Cylinder Coils?
  • Nova
    Ok Tinkerer, lets hope were still around to see this come to fruition, the Globalists seem hellbent on getting WW3 going, so for the moment it's wait and see!!
  • Tinkerer
    Originally posted by Nova View Post
    Thanks Tinkerer for your contribution to this thread, i will have to look into this platform, sounds very interesting.
    You might be right Carl about this large coil, the size of the object is maybe just a fraction too small to be picked up, i would challenge you on the GPZ being the deepest, as many have done tests and i recall someone did a test on a 10 oz nugget and it was the SD2200d that got it the deepest, maybe it was just on this shaped nugget that the 7000 couldn't hit, but on average if we were to test 10 different shaped nugget of equal weight maybe the 7 would win on 70% of them, Testing, testing and testing, i think we could do with a clone each, to do the testing for us LOL, there just isn't enough time to do it all damn!!!!
    So Carl, this AMX project, is there a future prospect of a detector coming to market by yourself using this new platform or is this like an "open" project for users to make themselves, mostly those on this forum?, if that's the case that will exclude a lot of us, who don't have electronics knowledge, can you tell me the direction you think this platform will go?
    I have often heard that the SD2200d was the deepest detector for large nuggets. So I suggest we use the specifications of the SD2200 for comparison.
    The SD2200 is a traditional Pi platform and is therefore limited to around 300uH coil inductance. about 300uH is the "brick wall" limit of the traditional PI.
    If you increase the inductance, you increase the delay to the first sample.
    This brick wall limit means that you have to use fewer and fewer turns of wire as you increase the diameter of the coils.
    The depth of detection is directly related to the diameter of the coil.
    Since on the traditional PI you can not increase the number of turns, you increase the current Amps. This makes a stronger field, but entails many other problems.
    The AMX platform has demolished several of the "brick wall" limits. It is closer related to the GPZ 7000, but not the same. I would say it is the most modern or advanced PI platform in the making.
  • Tinkerer
    This is normal, and any size coil will do this if the target is small enough relative to the coil. Prospectors commonly use coil-edge detection on small bits or to pinpoint. The problem is that the coil is just too large to efficiently detect the target's field, most of the target field is canceled by reverse-field effects. One solution is to place a much smaller RX coil concentrically. Tesoro did this on their VLF coils.
    Of the detectors I've tried, the GPZ wins hands-down on detecting big chunks deeper. Part of that is the big stock coil, but a bigger part is the CCPI operation. AMX also uses CCPI. As Tinkerer says, there is much to explore here. I would like to see an 18-inch concentric with a 4-6 inch RX.
    AMX Project
    I could make an 18" concentric, Induction Balanced coil for the AMX. I also have a TX to run it on.
    We can use this coil as an example to walk through the design and build process.
    As this coil is designed for the AMX platform, I suggest we discuss this coil build on the AMX Coil thread.
  • Nova
    I forgot to mention, this large coil can hit the bottom of a coke can at around 4ft in an air test, so it is "working", i probably should look at this coil as being the ideal coil for chasing those large slugs at depth, as it won't signal on bullets or other similar sized objects buried at the 5-12inch mark, yep, i've just convinced myself to do proper testing, like this you are always wondering and never sure, test and surety will follow!!!!! - an old Chinese proverb by a not so Chinese Nova!!!
  • Nova
  • Carl-NC
    And large coils, i have a 1metre coil that someone made for me, i made the housing for it, i used it in Victoria for a couple of hours, didn't find anything with it, but i know that it won't pick up 10 cents in the middle of the coil (Australian 10 cents is about the size of large marble, it is sensitive to small ****e close to the windings but won't hit this 10cents in the middle.
    AMX Project
  • Tinkerer
    Tinkerer, absolutely, i would be really interested in the whole process, of course to simplify it, a large mono coil for a Minelab would be the go, like i said i have a large coil but i have seen a vid of someone who had built a 1metre mono and that coil could easily pick up this 10c size in the middle and at about 2ft height, so i would say that my coil is not made right.
    AMX?, what the hell is that if you don't mind me asking, has this design/platform got the potential for large increases in depth?
    The Minelab coils have quite tight specs. There is not a whole lot that can be improved within the specs. Woody (detector mods) has probably experimented every which way. I can do no better and don't have a Minelab to compare with.
    AMX is a very advanced platform in the making. Look for the AMX project on this forum. Many of the usual limits of traditional PI have been overcome. There is great potential for very high sensitivity and extraordinary depth.
  • Nova
  • Tinkerer
    Tinkerer, you must of missed my previous post where i said "1oz+ chunks of gold at 3-5ft deep". Yes, i have dug no less than 4 holes at 3ft deep for junk in very hard goldfields ground, if i was healthy that would be nothing for me, but i have lung disease, just one hole like this in the day and my day ends after that, i am f.....
    Fly****e doesn't interest me, but sometimes when your chasing the bigger bits, it can go days to weeks without finding anything, so occasionally a smaller piece would be good to find.
    I am a bit lazy to test it properly, but i'm going to have to do it to see if this thing was made properly, i will have to make up a palm size lead target and bury it at the 4ft mark in the side of a creek and then compare to the smaller coils, to really find out if this thing will do what i want, maybe it's all i need to do the job?, and it weighs about 3.4kg , i use an army style harness, but it still gets heavy after a couple of hours, but its fun believing you my walk over a very deep chunk!!!!!
    Hi Nova
    what you describe, sounds like a lack of magnetic flux density at the center of the coil.
    If very small gold is detected on the rim of the coil, we can assume that the RX is fine. but the TX cold be beefed up. If it is a traditional PI platform, it is probably already running at its design limit.
