EPE resistivity logger
  • Test button shows the monitored values present at the outputs of TL074 IC4a/IC4b, as detected by the PIC’s ADC conversions.
    • what is the diference between logger and meter ?
      • My new test with EPE device
        But i have a question about electrode distance . I use twin probe and electrode distance is 1 meter.
        Can we choose the distance between the electrodes 2 or 3 meters? and when the electrodes distance is 1 meter How deep can penetrate?
        • Originally posted by ishtar hunter View Post
          [ATTACH]33015[/ATTACH]
          Hey.
          İs archeosurveyor connect to epe directly and receive data ??
          İs that possible
          • here is my project
            • Hello friends .
              Usually the number # must be in what range?
              • Originally posted by COBRA-11 View Post
                Hello friends .
                Not use a static numbers. Depends on the ground
                • Hi just completed the build of the resistivity logger and I a am getting B MAX reading and no A reading Everything else seems fine. Any ideas
                  ken
                  • Hi can you program a PIC for me for this EARTH RESISTIVITY LOGGER. It is no longer available from EPE.
                    Thanks in anticipation
                    Ken
                    • Originally posted by rwl518p View Post
                      Ken
                      I have two pic new programmed. If you want I have one system complete (all componente in pcb solder) end assembled in a box with connector and other component. Make an offer and I send you.
                      • Originally posted by algol View Post
                        I have a unit completed as well I just need a programmed PIC.
                        Ken
                          Ken
                          Please tomorrow reply with quote this message for dont forget it.
                          I send you hex code tomorrow
                          • Originally posted by wtrk View Post
                            Hi I do not have any way of programming it. I just need someone to programme a PIC for me.
                              I can send you a new pic to 40 euro + shipment.
                                A PIC only costs about 8 Euros and postage would be about 1 euro, so 40 euros plus shipping is too expensive.
                                Ken
