And so it begins...
  • moorejl57
    One of the spice simulations I like playing with. Don't know what is causing the noise, I would start looking at the power supplies with the scope. Maybe someone else has a suggestion.
    Thank you for you help and suggestions. I will give the sim a look on Monday.
  • green
  • moorejl57
    Don't have a MPP so I'm guessing, looks like copper tape might be acting as a target. Not avalanching, maybe overdamped a little? Does the ringing damp out? How many micro seconds to damp out?
    The hot lead insulation monitoring is a neat trick. I needed to add a thin layer of Kapton tape to the lead since the voltage seemed to be arcing through intermittently. As a test, I decreased the TX frequency to 250pps and increased the TX pulse width to about 300us and the spike trace still didn't get flat at the top, so I guess I am not able to force an avalanche condition with the combined 5.3ohm series resistance (3.3 + 2.0). I don't have ability right now to adjust the damping resistor, but is does look a little overdamped based on your examples. I will try some different values on Monday.
    Below are the hot lead insulation spike at 300us and the TP3 signal that looks like ringing. It seems to be outside interference since it changes a lot by moving the coil.
ID:	354132 Click image for larger version
  • moorejl57
    Tried a spice simulation. middle trace(fast coil, critical damped, avalanched) bottom trace(fast coil, overdamped, reduced Rd to eliminate avalanche) top trace(added capacitance to make slow coil, same Rd as bottom trace, critical damped, no avalanche) slow coil critical damped decays faster than fast coil overdamped with same Rd.
    The LT Spice simulations look very interesting. I have used it in the past, but not for such a complex scenario, just a two pole LP filter for converting PWM to audio from a PIC. I will need to learn how to simulate simple front ends and targets, looks like a fun efficient way to test ideas.
  • green
  • green
    Originally posted by moorejl57 View Post
    Thanks green. Here is CH1 on coil hot lead insulation and CH2 on TP3 pre-amp out.
    [ATTACH]46379[/ATTACH]
  • mushaba
    I think that's ringing on tp3..
  • moorejl57
    a. To see coil decay shape. Clip probe to coil hot lead insulation, can't read volts but shape should be similar as hot lead. Can see if mosfet avalanches, flat at first part of decay. Including picture of my Tx circuit with hot lead and hot lead insulation(not MPP). I like to look at amplifier out and hot lead insulation on the scope when adjusting damping.
    b. If you are not looking for short TC targets with a fast coil(first delay time less than 10us)I would jumper MUR460 in series with coil. Adds some capacitance, requires a lower damping resistor, allows a higher peak coil current before avalanche.
    c. Use a spiral or basket for a fast coil with the MUR460 not jumpered, fast coils require less peak current for the mosfet to not avalanche. Less peak current less signal if Tx shape stays the same. Bundle wound might be better if not looking for short TC targets?
    d. Might try a different shield if the copper tape is acting as a target. Post a scope picture of amplifier out and coil hot lead insulation with no target.
  • green
    In my first pass testing of the completed board with a 7" bundle wound coil of 328uH and 2ohm resistance, damping resistor at 680ohm, SRS around 800kHz, I think I am not getting the best depth with it. It can air detect a US quarter at about 7" and a US penny at about 8-9". What are typical results for a well tuned MPP Rev. E so I know what to expect?
    I would like to do some experiments to improve the detection depth for coins and rings etc... and would like some advice on what are the top Pareto items to change first.
    a. Improve critical damping (I haven't been able to really dial this in yet due to jitter from TX pulse period messing with scope trigger)
    b. Modify coil current with serial resistance to avoid MOSFET avalanche (do I just change the existing 3R3 2W resistor on the board?)
    c. Use a different coil design (basket, spiral etc...)
    d. Change current shielding from wrapped copper tape to something else?
  • moorejl57
  • moorejl57
    You get a direct ratio of the voltage IE: a 700 volt peak will give you 7 volts on the scope, so you dont blow your scope
    I am definitely going to give this method a try, I never did actually measure the flyback voltage since my scope maxes at 50V/div and was well more than full screen. Based on what I have read here in the forum, I should not let the MOSFET avalanche since this will slow down the return to zero and is probably hard on the MOSFET as well. I assume the remedy is to add serial resistance to the coil?
  • 6666
    Seems like this could work as well, thanks.
  • moorejl57
    Nice detective work.
    The datasheet states that the MM74HC4538 is pin compatible with the CD4538. However that doesn't mean that it's compatible in other ways.
    Both the CD4538 and the MM14538BCP have a pulse width output of T = R*C.
    Lol, true that. I put in the new resistor values (where I work has a "makers space" with some parts bins and I found what I needed in 1%) and got almost exactly 100us at TP8 and 9.8us at TP9 and TP10. I also changed the dampening resistor to 680 ohm for my 170mm coil, set frequency to around 500 pps and TX pulse width to 185us. Now on to designing the enclosure and coil shells.
  • Qiaozhi
    OK, found root cause on my TP8, 9, 10 timing issues. The parts I recently received in the MPP Beach kit for U7 and U10 are MM74HC4538N. Looking at the data sheet, the time pulse period IS NOT RxCx. Instead it is spec'd as 0.7RxCx. As such for the EFE delay of 100us, R32 needs to be more like 10K/0.7 ~= 14.3K. In the same vein, R35 needs to be 4.7K/0.7 ~= 6.7K. Hope this helps other folks building this kit.
    [ATTACH]46368[/ATTACH]
  • moorejl57
