TP4 waveform wrong?
  • Reg
    Hi Exciter,
    You should make the pulse frequency an outside adjustment so it can easily be changed. Sometimes just a little adjustment will cure the problem.
    Now, if the problem is caused by other things, then those will have to be fixed also. As an example, if you increase the gain, then the battery voltage becomes a critical issue and a good regulator could be needed. I use a 14.4V Li Ion battery and regulate the voltage down to 12V. This keeps things stable.
    Now, as for your use of the aluminum tape for shielding, I suspect it is causing problems. You need to look at the signal at the output of the preamp to see just how much droop is occurring. Usually, the use of aluminum tape causes the output signal to droop because the tape is detected as a target. This causes the signal to droop for some time.
    One big problem is there is no simple material that is cheap and easy to get that can be used for shielding. Some of the conductive paints work well. I have used them.
    I have also used some of the thin conductive mylar film and wrapped it around the windings. I have also used some simple conductive ribbon I purchased at Walmart.
    My preferred tape is a conductive polyester plated tape that has a very thin coating almost like paint. Unfortunately, it is very difficult to come by.
    I used to buy it in single rolls, but it is not available that way any more. So, I have been trying to buy 10 rolls from Schlegel, but so far have been unsuccessful in getting them to send it to me.
    Reg
  • exciter
    what i also figured out is, that im almost unable to trigger on any signals???
    they all jumping around and im not able to measure any pulse.
  • exciter
    My R17 and R19 are 100k with the NE installed.
    Me and my friends took the HH to a test today on an old WWII airfield, but i only found old nails etc....
    also the HH sometimes beeps around random seconds.
    i could only use some puls-width settings, because its beeping every time on some.
    or does my shielded coil is the error here? i uses Al-Tape.
  • Reg
    Hi Exciter,
    The LM318 should work. If you can't zero the amp, then as you said, you might need to change the values of the resistors you mentioned. You could reduce the value of the 1 meg. This large of a resistor could cause extra noise also. So, you might try a lower value of one, maybe a 100K or so.
    Keep in mind that the LM 318 will be noisier than the NE5534A. So, when trying to hear the very weak signals, the noisier IC will cause more problems.
    Reg
  • Reg
    Hi Gef,
    Check and see if your two NE5534's that have different gains are not made by different companies. I suspect they are. If they are, which company seems to have the fastest one?
    It appears the NE5534's are being phased out. NJM and Philips are no longer making them. This only leaves TI and ON semi that I can find.
    Making the AD797 work well enough that one can sample quickly takes a lot more work. It is tough and that is why I have decided to try to find a different IC that will be almost as quiet. I will let all know what seems to work.
    Reg
  • gef12
    Hi Reg
    Yes thanks for all your valued comments.
    Interestingly I replaced my 5534 with another and suprisingly my sensitivity shot up a little, not much but noticable. Must be different batch that I had purchased... would be a good thing to try. Also I did try an AD797 previously but it didnt work ...it just would not see anything.... but will try that suggestion of yours in the near future.
    I have my unit crammed into a small alluminium box which should give it ample shielding, and had to get that box from the U.S. Just doesnt seem to be quite what you want these days on the shelves so we have to improvise.
    Next step will be to construct the rod .. have to have it all ready by June when I go out bush.
    thanks for all reg
    cheers
    gef
  • exciter
    Hi all,
    will try these settings.
    I tried also an LM318 instead of NE5534 but i couldnt get Tp4 to zero, so i think R17 and R18 must be changed...right?
    I shielded my coil with aluminium-tape. Is it good or not so good? Should i go for another shield material?
  • Reg
    Hi Gef,
    For some reason the pic of the diodes and resistor circuit across the preamp didn't attach. So, I am trying again. The addition of the two 4148 diodes and the 22K work well on the high gain of the original HH. If the gain is reduced significantly, then the 22K will have to be reduced accordingly.
    Reg
  • Reg
    Hi Gef,
    One thing you didn't mention is if you built a form of ground balance for your PI. Ground balance is great but it can reduce the sensitivity.
    As for your sensitivity, you are close to the limit on the small stuff. However, there are a few tricks that help a little. Again, the strides will not be great, but you can gain a little more.
    So, to try to answer your question, you should be able to reduce the gain even more on IC 6 and use a DD coil. I am not sure just why you can't. It should be possible since I am doing it on my HH.
    The one thing that will allow you to reduce the delay (which can result in detecting both smaller gold and a little deeper) is to reduce the gain on the preamp some more. Also, the gain is not linear over the range of nuggets you should be able to find. If you search this forum but search for the following; "Low Noise Front for P.I." by Ferric Toes you will see how the gain tapers off on targets with a very short delay. This results in two big problems. First, the gain on small gold is reduced dramatically and the second is the earth field effect can cause problems. Both are not good. This shows up on his pic of the output of the preamp where the "fat" signal becomes thinner at shorter delays.
    Here is a link to the discussion. http://thunting.com/geotech/forums/s...ighlight=front
    I hope it works. The reason I linked to it is because it discusses the importance of reducing the gain. What isn't discussed is the fact some brands of IC's are better than others. This is another thing that Eric found out. So, reducing the gain can be more important with some IC's.
    Now, I used Eric's test technique and found I could reduce the gain to about 100 and my opamp worked fine with any coil. Reducing the gain does allow for faster sampling, but more importantly, increases the gain for detecting smaller nuggets, once the gain is made up in a later stage.
