Kit wanted
  • homefire
    I just purchased two TGSL Boards this month. All Parts from Tayda for two build was like $25.00.. Do it that way. LOL, Tayda did not have the LM7808. I may have order one or two parts from NewArk. Cant remember but here is my Tayda order plus a butt load of Bin parts.
    How to track shipment?
    Item Sku Qty
    BC547 Transistor NPN 45V 0.1A A-137 10
    1N4148 Switching Signal Diode A-157 50
    2N2222A 2N2222 NPN Transistor 0.8A 40V TO-18 A-113 4
    LM358N LM358 358 Low Power Dual Op-Amp IC A-045 10
    LM393N LM393 IC LOW POWER DUAL VOLTAGE COMPARATORS A-023 5
    LF353P LF353 IC 353 JFET-INPUT DUAL OP-AMP A-033 5
    2N2907A 2N2907 PNP Transistor 60V 0.6A TO-18 A-115 2
    PN2907A PN2907 2907 PNP 60V 0.8A Transistor A-108 10
    10K OHM Linear Taper Potentiometer Round Shaft PCB 9mm A-1847 2
    100K OHM Linear Taper Potentiometer Round Shaft PCB 9mm A-1848 2
    8 pin DIP IC Socket Adaptor Solder Type A-001 10
    2.2K OHM 1/4W 1% Metal Film Resistor A-2341 20
    3.3K OHM 1/4W 1% Metal Film Resistor A-2607 20
    220K OHM 1/4W 1% Metal Film Resistor A-2329 20
    10K OHM 1/4W 1% Metal Film Resistor A-2203 20
    15K OHM 1/4W 1% Metal Film Resistor A-2182 20
    1K OHM 1/4W 1% Metal Film Resistor A-2200 40
    100K OHM 1/4W 1% Metal Film Resistor A-2248 50
    330K OHM 1/4W 1% Metal Film Resistor A-2330 20
    470K OHM 1/4W 1% Metal Film Resistor Royal OHM Top Quality A-2180 20
    47K OHM 1/4W 1% Metal Film Resistor A-2279 20
    4.7K OHM 1/4W 1% Metal Film Resistor Royal OHM Top Quality A-2310 40
    22K OHM 1/4W 1% Metal Film Resistor Royal OHM Top Quality A-2284 20
    200K OHM 1/4W 1% Metal Film Resistor A-2630 20
    20K OHM 1/4W 1% Metal Film Resistor A-2339 20
    27K OHM 1/4W 1% Metal Film Resistor A-2772 20
    24K OHM 1/4W 1% Metal Film Resistor A-2771 40
    1M OHM 1/4W 1% Metal Film Resistor A-2277 20
    0.015uF 50V Multilayer Monolithic Ceramic Capacitor A-1471 10
    0.022uF 50V Multilayer Monolithic Ceramic Capacitor A-1472 10
    0.22uF 50V Multilayer Monolithic Ceramic Capacitor A-1367 10
    15pF 50V Multilayer Monolithic Ceramic Capacitor A-1393 10
    0.1uF 50V Multilayer Monolithic Ceramic Capacitor A-214 30
    10pF 50V Multilayer Monolithic Ceramic Capacitor A-1341 10
    10uF 25V 105C Radial Electrolytic Capacitor 5x11mm A-4534 10
    100pF 50V Multilayer Monolithic Ceramic Capacitor A-1359 10
    470nF 0.47uF 100V 5% Polyester Film Box Type Capacitor A-568 10
    22nF 0.022uF 100V 5% Polyester Film Box Type Capacitor A-560 10
    220uF 16V 105C Radial Electrolytic Capacitor 6x11mm A-4543 10
    220nF 0.22uF 100V 5% Polyester Film Box Type Capacitor A-565 10
    052317
  • Tibuck19
    Originally posted by sinko1 View Post
    hey sells his kits with a coil and prebuilt and very pricy I might add!
  • Tibuck19
    he sells the boards but has not kits , they are out of stock, I would like to give the TGSL a shot.
  • Koala
    Doesn't SilverDog sell the TGSL EDU Kit
    Discrimination is good no VDI
  • sinko1
    see here www.crazy-tech.net
  • Tibuck19
    started a topic Kit wanted
    Kit wanted
    Hi everyone, I am getting tired of digging up pulltabs and nails haha as you can all relate too im sure, I contacted silverdog to see if he had any kits that do discrimination (board and all the components ) as of now, he does not, I have made a few fully working Surf Pi's and a minipulse plus, I feel confident enough to try something else that has Discrimination capabilities, besides Andy, which I would love to do business with again, Where or whom else can I buy a kit or two from ?
