Originally posted by Teleno
Preamp
This is a sticky topic.
What is the advantage of reducing circuit resonance vs using a snubber to keep the voltage below avalanche volts? The coil decay time is faster with a snubber.
The LT is not JFET type like the AD (not sure?!). Descrete solution like cutting edge standalone op amp offers "repeat-ability" - it's all there in the package.
If you take 10 different op amps they will perform the same.
While the other solution may give unexpected results - lots of connections may pick up some noise long the way, component tolerance, etc.
It will be interesting to see a real working example, if it will prove better / worse.
It is when you need both fast turn-on and fast turn-off.Originally posted by eclipse View PostUsing a dedicated mosfet driver is better than a transistor pair.
In this case, however, fast turn-on is not required, only shorting the gate quickly to ground. A single BS170 does the job.
AD8610 is 6 nV/√Hz, my amplifier is 3.6 nV/√Hz.Originally posted by eclipse View PostAs for the preamp op amp consider the AD8620(x2) or AD8610(x1) - lowest noise, high speed, etc.
AD8610 is dual supply, my amplifier is single supply.
The purpose of my design is to do away completely with op-amps, be faster and achive lower noise. Look again at the circuit (download the simulation file). It's based on discrete components and has a gain of 1000 x Input noise is 3.2 uV (can be made 2.5 uV with emitter degeneration on Q4 and Q5).
AD8610 might be an option as a second stage though, not as preamplifier. I'll consider it and thanks for the sugestion.
P.S. LT1037 has similar characteristics and is usually cheaper.
Using a dedicated mosfet driver is better than a transistor pair. As for the preamp op amp consider the AD8620(x2) or AD8610(x1) - lowest noise, high speed, etc.
I have posted my novel GB scheme in another thread, should be tested in Aussie goldfields. If it works then gain shouldn't be a problem.Originally posted by Sean_Goddard View PostI was quoting the low gain front end as it seems that high gain ones suffer in Australian goldfields
The final design will be MCU based. I'm thinking ATtiny. The amplifier will be self-adjusting by two DAC outputs directly controlling the gates of J1 and J3. Tolerance is of no concern.Originally posted by Sean_Goddard View PostI want a few more people to comment on your amp designs Teleno. I am happy with the latest one. Have you run a component value variance sweep (MonteCarlo) on it to see how it performs? I envisage all values in the final build will be 1% resistors, but if the thing still works with 5% then we can wrap this section up and move on if all agree.
The current at Q2, which is the most critical parameter, is temperature compensated by D3.
Definitely.Originally posted by Sean_Goddard View Post, now I'm NOT looking to compete with ML,I would simply like a machine which had good performance on wet sand and costs less that $100 to build. We can do this can't we?
The following components should be added:
1 x ATtiny84 MCU (evt. ATMega family)
1 x MCP4728 quad DAC 12 bit
1 x standard 5V regulator.
1 x BS170 for driving the MOSFET's gate.
Alright I'll do the maths and the electronics design, you do the PCB layout and prototyping. Deal?Originally posted by Sean_Goddard View PostEEK..MATHS!!!
I can do the programming as well unless we have a more experienced volunteer.
EEK..MATHS!!!
But I see where you are going..I think.
That amp seems fast enough. I'm thinking to target 9ct thin gold rings. If we can hit those at a good depth (6" or more) then I think we will have a machine which is good for small nuggets too. My reasoning being is that I know the GPX4000 is a good gold machine, but look how much it costs. If we can make soomething which is comparable, maybe even better, then this will be a good project to build. I also want to keep it simple with no complex set up or calibration.
I was quoting the low gain front end as it seems that high gain ones suffer in Australian goldfields, now I'm NOT looking to compete with ML,I would simply like a machine which had good performance on wet sand and costs less that $100 to build. We can do this can't we?
FYI I have acquired an ML Etrac with an 18X15 SEF coil (plus standard) and on the beach it simply ROCKS. Deep, quiet and it discriminates, but I KNOW I'm missing those deep and thin rings, THAT is why I want to make a good PI. The Cscope 4PI just can't cut it in terms of the deep finds (sadly).
We're dealing only with the amplifier. Thin gold does not require higher gain per se, but a faster transient to capture the short time constant.Originally posted by green View PostPeak coil current is part of the gain equation. One amp with gain of 1000 same as ten amps with gain of 100. If thin gold is included in what we are looking for what would peak current and gain should we try for?
