  • Aziz
    Originally posted by Sergey_P View Post
    (oscillator + FFT) - very bad signal detector
    Optimal detector -> S(targets) = ∫ (Stx(t)*Srx(t)), technical realization – correlator
    For the harmonic signal Stx(t) = A*sin(wt+ф) need to know instantaneous (t) value w, ф, A . Oscillator it does not provide. Assuming that A,w – known constant, we can use DFT as correlator, but you must take into account its features.
    If, time integrating multiple of the period Tx, it is possible to choose the maximum number of samples to process. Otherwise - to apply smoothing function that limits the signal spectrum
    In the figure: a rectangular function and Blackman–Nuttall window
    Hi Sergey,
    thank you for writing some sentences now. I understand you this time.
    Yep, windowing limits the signal spectrum but it makes different solution approaches possible. Even the pure FFT solution.
    I didn't try all approaches. There might be more (maybe much more) potential for the detectors performance.
    Cheers,
  • Sergey_P
  • Aziz
    USB Powered VLF OSC Detector Controller
    Ok guys,
    spice simulation & circuit design finished: approx. 10 - 15 mA @ 5V with USB port power.
    I have to use p-mosfets this time and a DC/DC charge-pump converter generating the negative power supply for the op-amp (approx. -4.5 V). But the charge-pump is clocked by the LC oscillator (synchronized to LC oscillator).
    I have built the USB power cable already and I am keen on soldering the USB detector controller soon.
    Stay tuned ... it's going to be an interesting USB detector controller.
    Cheers,
  • Aziz
    USB Powered VLF OSC Detector Controller?
    Hi all,
    anyone interested in the USB powered VLF OSC Detector Controller with active RX-amplifier?
    Could be another nice and valuable KISS-project.
    I'm thinking of it.... stay tuned ...
  • Aziz
    (Aziz)
    FFT = ∑ DFT
    FFT * (win) >> DFT
    To select target – requires DFT
    Sergey,
    such a "compressed" conversation will lead to misunderstanding. I don't know exactly, what you are trying to say.
    Please put some sencentes there at least.
    BTW,
    a simplified processing of RX signal and TX reference can be done by only using the FFT on both RX and TX. So you don't even need Lockin-amp, I/Q demodulation of TX .. a very trivial task.
    Cheers,
  • Sergey_P
    (Aziz)
    FFT = ∑ DFT
    FFT * (win) >> DFT
  • Aziz
    Pics of Prototypes
    I haven't shielded my TX coil yet. And I haven't built the RX coil yet too. I've just put a RX coil I have found in a DD configuration.
    Hey, that's it. That's all the electronics I'm using at the moment.
    My previous prototype:
    Cheers,
  • Davor
    Now code it in the analog domain.
    No problem, I have my super sexy analogue multiplier.
    Funny thing is that, given the calculation complexity, even digital domain has some nasty limitations when it comes to some serious signal processing. Once you settle for a grown up DSP you find out that it uses so much power that you'd better done it in analogue instead.
    Only few people remember it today, but uptake of a 3G telephony stalled for a few years just because there was no digital solution at that time that would be practical with any realistic batteries. Finally a solution was found in a chip that was mostly analogue. Unlike the very much expected digital solution - it worked
  • Aziz
    BTW,
    you can't do the "World's best ground balance technology" (WBGB) in the analog domain. Yep, you can't do it with single frequency VLF detector either.
    But the current single frequency VLF project is so much beautiful and simple to implement it. And the outcome is very decent. A typical KISS-project.
    To the disbelievers of the WBGB: it's real and **********.
    Aziz,
    the master of madness
  • Aziz
    Gladly, but last time I checked there were no easy ways to enter, and no free platforms to play with. I'm not a bit inclined to code some odd functions into some soon-to-become-obsolete device by means of typing in the raw code. No way! Life is too short to waste it on some very temporary devices.
    If you can finger some open platform I'd be delighted to play with it. Otherwise I'll stick to analogue and do my "coding" there. It is basically the same thing.
    Yep, it can happen with Android systems quickly. And the f****** patent mania (f*** the patent trolls!) is blocking/obsoleting the devices too. Although quite cheap and small tablets available there.
    I'll keep doing with Win32 C/C++ and encapsulate the essential code to achieve some degree of platform independence.
    I hate Java. I really hate Java. I'm not going to code for Android.
    I hate Objective-C. No, I'm not going to code for IPhone, IPad, ITab too.
    I hate (Visual) Basic. I hate the inventor of Basic. I hate Bill Gates too.
    I hate all the other programming languages too.
    Oh yes, we have to wait for Windows 9. Windows 8 is going to be a bad version.
    Windows XP (good)
    Windows Vista (bad)
    Windows 7 (good)
    Windows 8 (bad)
    Windows 9 (must be good then)
    But software coding has its advantages:
    c = a*b
    c = a/b
    c = a*e^b
    c = a*log(b)
  • Davor
    Comeon guys, see the beauty of the math and DSP programming. You can do all the things and much more.
    Let's enter the "World's Best Digital VLF Technology"(c)(r)(tm) now.
  • Aziz
    (found somewhere on the Wiki-pages about window functions)
  • Aziz
    Aziz. Your plans for the production of the spectral window Rx?
    I don't know, whether I have understood you correct. You want to talk about window function?
    Ok, to give some basis to talk about, I'll give the following link to follow:
    (PJ, UFox, Rafferty, Robby_H look at it .. )
    Let's define the window w[n] for n = 0 .. N-1, where N = number of coefficients/samples in the window, usually a power of two due to efficient discrete FFT requirement.
    w[n] representing the factor coefficients of the window function.
    It is important, that the window function is symmetric and starting/ending (almost) with 0.
    w[0] = w[N-1] = (almost) 0
    The following window functions can be used:
    Hann window; B = 1.50
    Tukey window, α=0.5; B=1.22
    Cosine window; B=1.23
    Lanczos window (sinc window)
    and so on ... (Triangular, Gaussian, etc.. you see the analogy?)
    Further: sin²(), cos²(), sin³(), cos³(), sinc²(), sinc³() and others can also be used with right parameters of course.
    Any window function is convenient, which minimizes the spectral leakage.
    BTW, when using digital lock-in amp for the RX demodulation, windowing is also required (either RX, TX-I/TX-Q or both).
    Window function is not required, when the TX timing is generated from the Tablet/Netbook (clock source) and sound output/input are synchronized to each other. But we have an external clock source (the free running LC oscillator) and the sound card ADC system timing is not synchronized to it. So we have to use the window function.
  • Sergey_P
  • Sergey_P
    (complex) FFT
    I understand, thank you
