Originally posted by green
300mm x 25 turns = 458uH
400mm x 25 turns = 651uH
500mm x 25 turns = 853uH
Or if you keep the same inductance you have to reduce the amount of turns, like 400mm x 14 turns =268uH
14 turns x 1 Amp = 14 amp turns for a coil area of about 2000 cm square 14/2000 = about 0.007 ampere turns per cm square
25 turns x 1 Amp = 25 amp turns for a coil area of about 315 cm square = 25/315 = about 0.079 ampere turns per cm square
Now, with a certain di/dt (Rate of current change), and let's say an incidence of 0.02 ampere turns per surface of the target, the target having a surface of 5cm square, you can just detect this target. With a similar calculation you should be able to find what coil will give the best depth for that target.
Assuming the target in similar ground and with similar conductivity and similar thickness etc.
