Best coil design for surf PI
doing from fiberboard, take two nails and lath, cut by them. hammer nails in wood lath on one radius size, cut,
do same with another radius size. you get the ring.
then cut slots.
check the word i give a pic
There is no PCB for the basket coil. It is a cut frame. It is all explained in the link that I posted for you above....Originally posted by bklein View PostI mean the coil pcb...
Cheers
Here is a kit from the US, obviously not the same Long Board layout.Originally posted by bklein View PostAnyone sell pcb’s for this (in US)?
https://www.ebay.com/c/1878035697
You might be better off just getting a PCB from Silverdog.
This is the link that you need if you want to get directly to the Basket Coil:
http://www.metdet.ru/Sensor_K1.htm
Pleasure
good but not had actual in modern time. we mean FASTEST BACKET coil.Originally posted by surfdetector View PostIf you have not already done so, you should give this article by BBsailor a thorough read. It contains virtually everything you need to know concerning making a simple mono-coil.
https://www.geotech1.com/pages/metde...s/FastCoil.pdf
yes, new matter for you. unknown for you. sometimes DUAL FIELD BASKET coil.
https://www.geotech1.com/forums/show...l-for-baracuda
If you have not already done so, you should give this article by BBsailor a thorough read. It contains virtually everything you need to know concerning making a simple mono-coil.Originally posted by bishop_slayer View PostHi, I am planning to build a mono coil for a surf PI that has a diameter of around 10 inches. Are there any key factors that influence the depth? I am aiming for a coil inductance of around 400uH. Should I try and maximise or minimise the coil resistance? i.e. should I use thin or thick enamelled wire? What about the winding capacitance? Is this a big deal?
