Hello,
XP produces an excellent metal detector. The Adventis 2, that has a manual ground rejection pot. Then its little brother is the ADX250, which has same tech specs but fixed ground rejection. Here are some pictures of my ADX250 from which it is clear that both models share same motherboad and chipset. I would like to add a manual ground rejection pot to my ADX250 and trasform it in a Adventis 2. I modded a Cibola (that is a Vaquero with a fixed GB) with excellent results, but this time I need Your help. Here are some pictures:
1) Mobo and chipset of Adventis2 and ADX250 are the same:
2) As You can see even front panel is ready for a pot:
3) Heart of the ground rejection system, with trimmer and soldering points to attach a ground rejection pot:
Do You think that is enough to remove that trimmer (it is a trimmer, right?) and solder pot in place to do the mod?
Thank you for any advice you will give me.
Turbo
Turbo
