Some thoughts on this topic...
High-R shielding works well in some designs, not in others. The TDI requires 6 coats of graphite paint to get the shield R low enough to be effective. Eric has commonly used lead tape in his PI designs.
Graphite paint is commonly used in mass production for cost purposes. It can be difficult to control, but generally not difficult to connect to. Embedded wire or conductive tape work fine. Experienced manufacturers know how to do all this well.
In VLF, shielding can affect the loop null depending on geometries. It is usually predictable and in production the loop is slightly mis-nulled before the loop bottom is applied. Or, in the case of the e.g. Fisher F75 loop, final-nulling is done in a little access door after the bottom is applied.
Low-R shielding can alter the PI decay, again, depending on geometries, but it tends to be a static effect. I've applied aluminum foil directly to a bundle of magnet wire with little effect at 15us. If you are trying to achieve super speed, then some gap and close attention to symmetry are important.
Footnote:
KT, please don't provoke people with denigration or demands for credentials. If you have a question, ask the question. If you disagree, state your reasons.
Theories about coil-shielding
Thats right. Material should be Hard and brittle but during bonding time, it should not de-shape the coil otherwise it would destroy the nulling. Slow setting epoxy resign with smallest grain sand or some powder glass should do the work.
In a VLF coil the shielding makes or breaks it.
Manufactures even struggle to get a reliable system.
Marko Racer had a batch that couldn't run at very high sensitivity
As did a batch of Garrett Ace 250
Why do manufactures use graphite when is not easy to connect to instead of aluminium which you can crimp to or copper you can solder to ??
Tesoro went one further as on some of their coils the shell is also conductive
Having wasted time and money building coils that don't work at 100% I will stick to what works in the real fields
Originally posted by qute1 View PostAltair please be careful how you converse with other respected members (Kt315 is a very old and respected member of our community) people here are a wealth of information and experience and whatever your own background may be (you are relatively new member) please display grace and tolerance to all...... you never know there may be some people here with PHD's and/or 40 odd years experience in the field.....
Best wishes
If you have others advice for me on this matter, please, send me a PM, thank; this is a technical forum.
To close, I think that anybody is reading the thread with a normal critical judgment capacity, will be able to draw their own conclusions.
Originally posted by WM6 View PostCorrect.
We should add only, that to avoid some interferences in coil working,
those shield conductivity should be proper set (set to minimize eddy
currents and still retain enough conductivity to promptly maintain
changeable electrostatic charges between shield and soil).
Important especially in PI design with very early sampling.
So it is about proper conductivity (or resistance) of coil shielding.
Correct.Originally posted by Hyena View Post
Without conductivity your shield will not work as shield against electrostatic.
My first post here..
Aluminum foil and graphite are perfect material but copper self adhesive tape is never tested..
again nonsence from your side. I LEAVE YOU HERE GUYS WITH YOUR NONUNDESTANDING just i do not want to waste my time on teaching of you.
I do not see answer to my question. Your access is very authoritative and I do not like it.Originally posted by kt315 View Postok. i see you are very active in the field of the shielding matter. give me a link on your album with pics of the shielding.
then i will give mine link in exchange. i must see your awesome level.
You just changing topic and do not want to admit, that eddy current is in every... I will not write it again. But what I wanted to say is fact, that it will be there no matter if it somehow affect detection or not. So you are using word nonsense wrong.
I am shielding with graphite, aluminium foil and copper self adhesive tape. I do not have album, but if you wish, I will make it for you.
Eddy current appear in any conductive material --- i ask you again - WHAT relation it has to SHIELDING OF COIL? WHAT gives TO YOU the knowledge about Eddy currents' existing in theOriginally posted by Hyena View PostProbably you do not must think about eddy current in your graphite shielding to gain more depth and gold or whatever you seek for. You just can not say it is not there. Maybe we understand word Target differently. As I said earlier - Eddy current appear in any conductive material, which is in changing electromagnetic field. For me it means, that eddy current will appear in target, shield (aluminium or copper) and stem (aluminium from 50cm far from coil and more). No caps-lock nor bold font will change it. Its there...
coil shield? I reminder you again - we protect a coil from ESFI. JUST FROM ESFI!
Probably you do not must think about eddy current in your graphite shielding to gain more depth and gold or whatever you seek for. You just can not say it is not there. Maybe we understand word Target differently. As I said earlier - Eddy current appear in any conductive material, which is in changing electromagnetic field. For me it means, that eddy current will appear in target, shield (aluminium or copper) and stem (aluminium from 50cm far from coil and more). No caps-lock nor bold font will change it. Its there...Originally posted by kt315 View Posti ask you AGAIN. why i must think about Eddy currents in my coil graphite layer?? FOR WHAT? is that give me the knowledge about MORE DEPTH and MORE GREAT SENS TO THE GOLD?
FOR WHAT?????? what RELATION has Eddy currents to chield of coil protecting from ElectroStatic Field Influence (ESFI)???
Eddy currents appear IN TARGET and JUST ONLY in target.
Best wishes