    Every now and then, we get people asking on the forum for extra deep detectors. So maybe we should design a few extra deep coils and show the whole process of doing it here.
    Is anybody interested?
    There are several factors that need to be considered and compromises to be made:
    • Ergonomics - weight, shape, how do you carry it, does it fit into a car
    • Power, battery consumption, battery weight
    • Cable
    • Cost, cost of wire, overall cost
    • The coil design has to fit the whole detector platform.
    There are numerous third-party coils for Minelab detectors. Ample choice. I am not interested to compete there.
    the AMX platform is an advanced platform that has limitations that lie far beyond the traditional PI platforms.
    Just one example:
    Traditional PI TX coils are limited at about 300uH inductance.
    The AMX TX coil limits have not even been explored yet. However, I have made many coils for it with an inductance of around 4000uH and yet a first sample delay of under 5us.
  • Nova
  • Tinkerer
    Tinkerer,
    I agree with your observation about building your own metal detector. However, I have one additional point to add to your observation. Manufactured coils need to be made quickly, consistently, and efficiently. Home made coils are not bound by these things. When I started to wind many coils for my fastcoil.pdf paper, I observed a wide range of performance differences based on these variables.
    1. MOSFET coil driver capacitance.
    2. Coax capacitance that connects the coil to the detector control box.
    3. Coil capacitance based on coil wire insulation thickness and insulation type with Teflon being better than PVC for less capacitance.
    4. Coil shielding effect on coil capacitance with solid shields adding more capacitance than a fine mesh shield such as Scotch24.
    5. Shielding technique of putting the wire mesh on the coil like this:
    A. The letter o is the wire bundle size that is 5x the coil wire OD for a 19 turn coil.
    B. The letter U is the wire mesh shield that wraps around the cross section of the coil wire bundle.
    C. The upper part of the wire mesh is cut wide enough not to make conductive contact or insulated by placing tape on the overlapping part.
    I set up my O scope to measure all my coils self resonance and discovered that any coil building technique that resulted in less coil seen capacitance allowed me to use a higher damping resistor value which resulted in a faster mono coil shift from TX to RX.
    I discovered that making the coils wrapped around 16 cup hooks allowed me to hand apply a spiral wrap to secure the coil wire as well as add a spacer to the shield from the coil wire bundle. This technique is labor intensive and would not be a good technique for mass producing detector coils.
    Making coils for specific targets with a known time constant allows using coil making techniques to optimize the coil diameter and delay for that target. However, the treasure hunting environment may alter the design requiring making tradeoffs to maintain the best coil performance.
    Building good detector coils is an educational process that folks like Tinkerer share with geotech1 members.
    Thanks for your insight and shared knowledge!
    Joseph J. Rogowski
    Thank you for your feedback bbsailor.
    There is always a lot to learn from your posts.
    Everybody should read your article about coil building before attempting to build a coil.
  • Tinkerer
    Tinkerer, yes i understand that part, i have another hobby where that same drive has made me close to 40k over the years , it's a challenge that not many people in the world that i'm aware of would care to take up, but the joy is beating it and winning in the process.
    Speaking about electronics, there are now 36v batteries available for electric chainsaws and other equipment, could these batteries be adapted to work on Minelab machines, i understand that some of the electronics would need to be redesigned or perhaps just upgraded. Current Minelab's work on around 8v, 36v is 4.5 times as much power, if it is extremely hard to get any real depth out of building your own coils, surely you could get this extra 4-6 inches by increasing the power, and screw the regulations, who is going to know that your using a much more powerful machine?, i am asking you and anyone else that would know the answer to this question, can it be done? (and i'm not asking anyone to do it for me, just a general question?).
    The limitation is not the battery voltage or the TX voltage. We can make a very powerful TX pulse with less than 4V TX voltage.
    Limits exist, but there are many, many possibilities that are still unexplored, within the limits.
    Limit 1: The Flyback voltage. Mosfets with 1700V rating are easy to find.
    Limit 2: The stronger the TX pulse, the stronger is also the ground response.
    Limit 3: Depth, how deep do you want to dig? How many holes to 1 meter depth have you dug in your life? Tough job.
    Limit 4: what is the use of detecting specks of gold that are so small you can not see them?
    Limit 5: Large diameter coils reach deep. Large coils are also heavy and cumbersome to carry.
    You keep talking about 4 to 6 inches more depth.
    For what target?
    In which environment?
  • Nova
  • bbsailor
    If you look at it like that, I say: Just buy a Minelab detector and use a Minelab coil.
    Why?
    For some of us it is different. We enjoy tinkering with electronics. Usually it starts like that:
    Phase 1:
    We assemble a kit or repair a simple fault on a detector. It works. That makes us feel good. After a few like this, it becomes routine, kind of boring.
    Phase 2:
    We try to build a whole detector from a schematic. It is a challenge. When we get it working, we feel joy and satisfaction.
    Phase 3:
    We design our own detector and build it. After many trials and immense difficulties, vast amount of work and tribulations, we got it working. It does what we wanted. We find the first nugget or coin or unique relic with our own creation. Now we burst of joy. We feel on top of the world. The satisfaction is profound. We feel accomplished, alive. There are no more limits. The elation is such, that we feel that life is so good that it could not get any better.
    Is that the end of it? Not by a long way. It is just the beginning. The real life is only starting.
    Tinkerer,
    Joseph J. Rogowski
  • Tinkerer
Name:	Self-capacitance measurement.jpg
    Originally posted by Eddy71 View Post
    https://coil32.net/online-calculators.html
    Best selection of inductor calculators
    Thank you Eddy71, excellent link.
