  • geoscash1
    Originally posted by Aadu View Post
    Could it be a problem with the coil cable, I have all the coils built with speaker cable. It worked well for the Clone Pi AWR. The auto delay is 19, 390mh, 1.2 ohms.
    That is something youll have to try to work out. Do you have the capability to test your coil parameters (scope and test equip)?
    I will go check my docs and see what the coil parameters were, they are definitely specific to this detectors code and will set the coil alarm if not within the paraneters.
    Edit: some screen shots of adc parameters. Click image for larger version  Name:	Screenshot_20250721_165840_Samsung Notes.jpg Views:	0 Size:	154.9 KB ID:	439434 Click image for larger version  Name:	Screenshot_20250721_165444_Samsung Notes.jpg Views:	0 Size:	194.8 KB ID:	439433
  • Aadu
  • geoscash1
    Yes, sometimes positive numbers, sometimes negative. Runs very fast, does not depend on coil movement or settings
    Its most likely the calibration after start up. It has a bunch of initialization procedures and also some test functions.
    Do you have a reset or an "ok" or "enter" button? If so, power it off wait a minute or so and then turn it back on, let it do its initialize. If it still has the low tone multi beep then press and hold the ok/enter/reset button down for 5 seconds, keep the coil away from any metal and do it outside if possible and see if that works. This unit has a ton of functions and safety checks. In the code, the coil has to meet the requirements for min current and max current and min impedance and max impedance parameters too so it could be the coil causing the continuous beeps.
  • Aadu
  • geoscash1
    Thanks for the reply.
    I have tried different coils, changed mosfets, it doesn't help. The control numbers are fine, the depth is good, the discrimination works. It beeps three times every 5 seconds.
    So its possible it is the calibration alarm beeping. It also has a GPS "searching" as well. Does it show anything on the LCD display?
  • Aadu
  • geoscash1
    Hello, does anyone know what three beeps in a row mean, low pitch and continuous?
    It has quite a few different alarms. Battery low, coil error alarms for coil current and impedance low and high etc, gps & data log alarms, incorrect password etc and others. Looks to have low tones on coil errors.
  • Aadu
  • klaus3
    Hello everyone,
    I will try to wind a new coil with 380uH, if the error delay coil error comes from there. I can also try to reprogram the Atmega 328-PU, because it outputs 5volt at pin 16 for MOSFET bs170, but I don't think this is the error, rather the coil.
    Thanks in advance for the help​
  • pechkata
    Originally posted by algan View Post
    The coil must be made with a 0.50 or 0.45 wire, about 440 microhenries, and for an antenna size of 28 cm, this is about 23-24 turns. Make one like this. The problem is that it does not recognize the coil, which gives you an error about the coil.
    Let them find fault with the impulse.
  • algan
  • Detectorist#1
    Hello klaus3,
    If on the gate of BS170 haves +5V measured by digital voltmeter, most probably the microcontroller is not programmed properly.
  • MDfanatic
    What kind of PCB did you use? Homemade or manufactured? Have you checked ALL the traces to the components and made sure you have no cold-welds or unsoldered components anywhere?
  • klaus3
    Hello maybe someone knows advice,
    I have assembled the board and checked for possible errors without result with original parts always get error delay coil error displayed mosfet bs170 exchanged mos irf 840 also. try coil 170mm 20 windings .35mm wire diameter. At mosfet bs170 there is 5 volts at the gate and it thus controls through whereby mosfet irf 840 remains inactive.maybe someone has an idea I will wind a new coil and try again.
  • Aadu
    Thank you, that's clear.
