Lowrance MCC saved data structure.
  • Lowrance MCC saved data structure.
    I'm interested to know the structure of the sonar data recorded on a multimedia card in a Lowrance unit. Is each return geo referenced? I'd like to import the recorded data to Surfer to produce rough bathymetry maps.
    Mark
    Lowrance Sonar Log Data
    Yes, GPS position data is imbedded for each sounding in a Lowrance sonar log (.slg) file. You can use the Lowrance Sonar Viewer application to export the raw data (x,y,z) to a text file for import into Surfer.
    http://www.lowrance.com/Software/PCS...nar_viewer.asp
    This link may be helpful to you.
    http://conserveonline.org/docs/2004/...tudy_Final.pdf
    Gary
      Good question!!!
      That was a good question...
      Has anyone tried to get out the other data from the Lowrance MMC file???
      It cantains the echo intensities and positions for each ping, so it could be nice to be able to unpack all the data and run in a program of your own...
      The sonar viewer is quite good, but when displaying the sidescan image recorded with a modified Lowrance it has its problems. It would be easy to build a mosaic-picture of large areas if one could unpack the lot...
      Check out one of my modified-lowrance-sss images on the web (screenshot from the sonar viewer) at the following site (wrecksite in Finland)
      http://www.hylyt.net/hylky.jsp?view=...strandin_hylky
      If anyone has a clue how to do it, tell me!!!
      Henrik
        Lowrance data structure
        Thanks for the feedback on my question, interesting stuff. I'd be interested in getting a copy of a data file to look at if possible. I have a LCX15MT but I haven't installed a data card or interfaced my GPS to it yet ... and it's cold so the boats out of the water. My email address is:
        mark dot munro at ppo2 dot com
        What kind of time is available per meg of storage?
        Thanks,
        Mark
          slg data structure
          Do you have news about the structure of lowrance slg files?
          It would be really interesting to write an alternate software for processing sonar recordings.
          tanks,
          tom
            Hello Tom,
            I have broken the Lowrance data structure, but I have not had the time / knowledge to write a nice software to display the files in a more "sidescan"-convenient way.
            I know which bits are displaying the position, speed etc. From this, a software could be made which compensates the scan speed to the depth, so that the images are shown in the right scale (no streching, mosaic possible etc.)
            Does anyone want to write a software and share it back to me, if I give you the structure?
            Henrik
              Henrik,
              Could you please post the slg structure you have broken down!
              Thanks,
              RGecy
                Weird duplicate thread
                Boy, it's odd that I posted this same question just yesterday
                Here's what I've found out so far: No response from the various authors of programs that do read/convert the SLG format files. Still waiting. I also contacted Lowrance, no response yet.
                I had read in an internet post that somewhere there's an academic paper that lists a lot of information about the format of the file, separate from the limited information that the slg2txt outputs. Still looking for the paper, although I've found another couple that reference SLG2TXT.
                If anyone here has any information on the file, please post it, as I'm currently stumbling my way through reverse engineering the binary data, and it's a pain.
                Erik
                  Ahh, I see
                  I see Robert bumped the post. Makes sense now. I'll go back to mumbling to myself.
                    A start...
                    Hello,
                    I have come quite far in taking the code apart. Hope you will share back your results! It would be great to get a good viewer taking the position and speed into account!
                    Here goes:
                    Before each "ping", a string of data is displayed. It is of different length, depending if the GPS position is included or not (GPS updates 1 time/second, but the pings are usually more frequent). I think it can also be dependent on Lowrance product models.
                    I will list which byte means what (1 byte = 8 pcs zeros or ones) starting from when each new ping is started. This example is a string where the GPS data is included.
                    Byte 1 = ?
                    Byte 2 = ?
                    Byte 3 = depth limit (low)
                    Byte 4 = depth limit
                    Byte 5 = depth limit
                    Byte 6 = depth limit (high)
                    Byte 7 = depth (low)
                    Byte 8 = depth
                    Byte 9 = depth
                    Byte 10 = depth (high)
                    Byte 11 = GPS position, mercator meter, y (low)
                    Byte 12 = GPS position, mercator meter, y
                    Byte 13 = GPS position, mercator meter, y (high)
                    Byte 14 = 0
                    Byte 15 = GPS position, mercator meter, x (low)
                    Byte 16 = GPS position, mercator meter, x
                    Byte 17 = GPS position, mercator meter, x (high)
                    Byte 18 = 0
                    Byte 19 = ?