A fast amplifier allows for earlier sampling, which also means more signal for the same gain. Implementations around NE5534 introduce great delays which are unacceptable.
CORRECTION: The previous formula was wrong, the value of the peak current for a critical damping resistor R is:
where R is
Example:
L = 300 uH (typical PI coil), with Cc = 150 pF.
The drive MOSFET has a diode in series with the coil, therefore the capacitance seen by the coil is the diode's. Co = 100 pF
The damping resistor R should be under 547 ohms
The MOSFET breakdown spec. is 500V, then the maximum current is 1.24 A:
If shorter time constants are not interesting for you (hunting for larger objects) then you can increase Imax by adding capacitance to the coil resonant circuit, for example, by removing the series diode in which case Co is the output capacitance of the MOSFET, in the order of 1 nF:
But then you get flyback twice as long as in the first example.
Oly if the flyback decay rate is the same, which means 10x higher flyback voltage for 10 amp.Originally posted by green View PostOne amp with gain of 1000 same as ten amps with gain of 100.
Your compromise is to barely reach reach the breakdown voltage of the MOSFET that drives a given coil.
Cc = coil capacitanceCo = Mosfet output capacitance
Vbr = MOSFET breakdown voltage
L = coil inductance.
This is the maximum I you can work with for a given coil.
For small gold depth is not as important as a fast flyback, therefore you'd go for faster coils (less L and less Cc) and faster amplifiers which would normally have to be designed around discrete components as in my example above.
Peak coil current is part of the gain equation. One amp with gain of 1000 same as ten amps with gain of 100. If thin gold is included in what we are looking for what would peak current and gain should we try for?Originally posted by Sean_Goddard View PostIf we can turn that into a reality, then the problem of thin gold not being detectable is cracked. That amp is F A S T:......!
Is the noise figure one you put in or a calculated one?
I can but marvel at what you are doing as this depth of analogue design is outside my sphere of current abilities. But I think we have a winner in the input amplifier stage design. My only comment is that I think a gain of 1K is a little high, in order to use this in Oz it will have to be a lot lower.
Now something else not mentioned here, what about saturation and recovery? From what I see there is no problem with this with respect to this design. Does this mean it ois NOT a problem now?
Noise as calculated by LTSpice.Originally posted by Sean_Goddard View PostIf we can turn that into a reality, then the problem of thin gold not being detectable is cracked. That amp is F A S T:......!
Saturation is not a problem now.
Reducing R11 reduces gain. Easy calculation: gain = 1,000 x R11 / 50K
Another preamp for brainstorming. All criticiss, suggestions, improvements ... and breadboards! are welcome.
Actually this is a two stage: preamp + amp.
Design priorities: high speed and gain, insensitivity to power ripples.
Compromises: current consumption and noise. Both held as low as possible without compromising the priorities.
This is version has a gain of 1,000 and 2.6 mV output noise. Input noise is 3.3 uV. It consumes 8.7 mA.
Q1 and J1 added for common mode rejection (power line ripples).
Second stage Q4 - Q7 added for extra gain.
Current source J3 corrects the baseline, which should be about 600mV.
.ZIP attachment contains LTSpice simulation file.
Copyright: Oscar Gonzalez.
Do you have a pointer to such a design?Originally posted by Sean_Goddard View PostI still love this preamp design though, it's simple, cheap and very effective. Maybe it's why the late Great Andy Flind favoured it for some of his designs.
Can't really comment without seeing your circuit.Originally posted by Sean_Goddard View PostFair enough. I just realise that sometimes simulations don't necessarily translate into real life.
I tried changing the pulse width on your sim to incorporate the energy saving system I designed which measures the coil current and when there is no more di/dt it shuts the pulse off (as maximum I coil has been achieved). But is stops working. I know my circuit works so I took it out and just left the changes pulse width. Still Nada!
This preamp is fast, has a high gain (100 x), low output impedance and a good rejection of power ripple (58 dB).
Input noise is 2.7 uV in the range 1 KHz - 700 KHz.
D1 can be any schottky diode > 200mA and forward voltage as low as possible (e.g. BAT46WJ)
Adjusting procedure:
- Trim R3 to get anything between 100 uA - 140 uA going through the damping resistor R1.
- Adjust the baseline by R6 to a minimum of 600 mV - 700 mV at "vout".
Optional:
- Achieve lower (higher) gains by decreasing (increasing) R2.
.ZIP attachment contains LTSpice simulation file Preamp_geotech_2.asc
