Originally posted by WM6
My completed UMaxII (on vero etc) With a nod to the TGSL project
Width for pole end is 9mm. Just ordered four more. BTW I use nylon nuts and bolts from Ebay --way cheaper than so called metal detector coil bolts etc.
Look nice.Originally posted by mykaitch View Post
What are dimensions (between ears in first line)?
Looks like a useful item for DIY metal detector projects!Originally posted by mykaitch View Post
Aha! That is a clamp thingy used to secure a boat awning. I found them on Ebay (or at a Chandlers) for about 2.50 each. All nylon and they are easy to tap - just screw the bolt you want to use first (ie a metal one first). It is secured with those plastic thingys that join kitchen units together - - NOT rthe type witjh a metal screw. The stem etc came from an old £5.00 punt on Ebay (70's BFO broken).