                    Byte 20 = ?
                    Byte 21 = ?
                    Byte 22 = ?
                    Byte 23 = ?
                    Byte 24 = ?
                    Byte 25 = ?
                    Byte 26 = ?
                    Byte 27 = Time, milliseconds, (low)
                    Byte 28 = Time, milliseconds, (high)
                    Byte 29 = ?
                    Byte 30 = ?
                    Byte 31 = speed (low), float
                    Byte 32 = speed
                    Byte 33 = speed
                    Byte 34 = speed (high)
                    Byte 35 = ?
                    Byte 36 = ?
                    Byte 37 = ?
                    Byte 38 = ?
                    Byte 39 = ?
                    Byte 40 = ?
                    Byte 41 = ?
                    Byte 42 = ?
                    Byte 43 = ?
                    Byte 44 = ?
                    Byte 45 = Ping listening starts, with full volume 255 (11111111), new ping starts after byte number 2450
                    Byte 46 = 255 (11111111)
                    Byte 47 = 255
                    255
                    255
                    255
                    255
                    253
                    255
                    255
                    255
                    255
                    229
                    185
                    150
                    139
                    127
                    119
                    122
                    120
                    108
                    97
                    101
                    106
                    103
                    89
                    69
                    85
                    89
                    89
                    94
                    90
                    68
                    And so on, towards zero as the echo fades, until a new ping starts at byte number 2450
                    Good luck, best Regards,
                    -Henrik
                      Looking for the flag....
                      This is one example where you see the beginnings of 12 Lowrance-pings (each ping has a column)
                      The ones which begin with 4 have the GPS data in the string, the ones which begin with 1 do not...
                      -> pings 5,6 and 11,12 have the GPS data.
                      It should not be impossible to sort out which pings have the GPS data and which do not, and from that get the position data....
                      1 1 1 1 4 4 1 1 1 1 4 4
                      44 44 44 44 109 109 44 44 44 44 109 109
                      236 236 236 236 236 236 236 236 236 236 236 236
                      70 70 70 70 70 70 70 70 70 70 70 70
                      17 17 17 17 17 17 17 17 17 17 17 17
                      67 67 67 67 67 67 67 67 67 67 67 67
                      72 72 72 72 72 164 164 144 51 51 51 193
                      225 225 225 225 225 240 240 194 179 179 179 117
                      108 108 108 108 108 108 108 108 108 108 108 108
                      64 64 64 64 64 64 64 64 64 64 64 64
                      122 122 122 122 61 64 122 122 122 122 64 66
                      113 113 113 113 153 153 113 113 113 113 153 153
                      104 104 104 104 128 128 104 104 104 104 128 128
                      63 63 63 63 0 0 63 63 63 63 0 0
                      230 159 221 98 219 219 230 230 230 168 219 219
                      179 20 52 244 187 187 179 179 179 147 187 187
                      65 54 50 57 42 42 65 65 65 69 42 42
                      64 64 64 64 0 0 64 64 64 64 0 0
                      250 159 63 228 122 122 206 110 19 179 122 122
                      0 1 2 2 113 113 4 5 6 6 113 113
                      0 0 0 0 104 104 0 0 0 0 104 104
                      0 0 0 0 63 63 0 0 0 0 63 63
                      96 96 96 96 36 98 96 96 96 96 106 168
                      9 9 9 9 212 244 9 9 9 9 115 147
                      255 255 255 255 61 57 255 255 255 255 73 69
                      255 255 255 255 64 64 255 255 255 255 64 64
                      255 255 255 255 132 41 255 255 255 255 88 253
                      255 255 255 255 3 4 255 255 255 255 7 7
                      254 253 253 254 0 0 254 253 254 254 0 0
                      255 255 255 255 0 0 255 255 255 255 0 0
                      255 255 255 255 78 78 255 255 255 255 68 68
                      255 255 255 255 29 29 255 255 255 255 154 154
                      255 255 255 255 5 5 255 255 255 255 7 7
                      228 230 230 231 64 64 232 233 231 232 64 64
                      184 186 185 187 0 0 187 188 186 188 236 242
                      150 150 148 150 0 0 151 149 151 153 98 211