    You might also consider building Carl's double amp preamp circuit as an add-on and not use a single amp for the preamp. This would allow for additional gain without the problems involved with a single amp. It isn't necessary, but should help overall.
    One other thing you might want to try is something that I came up with that was posted on another forum and that is to add a diode and resistor combination across the feedback resistor of the preamp. The basic design was posted on the PI forum by another guy to whom I had sent the idea, so I will show it here. Now, if the gain is changed from the original, then the 22K resistor will have to be changed. You could experiment by using a 25K pot, and may find you will have to go down to a low value of 2K or maybe less at reduced gain.
    What this little circuit does is reduce the gain and speed up the preamp which also allows for a little faster sampling, but more importantly, it reduces the ground signal. In some cases, the reduction is enough that no ground balance is needed, which effectively increases the depth capability.
    Finally, the IC noise is still a problem when searching for small gold because it interferes with hearing the very weak signals. My little diode circuit allows one to use some other low noise IC's that won't work without it. Right now, I have another IC coming my way I want to try. I have been able to use the AD797 which won't work without the diode circuit, but have had to reduce the resistor value even more. Unfortunately, the AD797 is quite expensive and does require a little more reduction than I would like to use. So, I am always looking for the ideal replacement for the NE5534A.
    If you are hunting in the field, shielding of the electronics isn't quite as critical, but is still a good idea. I use a plastic housing but add shielding inside the case to reduce signal pickup. It is amazing just how much it helps and where it helps. If you have the resistor in series with the FET, you might not need any form of heatsink on the FET. That becomes a great noise antenna and makes noise a bigger problem in some areas by re-radiating the noise inside the housing. I am going to use a heatsink but do something different and that is to isolate the heatsink from the FET and then ground the heatsink. This way, the FET is "shielded" from radiating noise. Using one of the newer plastic encased 220F types helps because the FET case is already isolated by the plastic.
    So, as you can tell, there are always things to try that can help. I hope this helps you a little more.
    Cheers,
    Reg
  • gef12
    PS
    Also have reduced my sensitivity to ironstone hotrocks to almost nil, which I feel is a good thing.
    I have a 22ohm in series with the mosfet to the coil to reduce current.
    Am using low coss mosfet at 600v and 2A. I have made slight mods to the coils my cutting at least a foot off the cable to reduce the cable capacitance.
    My targets are gold nuggets. Small ones for the region I go to.
  • gef12
    Sensitivity
    WHile you are here Reg
    I was chatting to you a while ago about my HH and you helped me with a few issues like the ground balance etc.
    Wondering if you could advise on a good combination for the feedback resistors and caps for the opamps. Currently have mine at 320k for the IC6 (wont go lower with the DD coil but with a mono will go down to 100k for some reason) and yes have played with the balance resistors too.
    Also using 470k for IC8A and B. Am getting about 4 inch max with Minlab 11 inch DD coil on .9 gram gold nugget and maybe a 5 to 6 inch on 10" coiltek eleptical coil. Its close to what I expect but am greedy I WANT MORE
    Do you think this is what I should expect. Delay is better with the DD than the Mono , currently about 8uS with DD and 10 with Mono. Anything else I can tweek or play with. Am using li-ion 15volt battery going thru 12v Regulator and have separate Audio amp with 9 volt supply. This is also non-vco option. Thanks in advance.
    CHeers
    gef
  • Reg
    Hi Exciter,
    I am glad it is working better. Now, you don't want to use any battery with a lower voltage than what you have. You may experience problems with the other power supplies not obtaining the proper values. Also, you may be getting some interaction if the battery you are using can't handle the current draw and drops in voltage a lot. This could be part of your problem.
    As for your depth on your coin, it doesn't sound to bad for a beginning. Now, you need to try to find the best possible adjustments for the delay, the second delay, the pulse length and sensitivity adjustment. All can interact at times and cause changes in the depth capability.
    For starters, I would try to get the main delay down as short as possible. I would start out with a 100 usec pulse length, a 10 usec sample time and a second sample at a couple of hundred usecs later than the main sample.
    For silver and copper objects, you will need a longer pulse length for the best depth, especially on larger objects.
    Reg
  • exciter
    my fault, got a 100k. i looked at R35.
    I tryed it once again in the garden. HH seems to work alot better.
    i could regulate the threshold and was able to detect 10€ cent in ~17cm under potting soil. is this good?
    i will try my shielded coil, maybe its better.
    Hopefully it will work tomorrow, when i completely assemble it.
    first i tryed with 9V battery, but there was the problem with the threshold...even outside.
    with the 10,8V 4Ah LiON battery, everything seems to be good.
    its hard for me to find the best setting. Some told they are able to detect a can about 80cm, im not able at all.
    But maybe because of the settings...or are there some mods, which i can do? my coil resistance with 2,4ohm is okay???
    Thanks for your help, will tell you how my HH performs.
  • Reg
    Hi Exciter,
    You mentioned your threshold pot is a 4.7K. It is supposed to be a 100K. You might try replacing it and see what happens.
    Reg
  • exciter
    okay...
    my pot is 4K7 for threshold.
    TP9 goes from 0.1V - 1.70V, but i can only measure it, when PulseWidth is around middle position. When i decrease width, sound stutters like in the recorded mp3, and the voltage on TP9 is jumping.
    Tested without coil.
    R51 is 10k and r38 100k.
    Transistor values are right.
