Vallon VMH3CS Mine Detector
  • Asgard
    Alexandre, This thread was specifically started to discuss the Vallon VMH series of mine detectors. Would it not be better to have a separate thread for your interesting, but non-related, material?
    Maybe but I'm not doing it now that it is written.
  • Ferric Toes
    Originally posted by Asgard View Post
    Metal enclosure is good for emi but no good for capacitance between mosfet / ground PCB / ground enclosure and metal heatsink.
    I recommend using a metal box and use a ceramic sink for the capacitance ! You'll see all your problems disappear! heat dissipation, emi, capacitance etc ...
    Alexandre
  • Ferric Toes
    I recalled that someone once told me FTP had a Vallon, so I poked around the dustbin and found it. It's a VMH3 without the CS, which apparently means Changeable Searchcoil, because that appears to be the only difference.
    A couple of years ago I picked up a copy of Janes Mines and Mine Clearance 2009 - 2010, at a swap meet. It has a section covering the various countries and the mine detectors they manufacture; Vallon being one for Germany. The VMH3 details are there and from the pictures it appears that the seach coil is not changeable, whereas the VMH3CS has this facility. On the following page is the VMH3S which has interchangeable coils as does the VMM3 on the next page. Whether CS really means changeable search coils, one can't be sure.
    One difference between the VMH3CS that I have is a push button for pinpointing Click image for larger version
ID:	345751 which is absent from the VMH3 picture in Jane's. The button with the crosshairs appears to speed up the 'retune' and sharpen the response. The other variable is that the firmware can be reprogrammed on all machines for different applications, which presumable would affect the small object response and range.
    I will check the 'air' range on a US Nickel and see what I get.
  • Asgard
    Originally posted by daverave View Post
    are you saying that a plastic enclosure is better than a metal type...if so what about external noise..surely a metal box is better for pcb screening ??
    Alexandre
  • Carl-NC
    That's great; it's too good a detector to be in with the trash. Do you have the full operating manual? I didn't get one with the detector but one should be arriving today. The field operation card I have is so basic it is almost useless. i.e. it doesn't adequately describe ground balancing or sensitivity adjustment. The pinpoint mode is not mentioned at all.
    One of the accessories is a 60cm diameter UXO coil, hence the CS. Also I believe there is a probe. I am going to have a go at making a 12in coil in a Whites shell, maybe dual field. That should make a very good coin, ring, and nugget detector both for the beach and inland. Garrett's ATX Extreme seems to have copied, almost exactly, many of the features of the Vallon.
    Yes, the unit is complete with the carry case, manual, field card, and firing pin OTP (operational test piece). This unit does not appear to be as good as yours. At max sensitivity it will detect the OTP (which tells me it's working within spec) but a US nickel is only 9-10" or so, and it won't detect my 1x foil standard at all. The TDI easily beats this.
    I think there is something out-of-whack on this unit. My foil standards are square 1"x1" pieces of foil layered in clear packing tape, with 1x being single layer, 2x has 2 layers, etc. I have 1x-8x continuous (helps identify target holes), plus 12, 16, 24, and 32x. The 1x is invisible. 2x has a negative response, that is, I get a signal as the target moves away from the coil. 3x has a weaker negative response, 4x a decent positive response and the rest look good from there. I'll try to play with it some more today.
    Yeah, the Recon/ATX looks a lot like the Vallon. I also have an ATX so maybe I'll try it as well.
  • daverave
    Everything is an area of ​​question!
    There are 3 problems at this level, the capacitance, the antenna effect for EMC, and thermal noise.
    Over the rds mosfet is high more it heats, so you have a MOSFET with low RDS but also low capacitance, etc ... (many parameters are important) It's very difficult to find it.
    We must dissipate this energy, dissipation pad of the mosfet has a surface and this surface will be close to the metal grounded card more capacitance will be great and will vary depending on many physical parameters. (Mass of the case, mass of the ground plane, with large flyback, no mercy!)
    We must therefore avoid any metal sink with a large surface parrallel this mass to avoid the capacitive effect).
    Unfortunately when a metal heatsink is good, this surface is large ! we must avoid to dispel with metal or electrical conductive materials!
    The antenna effect will be more reduced ... and the electrcal noise output from the preamp will be greatly improved. etc....