                      136 139 138 138 0 0 140 142 142 145 199 198
                      125 125 130 124 0 0 129 133 134 135 64 64
                      124 121 124 118 152 185 125 127 128 128 185 83
                      126 125 125 119 67 211 125 128 128 126 211 65
                      122 118 121 111 161 15 116 120 124 113 15 75
                      108 90 112 103 192 193 93 112 115 96 193 193
                      89 86 108 104 96 96 101 110 112 74 96 96
                      61 92 101 104 9 9 98 93 104 91 9 9
                      57 94 86 95 255 255 88 80 101 98 255 255
                      81 89 86 81 255 255 84 83 100 79 255 255
                      105 90 108 90 255 255 94 94 105 90 255 255
                      109 89 108 93 255 255 87 102 107 92 255 255
                      104 86 108 80 254 253 75 102 91 100 254 253
                      81 98 106 60 255 255 80 96 65 101 255 255
                      88 98 105 65 255 255 78 90 65 96 255 255
                      95 67 88 72 255 255 73 91 81 101 255 255
                      89 72 77 79 255 255 75 100 98 116 255 255
                      79 85 77 77 231 232 87 103 99 116 229 234
                      61 85 81 88 187 188 92 100 80 111 184 189
                      73 78 70 99 150 150 84 77 68 96 151 145
                      82 94 87 103 140 140 66 67 83 79 139 138
                      83 102 97 107 129 125 85 64 83 91 129 131
                      - Henrik
                        Here's what I know (and think)
                        I am working with a Lowrance LMS-525C DF Sonar/GPS Chartplotter Combo. I am attempting to use it for Echo Sounding in an industrial waste pond.
                        I have analyzed the raw binary slg file produced by this machine in light of the very helpful starting information provided in this forum.
                        Here's what I know / think:
                        An SLG file consist of a file header followed by some number of records.
                        The File Header contains the following information:
                        Bytes 0x00 - 01 is a 16 bit integer. probably the revision number of the file. (I get 0x0100 for now)
                        Bytes 0x02 - 03 are unknown to me -- currently set to 0x00
                        Bytes 0x04 - 0x05 are a 16 bit integer giving the size of any single record within the file. I'm my case 0x07B2 or 1970 (base10) bytes.
                        Bytes 0x05 - 0x06 are unknown to me -- currently set to 0x00.
                        Here ends the information to be found in the header for the binary file.
                        The rest of the file is a sequence of records all having the byte-size given above.
                        A record has a (short) header followed by the data.
                        In terms of offsets into a record, A record's header is
                        0x00 - 01 is unknown to me currently set to 0x00.
                        0x02 - 0x03 is a critically important 16-bit quantity which enumerates which 'optional fields' are to be found in this record. More on this in a minute. For now, let's call this the "Manifest Variable."
                        0X04 - 0X07 is a 4 byte float value giving the "Lower Limit"
                        Here endeth the definition of a record's header.
                        The Data in a record consists of up to 13 optional fields followed by the ping data. As near as I can tell the optional fields follow the same sequence as in the file created by reading an slg file into Lowrance's SonarViewer.exe and then outputting a CSV (which, in all likelihood, is equivalent to that file produced by their slg2txt.exe utility.) Specifically, the sequence of the optional fields appears to be:
                        Depth: 4 byte float
                        Water Temp: 4 byte Float
                        Temp2: 4 byte float
                        Temp3: 4 byte float
                        Water Speed: 4 byte float
                        Position X: 4 byte Integer in Mercator Meters
                        Position Y: 4 byte Integer in Mercator Meters
                        Surface Depth: 4 byte float
                        Top of Bottom Depth: 4 byte float
                        Time offset: 4 byte integer
                        Speed: 4 byte float
                        Track: 4 byte float
                        Altitude: 4 byte float
                        following these optional fields is the ping data.
                        The ping data consists first of a 16 bit integer giving how many 'listenings' are present in this record, and then of that many unsigned characters (255 to 0 in value) giving the intensity / volume of the sound heard at a particular instant.
