Electronic-Nulled Loops
I am suspicious about cd4051 in this circuit. There is multiplexing for sure but maybe there is just clever use of ordinary 4053 chip. What do you think?
I just now realized that there is a CD4024 chip on main board. CK wire goes to pin 3 of CD4024. Now I think everything is closer to being solved.
I compare the 2b board with the 2ba board. On the 2b board nothing is connected to pin 3 of CD4024. So this question is put to rest.
From this picture it looked like CK(white wire with purple stripe)is going through the hole in the main board. To the top side.Attached Files
Or do you mean from 6 and 2 of 393 at the end of the filters section.
why would it connect there?
Main board lm393 pin 2 or pin 6. Those are the disc and ground balance phase shifters taking signal from the Tx oscillator waveform. So CK could mean the Tx clock?
There are two power sources +12V from Dmc and +5V (probably) from the stabilizer on the autotune board, which is not taken into account in your diagram. It seems to me that CK can take the signal from lm393 pin 2 and pin 6 where there is 0V on the nautilus board.
Schematic. Now I hope I am a bit closer.Attached Files
555 configured as one shot monostable pulse generator. I should have looked more closely at your pcb layout. So pushing the slb switch merely triggers a pulse which enables the electronic potentiometers to do their thing. The pulse should be long duration maybe 3 seconds or so, after which the digital pots are disabled. Maybe that's how it works.
I discovered one more ERROR. In the forum posts about DMC IIb there is information that the inductance of the Rx coil = 8.42mH (FAKE). correctly RX=5.42mH. My colleague YOYO27983 also made a mistake by replacing Tx with Rx in the DMC VLF diagram (correctly Tx = 2.5mH, C1 = 47nf, C2 = 470nF, F = 15.39kHz, RX = 10.7mh, C = 10n, F = 15.38Khz ) I am one step away from starting Nautilus, I still need to connect the coil socket. Does anyone have a photo of the eight-pin DMC IIB coil socket connector from the printing side? I will be grateful for your tips. Greetings and wish you a healthy and happy Christmas.
Seems I was wrong, it looks very much like this track is output of voltage regulator. I will have to correct my schematic again.Originally posted by Mario-j23 View Post
For this circuit, the photos show pin 6(inhibit/enable) pin 7(Vee) and pin 8(Vss) are all connected to ground.(4051 chip)Originally posted by Altra View Post
That's good to know. The 4051 has vdd (12v), vcc digital ground(?) and -vee or analog minus(B-)?
It's important we know the power connections for the digital pots.
The datasheet has some interesting things to say about setting the Vee.
