You can put the damping R in the coil, but then every coil has to have the R, as opposed to just the detector.
The cable does have capacitance (or, more properly, a distributed RLC) and placing the R in the coil may result in some minor ringing in the signal that still requires a small amount of additional damping R in the detector. I don't recall this to be the case way back when I tried the damping R in the coil, but I wasn't looking at an aggressively fast coil and this may be a factor.
In short, there is no advantage (I can think of) to putting the R in the coil, and some minor disadvantages.
- Carl
Why is the damping resistor on the board?
OR INSIDE CLEVIS TUBE
See this:Originally posted by AdrianM View PostAs opposed to..? Is there a way to put the front-end on the coil without upsetting its behaviour?
Hi bklein,Originally posted by bklein View PostWhy is the PI damping resistor placed on the board and not at the coil?
you can not eliminate the coil leads capacitance, if you place the damping resistor at the coil. The coil leads form an additional capacitance, which is connected parallel to the coil. This connection is typically a low impedance path. Yes, there is also additional inductivity on the coil leads, which we won't take it into account.
From the point of capacitance, it doesn't matter, where you put the damping resistor.
But from other facts, it is better to place the damping resistor on the controller board:
1. Heat generation can be dissipated better (we do not want heat in the coil)
2. Required wattage and voltage of the damping resistor takes a large space (could cause response from the damping resistors)
If you want four coils for different Jobs, Are you going to build a Front end for each one?
Sounds a bit Ruff to me.
Last I heard of , You need a cable to connect the coil to the Circuit.
The Cable has a C value to it.
If you want, you can put the front end of the circuit in with the coil but that makes problems of it's own.
Be the First! Be the Best. Hit it and show us how much better it is.
Why is a cable connected to a "fast" coil? This makes the network to operate as "slow" coil and decreases resistance of damping resistor for critical damping.Originally posted by bklein View PostWhy is the PI damping resistor placed on the board and not at the coil?
Originally posted by homefire View PostTop end away from the coil is best because it takes care of the Capacitance of the Connecting Cable as well.
is it true??? I dont think so...
Because!
LOL! I think it was BB Sailer that suggested putting part of the required R on the board and using a Resistor in the Coil connector to the box to match and bal the coils .
That way any of the coils you build would be best matched with out board surgery.
Why is the PI damping resistor placed on the board and not at the coil?Tags: None
