Whites Classic, II, III, ID, and IDX Modifications
three months ago I picked up a Classic SL/ID up at a local pawn shop, then found a Mr. Bill modded IDX-Pro on craigslist. So now I'm in the process of modding my Classic. I've done the pots, now need to do the resistors.
Mr.Bill
If I could trouble you with a quick question. Do these instructions pertain to the IDX PRO as well. Any difference at all.
Thanks.
you dont need the pictures really all the components are numbered on the board and the pictures you need are all ready on the the forum i did the mod with the numbers and then found the picturesOriginally posted by Dickie View PostAmazing, thank you Mr Bill!
Could anyone who has successfully completed this mod, post some pictures which mark all the relevant components (resistors, etc) which need changing over.
I know this is a big ask, but I would be sooooooooooo grateful!!
Thank you in advance
I'm no expert but from all my reading you can put resistors in series to make one value also, ie a 300 and a 75 to get the 375. I wasn't able to find the 375 at a company that had the other components I need and I didn't want to order from 7 different places.
What watt resistors are you guys using for the mods?
It's not a odd resistor value. There availble at most ele. supply places. Now with that said, it's not a critical value. Use something close, you'll be fine.
Bill
My apology for what seems to be me saying something twice in different way! I was trying to edit my first post and instead added it to as a second post! Sorry, noob!
I just finished the GEB/Threshold mods on my Classic III after doing the same to my IDX Pro. What a great mod! I can go almost as deep in Disc (minimal) as I can in All-Metal mode! Thank you Mr Bill! I have yet to make the SAT mod because I am thrown by the odd resistor value given for R32. Where do I get a 375k resistor, is that not an odd value?
My question is, re: R32, where do you find a 375k resistor? This is a custom resistance value not in the normal range of available resistors is it not?
It would enable your IDX to use lower amplitudes of signal, but eventually you'll hit the noise floor and your unit will behave a bit hectic.
so what ive done is ok but would it be better to put the 2.2 meg in would that make it more sensitive ?