                        Any remaining space in the record is padded with 0x00.
                        Now, which optional fields are present in a given record? Sadly, I failed miserably in my attempts to logically decipher the Manifest Variable. I can, however, say that in my particular data, the following values have the following meanings (all cases are using 200khz mode for pinging):
                        Manifest Variable = 0x112C, raw (or 0x2C11 if x-lated to a short int) means
                        Depth: present
                        Water Temp: present
                        Temp2: absent
                        Temp3: absent
                        Water Speed: absent
                        Position X: absent
                        Position Y: absent
                        Surface Depth: present
                        Top of Bottom Depth: present
                        Time offset: present
                        Speed: absent
                        Track: absent
                        Altitude: absent
                        Manifest Variable = 0x012C, raw, means
                        Same as 0x112C except Water Temp absent.
                        Manifest Variable = 0x146D, raw, means
                        Depth: present
                        Water Temp: present
                        Temp2: absent
                        Temp3: absent
                        Water Speed: absent
                        Position X: present
                        Position Y: present
                        Speed: present
                        Track: present
                        Altitude: present
                        Same as 0x046D with Water Temp Absent
                        (So, o.k., the first nibble, or the first bit of the first nibble, appears to control water temp, but that's the only sense I could get out of it)
                        Notes and comments:
                        1. I saw no field for "Upper Limit." Seems to always be 0.000 in the CSV file.
                        2. I have not exhaustively tested these Manifest Variable interpretations yet, but I'm pretty sure my data only has 4 possibilities. If I find others, I will write again.
                        3. In the cases of those optional fields that are always absent from my data, I'm only guessing about their place / sequence among the other optional fields. If you find otherwise, please let all of us know.
                        4. I've glanced at older versions of the slg files, in the form of sample data supplied by Lowrance. They seem to follow the same general scheme with the following caveats:
                        A. No version number. They seem to begin at the "Size of Each record" value
                        B. Their "manifest variable" interpretations or implementations seem to be entirely different from Rev 1. Good Luck.
                        5. Could someone, please, give me a logical explanation for the interpretation of the Manifest Variable in Rev. 1 of the slg file? I'd learn a lot from hearing it.
                        6. General meanings of each of the fields can be found on page 153 of http://www.twdb.state.tx.us/RWPG/rpg...ationBrine.pdf
                        7. I wrote, in C++, an importer for the CSV version of the SLG file sometime ago. I also have adequate binary-read facilities left over from my hack on version 3 of Lowrance's USR file. I've begun work on the importer for this binary slg file. It won't take long (so long as I can keep interested. The professional need has passed for now.) If someone has the web space, I'm willing to post the source code when it is done.
                        8. Why I bothered: The whole reason I chose to hack the slg was because the speed of sound in the industrial soup that we are surveying is more than different enough from that of normal water to make the reported depths meaningless. I'm hoping to read the ping return times from the slg file for a know depth, back-calc the speed of sound from that, and then go on to survey the rest of the lake. Also, the Lowrance seems to have difficulty in depths under, say, 3.5 feet. (and this pond happens to be a generally shallow evaporation lake.) I hope that I can overcome this limitation as well.
                        9. Comments, questions, suggestion, are welcome.
                        10. Thanks again for the great starting point. I hope all this is useful to someone else, too.
                          minor correction
                          Manifest Variable = 0x046D, raw, means
                          Same as 0x146D with Water Temp Absent
                            I have a program in C++ that reads the lowrance slg files and have already broken down the header.
                            Yes it is very complicated and is almost too much to post here. The key to it is, there is a set of flags that determine which bytes of data are present in each ping. The hard part is, that they are actually individual bits. Basically 1's and 0's for True or False. These offset bits will determine what bytes to read.
                            I have done a lot of work to get this far, but I am swamped and have basically abandonded the project. If anyone is will ing to take over my work or at least see what has been done, I would gladly email you all of my files.
                            Just let me know!
                            Robert
                              Sure
                              I'm pretty happy with how my code looks so far, but having something sane for the manifest variable would certainly help.
                              So, please, send along what you've got to:
                              rrkusaba at linuxmail (you know the symbol here) org
                              Thanks. When / If I get it done, I'll write back.
                              RK
