Very high resistence
  • ttu
    Thanks Esteban!
    I have downloaded that suggested patent. I need time to deep inside to understand that.
  • Esteban
    Originally posted by ttu View Post
    Hi everybody,
    I just wonder, is it possible adjust resistance of that transistor network?
    Let say instead 100G just 1G.
    Regards.
    See in Google patents # 5760450 Semiconductor resistor using back-to-back zener diodes
  • ttu
    Hi everybody,
    Regards.
  • Fred
    yes, indeed...
    but I think Esteban like make stuff with his own hands than sending money to Farnell or other gringos...
    Kind regards,
    Max
    I respect that.A ggod way to learn and stay independent
    And he also post his finds for others to learn
  • Max
    Possible(s) origin of word gringo.
    http://ask.yahoo.com/20000821.html
    always refers to gringos and gringolandia!
    At the end... i'm sure Esteban will made his own hi-value resistors and saludos a todos los gringos!
    Kind regards,
    Max
  • Esteban
    yes, indeed...
    Kind regards,
    Max
    The search engine that helps you find exactly what you're looking for. Find the most relevant information, video, images, and answers from all across the Web.
  • Max
    Originally posted by o.mag View Post
    HI
    2x 50 G ohms =100 G ohms
    olivier
    http://fr.farnell.com/jsp/search/pro...sp?SKU=1174530
    yes, indeed...
    Kind regards,
    Max
  • o.mag
    HI
    olivier
  • Fred
    Do you think that only I think in such things for use in ion chambers or similar?
    Yes, i do
  • Esteban
    Hmmm... I don't know... simply why the need of such hi-value-resistors if do not have an application for them !?
    Just another puzzle I think...
    As I see, you are a phanatic of puzzles...!!!
  • Max
    Maybe is a curiosity the connection of the both transistor as very high value resistor. I post only for this. Do you think that only I think in such things for use in ion chambers or similar?
  • Esteban
    Just, only 22Mohm ???
    What place is that !?
    Seems impossible Esteban... do not find e.g. 39Mohm, or 68Mohm there ???
    Lets go back at the issue of large resistor...
    so, are you doing ULF receiver maybe ? Shumann resonance things ?
    Cause the list of applications for such hi-value-resistors is about short...
    Kind regards,
    Max
  • Max
    Who knows... maybe is interesting. The most high value commercial resistor I can find here is 22 M. No, I'm not making homemade ion chambers!
    Kind regards,
    Max
  • Esteban
    Are you making homemade ion chambers ?
    That hi-value-resistors... seems have few applications...
    btw, it works pretty good for that things...
    Kind regards,
    Max
  • Fred
    Are you making homemade ion chambers ?Max
    Exactly!
    Probably from the link i found some day, the problem is the gigantic value resistors.They are rare and expensive
    I don“t know if this transistor thing work, but it is interesting.
