Delta Pulse
  • mrmetal
    hi.my dp is not sensitive for GOLD.
    What do I do ?
  • kt315
    Maximus has a trouble with his turkish board.
  • pigeon
    hi
    thank you very much
  • kt315
    had some spare time and completed 2 dp pcb's the problem is one is working but acting strange when the object is getting closer to coil it gives normal stronger signal then when i dont move it just keep the object still the signal starts fading and dissapears then i have to move the object again to get a signal , coil is 30cm 5.3ohm
    that is a normal work of SAT. DP has advanced SAT but it is slowly acting. why slowly because DP is fit for no-motion (REAL no-motion) and big coil prospecting. if you want change SAT reaction so you have to change some values).
    the other pcb doesnt see the coil at all it turns on and i can set the pots to get constant oscillations but it acts the same with or without coil and its doesnt see metal objects nor does the power knob react at all and the voltage regulator is completelly cold tried changing voltage reg ,ic 's and checking all the components again its all ok cant find the problem. ???
    desolder IRF740, take o-scope and seach all timing. if all is OK then solder IRF back and observe output of LF357. you have to see clipped-at-top inverted 'delta pulse',
    very bottom of it.
    Anatloy
  • kt315
    congruts. you discovered a possibility of DP to find out the underground tunnels, caves and graves. it gives big advantage now for new generation of handymen,
    new fresh sea breath of DP.
    thinking this is still need in additional learning by deeper's owners deepground prospectors.
    Anatloy
  • pigeon
    hi all
    please help me
    thank you.
  • pigeon
    hi all
    I have a classic delta pulse that work well i am using a 2metre coil .the problem is that there is an old stoned tunnel.i scanned it with coil,its sound is increasing more and more for about 12metres them it decreases so much.do you think that sound is because of a metal or just that thr ground?
    Thank you
  • maximusdesmus
    thanks in advance
  • kt315
    for what you mean? do you hope to encrease the depth or can you not find out 12V battery anywhere around??
  • pigeon
    hi all
    I can use 24volts for delta pulse?
    thank you
    pigeon.
  • mschmahl
    Thank´s a lot KT315. So i can continue to build the dp.
  • kt315
    hello ms...l
    Hi kt315.
    Iґm building the Delta Pulse with your nice PCB. I have some questionґs.
    Why you have C12 with 47uf and not 100uF (see picture)? Is it critical?
    I did set what I did take first =) 10-25V caps will be OK here. not so critical... 47-100uF and more value caps...
    You have built it with standart R6/AA batteries and big caps nearby. What are the values? (see 2. picture) There are some other hidden parts? I will use also R6/AA batteries.
    in my case I used two 10000Uf 25V caps everyone.
    How critical is R23-R26 with 4,72k? can i use 4,70k or 4,75k also?
    yes. certainly. but you have to choose them in a couple - R23 with R24, R25 with R26. for example if one is 4,628 another is 4,630 that will be OK.
    How to tune R37?
    you will see. that is some kinda intuitive tuning. on a reaction at a target (big target and max reaction) the arrow of the microamperemeter has not to foul hard at right side of a scale ("throb"). leastwise there has not to be so big reloading of the uAmeter.
  • kt315
    in an especial folder at the DVD you may see a text and a diagram of Eric Foster ...\#miscellanea\Eric Foster_range_curves\.
    so you have to decrease a size of a coil to increase a depth on a nugget instead of the increasing like you are thinking
    a big size will give to you big depth. NOT. there is NOT un-linear dependence, there is some size that will be OPTIMAL for some size
    of the nugget.
    Re: Question on coils
    Posted by: Eric Foster
    Date: May 18, 2005
    Here are the curves I have used for many years. The range reaches a maximum when it is
    equal to the radius of the coil. Coils larger or smaller than this optimum will result
    in less range. To show how this works, along the bottom axis you see coil diameter,
    which is obviously 2 x the radius. So for an 11in coil, if we go up the vertical scale
    to A, we have 5.5in. Also note the diagonal line and the series of ever increasing
    semicircles. Everything to the left of this line shows increasing detection range up to
    the maximum where it intersects the line, then decreasing range to the right, where the
    semicircles are shown dashed.
    If a certain metal object is just detected at 5.5in with the 11in coil, then going
    larger in coil size will cause a reduction (going down the dashed side), and going
    smaller in coil size will have a similar effect. Initially, it won’t be much, i.e.
    going from an 11in to an 8in coil will only make 0.5in difference but below 4in
    diameter, the range will drop rapidly.
    Now, suppose with the 11in coil, you can detect an object at about 12.5in (B on the
    vertical scale. This indicates that the coil is not an optimum size for that particular
    object. If we carry on up the curve (direction of arrow) we can see that by using a
    20in coil, we could gain another 2.5in (C). The curve peaks at 15in with a 30in coil.
    But the extra inch gained hardly makes such an unwieldy coil worth while.
    Other factors come into play of course. The curves assume that the number of turns and
    the coil current is the same in all cases; which it isn’t necessarily. For the same
    inductance value, a smaller coil has more turns, which counteracts to some degree the
    loss in range. Also a smaller coil will pick up less electromagnetic noise, earth’s
    field noise and ground effect, which make for a smoother threshold.
    The end result is, that with a small nugget that can be detected at between 5 and 7in
    with the 11in coil, so that it is on the top part of the curve, an 8in coil may well
    give a similar range. That is not to say that smaller coils do not have other
    advantages. Small coils and probes are very useful in rocky areas or searching in
    undergrowth. They have less drag too for water hunting, and less pickup from
    mineralised soil or conductive sea water plus better signal separation on close or
    multiple objects.
    One other point regarding PI, is that the small object sensitivity is largely
    determined by the sample pulse delay. If an object is so small, or thin, or made of
    high grade stainless steel, such that all the signal has decayed before sampling takes
    place, it would not matter how small a coil you made, it would never be picked up.
    Eric.
Name:	range curves.jpg
  • mschmahl
    Hi kt315.
    I´m building the Delta Pulse with your nice PCB. I have some question´s.
    How to tune R37?
  • kt315
    Dean, a metal detector is reacting at big target, not on all massive of the gold nuggets you maybe waiting. that is hard fact that all targets being folded together do not pool in one volume, for a detector reacting. so DP will react only on big sample from all samples, because such working of eddy current in the metal target and a EMF reply of it in the coil.
    more theory on that in comments of Carl M. and in the book ITMD you may find.
    http://www.geotech1.com/forums/showt...ghlight=silver Cache Test is good example...
