Time Domain ElectroMagnetic (TDEM) R&D project
  • Geophyz
    Hi Willy,
    this project is very interesting. If I understand the thread correctly you are interested in the differential TDEM as proposed in the SERDP funded work of Foley. I would like to also bring you attention to the work of French researchers who have built a machine with multiple time gate and exploited the viscosity effects on a man portable slingram TDEM for archaeological survey.
    "Thiesson, J., Tabbagh, A. and Flageul, S.,
    2007. TDEM magnetic viscosity prospecting using slingram coil configuration. Near Surface Geophysics. 5-6: 363-374."
  • Willy Bayot
    TDEM project update
    Just a small update.
    I have found an active partner on this R&D project. Together, we have made a number of LTSPICE simulations to check the validity of our design and timings.
    We have now setup a first table-top prototype of the TDEM system delivering good-looking signals and decay curves with reduced voltage and currents.
    The timing generator, signal processing and data storage firmware (running on an ARM LPC2148 from NXP) is ready to be tested on a prototyping board
    See the two pictures attached.
    Willy
Name:	Coil and board_06-09-2014.jpg
Name:	TX_Decay curve_A and B.jpg
  • Orbit
    Share
    the human eye the number of small parts if our brains analyzed image only partally eye and before that
    it was divided into many parts they would see only a small part of the picture
    in our visual field !
  • Orbit
    poenata more channel receiving finally outputs channel after gain should not be added together but each of them are shown be displayed on the LCD or in software which works by each channel or final outcome divided into at least four for example, up to 6 or more sequences this approach allows that objects are actually visible very very It can be seen form size etc.sorry If not reasonably this is due to ....
  • Aziz
    Please write in English.
    Good try. If I could.. *LOL*
    No, I just have "cracked" the encoded message.
    ^sif
  • Qiaozhi
    broj 1 imamo primarni kalem u njegovom sredistu je broj 2 sekundarni kalem koji ignorise magnetno polje primarnog kalema primarni kalem je prijemni kalem magnetometra itd da ne budem dosadan decimalama no poenta je visekanalni prijem bez toga nista od ovoga gore
    http://www.unit-conversion.info/text...adecimal/#data
  • Aziz
    62 72 6F 6A 20 31 20 69 6D 61 6D 6F 20 70 72 69 6D 61 72 6E 69 20 6B 61 6C 65 6D 20 75 20 6E 6A 65 67 6F 76 6F 6D 20 73 72 65 64 69 73 74 75 20 6A 65 20 20 62 72 6F 6A 20 32 20 73 65 6B 75 6E 64 61 72 6E 69 20 6B 61 6C 65 6D 20 6B 6F 6A 69 20 69 67 6E 6F 72 69 73 65 20 6D 61 67 6E 65 74 6E 6F 20 70 6F 6C 6A 65 20 70 72 69 6D 61 72 6E 6F 67 20 6B 61 6C 65 6D 61 20 70 72 69 6D 61 72 6E 69 20 6B 61 6C 65 6D 20 6A 65 20 70 72 69 6A 65 6D 6E 69 20 6B 61 6C 65 6D 20 6D 61 67 6E 65 74 6F 6D 65 74 72 61 20 69 74 64 20 64 61 20 6E 65 20 62 75 64 65 6D 20 64 6F 73 61 64 61 6E 20 64 65 63 69 6D 61 6C 61 6D 61 20 6E 6F 20 70 6F 65 6E 74 61 20 6A 65 20 76 69 73 65 6B 61 6E 61 6C 6E 69 20 70 72 69 6A 65 6D 20 62 65 7A 20 74 6F 67 61 20 6E 69 73 74 61 20 6F 64 20 6F 76 6F 67 61 20 67 6F 72 65
    to je to !
  • Orbit
    to je to !
  • Willy Bayot
    This is the link to one interesting thesis from Canada (only for those who can read French)
    Each bipolar pulse has a peak current of 700 Amp, a width of 486µsec and a pulse period of 16.6 msec to make a full period of 33.3 msec or 30 Hz. This is set for the regions where the power lines are at 60 Hz. In Europe, the pulse rate would be 25 Hz. By subtracting the decay voltages of a negative pulse from the previous positive pulse, the AC Power line effects are minimized.
    Although it is not explicitly defined in the document, I think the switching was made by a H-bridge of SCR's and a resonant circuit with a low-ESR capacitor tuned to set this pulse width.
    By the way, I am happy to see that the discussion machine has started ticking
    Willy
  • Willy Bayot
    Originally posted by Doug2 View Post
    A US patented TDEM system using 1/2 sine pulses
    Abstract
    In a time domain electromagnetic mapping technique of the type using transmitter pulses of half-sinusoidal waveform, with the half sinusoids being segments of a sinusoidal waveform having a frequency and corresponding to a resonant frequency of the transmitter coil, an improved current fall time at the end of each pulse is obtained by forming each transmitter pulse of plural immediately successive half sinusoids, the transmitter coil being tuned to an appropriately increased resonant frequency relative to the pulse repetition rate. Circuits for generating the improved pulse waveforms are disclosed.
    http://patentimages.storage.googleap.../US5796253.pdf
    Thanks.
    This old patent improves the standard single bipolar pulse generation by generating a series of successive pulses in order to make profit of the resonant system and enlarge the total width of the transmitting pulse in practice.
    Good idea!
    Note that it is already using Thyristor switches (SCR's) back in 1998
    Willy
  • Doug2
    This may be of interest as well
    Sub-Audio Magnetics
  • Doug2
    Originally posted by Willy Bayot View Post
    This is a document reporting about the design and tests of the prototype of a High power TDEM transmitter from Zonge with the funding of SERDP (dated 2003).
    Very clever use of SCR's to generate high power, narrow half-cosine pulses.
    I have looked on the web and I do not see this technology re-appearing anywhere in commercial systems but that could have been integrated in high-end instruments since then (2003).
    That will be the base of our first prototype as we were seduced by the principles.
    Willy
    Abstract
  • Willy Bayot
    Willy
  • Willy Bayot
    The resident trolls do not know that.
    Seek "UX1355 - FINAL REPORT" for inspiration of PI colliding with other methods
    Thank you for the info.
    I have made an overview on this document and it was quite informative.
    The environment where that study was made (Highly volcanic Hawaii Islands) is quite hostile to any type of magnetic survey (magnetometers go crazy there!!!). This represents the highest limit of difficulty to detect and discriminate targets from the ground effect.
    Here in Europe, we have rarely where UXO or Archaeological surveys have to be made in highly volcanic area.
    I want to pursue this differential process with a system which is hopefully more sophisticated, more flexible and powerful than the commercial EM61 or EM61-MK2 or even the EM63 that they used for conducting this study.
    The pulse rate, the pulse width and the pulse shape will be programmable as well as the field moment (A.sqm) using the most advanced modern power control devices existing now (MOSFET's, IGBT and SCR's) as well as high resolution ADC and fast DSP for sophisticated real-time filtering.
    My previous experience with my old digital PI project and our long lasting PPM project should give SOME advantages in this particular project but such a project can not be conducted alone, it requires many types of specialized wits and that's the reason why I have started this thread.
    Willy
  • Stefan
    Hi Willy,
    Thank you heaps for the time an energy you have displayed in providing insight to proton magnetometers. I was first introduced to proton magnetometer in 1981. Things have changed quite a lot since then. Your contribution to this forum has not been lost to some of the older generation. And again thank you very much for your contribution.
    Stefan
