sovereign GT stability????????
  • muddy fingers
    Sean's post reminds me that I don't have a coil cover on my elite for that very reason. It has to be said though that there aren't any stones on the beach that I go to. Also, I sprayed the coil with silicone spray, as I heard that it helps prevent the salt water droplets "dancing" around on the coil which is another factor that causes instability.
  • Sean_Goddard
    Nothing so mundane!!
    If you use a coil cover (protector) remove it and empty the sand out at REGULAR intervals otherwise the sovereign will behave JUST as you describe,
  • kt315
    or the battery is on its way out
    measure the voltage of battery, before and after.
  • muddy fingers
    My elite seems O.K since I opened up the control box and cleaned the foil shielding that surrounds the circuit boards. I also cleaned the paper clip connection to that foil shielding. I thoroughly overhauled the meter which was full of sand and had corroded connections, despite it being sealed with tape.
  • Gumhorser
    Check battery power continuity. Loose or dirty contacts, bed solder, loose wire etcetera.
  • muddy fingers
    Hi Peter, I have exactly the same problem with my Sovereign Elite when down the beach. The machine is fine for a couple of hours then it gets so unstable I have no hope of hearing any tiny deep signals. I think it is a coil problem (Tornado 1000) though I'm not aware that I have got it wet. Last time on the beach I used my 15" coil (NEL) and didn't have any problems. I think I will have to attempt to look at the cable where it enters the coil. Strangely though, after about 15 minutes of this dreadful instability, the detector can settle down fine again which made me wonder if it was a problem with some sort of electrical interference source from a ship or mobile phone.
  • ivconic
    shorten... do you see the topic killer around you wishing to help so actively and hotty? I am not. WHERE IS PETER MORGAN ivconic. this is dilemma.
    Dilemma?!
    Maybe for you, not for me!
    Peter Morgan is closed in the jar.
    Here is the proof
  • kt315
  • ivconic
    Maybe shorten battery life?
    It is most logical explanation, because if it was about the coil; than it should manifest such behavior from a start and not after 2.5 hours
  • golfnut
    can u give more info pls. You said only after 2.5 hrs does it go when using on land after 2.5hrs - - - it could be battery,. When beach working do you get the coil wet in rock pools or surf? If Iyou go straight to the surf and dunk it - it should false then and there if it leaks.
  • Silver Dollar
    I had a similar problem with a different Mfg's coil. It was advertised as being waterproof so I
    used it underwater. Immediately afterward it started falsing a lot as water had gotten inside it.
    A hollow coil is lighter but a filled one is more waterproof....
  • Ron from Michigan
    David,at the price of new Tornado coils it may not hurt to use silicone around the cord nut at the coil.HH Ron
  • DavidB
    I have had similar problems with the Minelab coil. They leak a little and the static shield ground connection corodes apart.
  • Ron from Michigan
    Pete, I had the same problem with my 800 Tornado.I used it as a wader and some how the area where the cord goes into the coil leaked water.I sold the coil on Ebay as is, with the problem described, to help pay for a new coil.If I do any wading my current coil will have silicone around the cord nut on the coil.Good Luck HH Ron
  • peter morgan
    thanks mate