    The fact that Eric is not ground plane on the card at this level that the capacitance decreases relative to the sink, it is a chance, regarding the goldscan 5c case are plastic so it will also in the right direction, but using is kind of materials would have felt a huge noise difference after the preamp .... Best dissipation and almost no antenna effect!
    Alexandre
  • Ferric Toes
    I recalled that someone once told me FTP had a Vallon, so I poked around the dustbin and found it. It's a VMH3 without the CS, which apparently means Changeable Searchcoil, because that appears to be the only difference. The D-cells are dead so I have to go after work and buy some new ones. Then I'll play with it and see what it does.
  • Ferric Toes
    Hi Eric, good to see you back on the forum. Does the detector still detect the nugget with your amplifier connected? Do you have a scope trace of coil volts without your amplifier and does it detect the nugget with the scope hooked up?
    With my preamp across the coil the detector indicates a fault condition and does not respond. The unit seems to be very sensitive to small changes in the coil circuit e.g. the insertion of a 0.1 ohm resistor in the ground side of the coil at the connector end, shows as a fault and the receiver in the detector no longer functions. I can understand that for mine detection life depends on perfect functioning, but a change of 0.1 ohms in a 3 ohm circuit is a bit fine.
  • ivconic
    ...What we need of course is a schematic, but I doubt very much if that is possible.
    Slim chances. It is full DSP and all the processing is done in code in MCU.
    Schematics with just few parts will tell you nothing.
    You could open it and take a close photo (macro).
  • mickstv
    I wired up a front end amplifier, the same as I have used many times in the past, to give some front end gain. The standard input configuration is via a resistor and a couple of diodes back to back to clip TX pulse and flyback transients. What we see is a standard PI response waveform. Amplifier saturation to plus and minus rails, both 5V; amplifier recovery to flat baseline. Scope trace starts at TX switchoff.
    [ATTACH]36185[/ATTACH]
    A metal can is then placed on the coil and standard decay observed for both pulse polarities.
    [ATTACH]36186[/ATTACH]
    The scope sensitivity is increased and the above repeated.
    [ATTACH]36187[/ATTACH]
    As above with metal can.
    [ATTACH]36188[/ATTACH]
    What is puzzling is the glitch at 103uS on both polarities. Is this a gating glitch or just an unimportant artifact appearing across the coil? The amplifier recovery with this high inductance coil also seems much too late to detect, say, a 0.3gm nugget; which the Vallon unit does quite easily. O.K., is this a DSP trick where you can sample into the flyback recovery period? Then there is the ground cancelling, how can that be done? Over to the experts in the digital domain, as I am not one.
    Nothing changes in the above pictures if I switch to the ground cancelling position. What we need of course is a schematic, but I doubt very much if that is possible.
    I Eric, just wondering if you could post some pictures of the response to your ironstone target at 1v and 100mv scales.
    Mick
  • Qiaozhi
    How much gain did you have in your front-end amplifier?
    We found a similar situation recently with the Felezjoo design, where the front-end gain was 66.2dB, but it was still able to detect some very small targets. The opamp used was an LF357.
  • Carl-NC
    Presumably, the tilt is the remainder of the the normal L/R charge up time until switch off?
    Exactly.
  • Chet
    Hi Eric
    In an earlier post you stated that the pulse was running at 6v. This implies that something is occurring to raise the three D cells from 4.5v to 6v. Maybe the glitch at 103us is from a power boost circuit that is synchronized to not interfere with an early narrow sample gate for small objects. Or maybe it’s a power recovery capacitor that is being gated back into the power supply after the receive sample gate ends. The long battery life24-30hrs implies that there may be a power recovery circuit.
    Have a good day,
    Chet
  • green
  • Davor
    Perhaps there is some sort of front-end sampling/integration? If so, the "late" capacitor would introduce a glitch when switched on, due to the charge stored from a previous cycle. I have no idea what the schematic may reveal, but I'd do it that way. It is a way to get meaningful samples from deep into the flyback.
    Since there is no variation in the periods (iamb, staccato), Paltaglou is off the hook, and the only way to do GB is by early vs. late arithmetic.
    No need for EF in a bipolar system. Another bonus.
