Surf pi coil ?????
  • godzirra
    Originally posted by DigginOlz View Post
    Sir, you are a legend - and I now have a new site to haunt If Razorback comes through I will be back to post an update for anyone else who is building the same kit. Many thanks TH'r !
    did razorback ever come through? if so what was the coil and how well does the coil work for you
  • kt315
    this is conversion AWG in mm, although in russian, but clear.
  • chemelec
    Originally posted by Dixix View Post
    Interesting! How big is the diameter of the wire? 0.5 mm?
    I used a 28 AWG wire.
  • Dixix
    This Ferrite Rod Might be of Interest to some People here.
    Winding 25 Turns on this Ferrite Rod Gives an Inductance of aproximately 250uH
    (Or 40 Turns - 400uH, Etc.)
    On my Prototype of the Surf PI, I can detect a 1/2 Gram Gold Nugget at about 1 1/2 inch.
    A 1/8 Gram gold Nugget at about 3/8 inch.
    Or my Gold Ring at about 5 Inches.
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G19561
  • chemelec
  • 6666
    Ok thanks.
  • TH'r
    As requested, they used a TDI type plug wired in the TDI configurtation. I think not a problem for them, they specalize in TDI aftermarket coils.
  • 6666
    TH'r
    what type of connector did they put on that RG8 ?
  • TH'r
    If you want to optimize your coil for finding small gold I'd avoid the use of RG-8 or RG-58 as both have about 26pf of capacitance per foot and capacitance is the enemy of coil speed. RG-62U has 13.5 pf of capacitance per foot and there are other options such as a twisted pair with thick PTFE aka Teflon insulation that can be better still. I would be interested to see what feed line Razorback is using.
    Good Luck!
    Dan
    The cable on the coil Razorback made for me is marked RG 8X
  • Geo
    hello geo
    i dont believe that a cable is destroyed by the water pressure
    Hi.
    Before long time i tried a "fat" microphone cable at 4..5 m depth in the water and it shorting.
    RG58 is more resistant than the microphone cable, but i want to be sure before i"ll try it at 25+ m depth.
  • bernte_one
    hello geo
  • Geo
    Hello.
    I want to make a coil for Surf_PI for underwater detecting.
    It must work at 25..30 m depth (2.5 .. 3 atm pressure). I am not sure if RG-58 will work perfect at this depth or the pressure will destroy it.
    Does anyone has the experience???
  • baum7154
    Good Luck!
    Dan
  • DigginOlz
  • TH'r
    Razorback Coils made me a very nice 5 1/2" custom coil for my modified Surf Pi Pro. Check with them, they might save you much trouble.
