PPM Fluid - what's best?
  • sevzirfo
    Originally posted by Willy Bayot View Post
    We are using isopropyl alcohol (isopropylene). This is the alcohol used to clean the white boards and the TV and PC Screens. It is widely available and cheap. We get very good signals from a polarization duration as small as 600msec which gives us a practical reading rate of one per second.
    I have also used the type of alcohol used to light the BBQ,thaty works almost as well. The problem with kerosene is that it is a mixture of undefined percentages of many simple components and that could give very different results from one sample to the other. It also smells very bad!!!
    Willy
    Today, I first tested isopropyl alcohol (isopropylene) in the proton magnetometer PPMA-3. Large improvements in the device compared to kerosene had not noticed. The device works fine when the polarization of 600 ms. Boundary of stable operation - 400 ms
  • Willy Bayot
    Originally posted by Boattow View Post
    Are we still talking about proton precession mags???
    No, this is the principle used in Overhauser systems but it also needs an RF excitation coil.
    Willy
  • Boattow
    Originally posted by bmoore View Post
    This I surmise helps couple the first RF pulse to the fluid which can then couple this energy to the magnetic domain for subsequent steps.
  • bmoore
    PPM fluid additives?
    Originally posted by ToyMaker View Post
    Have done some reading about ppm fluids. Seems most use
    water or an alcohol (ethanol, methanol).
    If I understand (please correct me as needed ) the ppm
    detects the protons in hydrogen as they spin out of
    alignment.
    So it seems that if the fluid has relatively more H it will
    generate a stronger signal. With this in mind, I spent a few
    minutes with wikipedia and a spreadsheet (OpenOfficeCalc)
    and found the following:
    Code:
    Substance      Formula       Density          %H
    Water        H2O               1.00          100.0
    Propane      C3H8              0.58           95.4
    Butane       C4H10             0.60           92.9
    Methanol     CH4O              0.79           88.4
    Ethanol      C2H6O             0.79           92.2
    Paraffin     C25H52            0.93          123.6
    Six "fluids" are listed with their formulas, densities, and % of
    H relative to water. I used molecular weights and grams/mol
    to derive the result.
    So, given the potential for a 20% gain in signal strength,
    has anyone used paraffin (wax) as a working fluid? If not,
    why? It seems that because it is "solid" at room temps
    it would be quite easy to work with.
    regards,
    thom
    I've read that the commercial manufactures have proprietary additives to make
    the fluids work better. One idea is to use distilled water and add an 'ion' additive.
    This I surmise helps couple the first RF pulse to the fluid which can then couple this energy to the magnetic domain for subsequent steps. I think this might be an
    acid of some kind.
  • Willy Bayot
    Some proton magnetometers used Kerosene. I believe it gives a faster proton alignment.
    Liquid paraffin may be similar.
    Tinkerer
    Willy
  • Qiaozhi
    Originally posted by Seden View Post
    Should read 2008 for the copyright. Tried saving my corrections three times and goes back to the happy face,oh well.
    Randy
    This happens when you type an "8" followed by ")". For example: (200
    The solution is to type ( 2008 ).
  • Seden
    Tried editing 3 times
    Randy
  • Seden
    Pure Liqued paraffin wax
    Here is true liquid 100% paraffin wax:
    http://www.instawares.com/soft-light-disposable-liquid.977076.0.7.htm?gclid=CPLD6fnOqKMCFQUbawodRC sH4A&s_kwcid=TC|20025|liquid paraffin wax||S|p|5839841289&
    Used for candles. Paraffin is what Purcell,Pound and Torrey used in their discovery of nuclear magnetic resonance,for which they won the Nobel Prize (from pg.12 of the book "Signals from the Subatomic World" by Stefan Hollos and Richard Hollos-200.
    Randy
  • Tinkerer
    Tinkerer
  • Seden
    PPM Fluid-what's best?
    Not a problem-liquid paraffin is also known as Mineral Oil.
    From Wikipedia:
    Mineral oil
    Main article: Mineral oil
    Liquid paraffin, or mineral oil, is a mixture of heavier alkanes, and has a number of names, including nujol, adepsine oil, alboline, glymol, medicinal paraffin, or saxol. It has a density of around 0.8 g/cm3.
    Randy
  • ToyMaker
    Aha... thank you. I knew there must be a reason.
    I'll keep reading and learning.
    regards,
    thom
  • msolc
    It MUST be liquid
    to work...
  • ToyMaker
    started a topic PPM Fluid - what's best?
    alignment.
    Code:
    regards,
    thom
