Great job ivconic!
The second half of LM393 can be used to indicate the low voltage power supply.
Best regards,
GSL
Tesoro Cibola
With additional infos that i got recently; i made corrections in Cibola schematic and finally made it.
There are many differences between "original" one and the one i made.
The one i made now is working indeed decent.
So far i tested it ONLY in DISC mode and therefore i can't claim anything relating to All Metal mode and Nonmotion.
I get decent air distances for various items.
GEB is working just nice; rejects all minerals, ferrite etc...
Disc is working excellent!
Treshold is working, Sense is working... seems everything is on it's place.
I couldn't obtain some of "original" ic's so i made series of checks and tests and established most proper ic's for present conditions that i have now.
Funny thing, but TL061 is performing very well at RX front end!?
Much better than a pile of other types that i tested!
I intentioanlly wanted to avoid second 4053 and instead i will use ordinary mechanical switches, by now i only made wire jumpers so to settle it only in Disc mode.
Also i intentionally wanted to avoid use of CD4024 and instead i used simple VCO taken from White's Classic schematic.
Without additional buffering; 7660 will not synchronize directly via resistive coupling so i used most simple method: capacitive coupling!
What to say? This thing is working and it is working indeed very decent!
I have original Tesoro coil (for Tejon, Cibola and Vaquero) and all the checks i did with it.
Cheers!
I can get the tests only on weekends. I have not free time during the week
Hello GSLOriginally posted by GSL View PostI have not fully tested the board, GB has not been adjusted. Modes All Metal-discrimination work. It is too early to talk about sensitivity, but there is good sensitivity to gold and silver coins.
Best regards,
GSL
What about your tests, Did you get a good result?
Kind regards
Best regards,
GSL
Hi GSL,Originally posted by GSL View PostNot only looks working. The scheme really works.
The amplitude Tx = 25 V pp, pleasant sound.
Regards, GSL
Thank you for your work !
Have you fully test the board ? All-Metal, Disc ?
What is the detection range ?
Best regards,
Hugo
Blocking sites on the internet is almost a waste of time. You only have to find a list of free proxy servers, like this ->Originally posted by kt315 View PostUnfortunately, access to this particular item has been blocked due to legal restrictions in some countries. We are blocking your viewing in an effort to prevent restricted items from being displayed. Regrettably, in some cases, we may prevent users from accessing items that are not within the scope of said restrictions because of limitations of existing technology. Please accept our apologies for any inconvenience this may cause, and we hope you may find other items of interest on eBay.
Pick one, and enter the IP address in the manual proxy configuration field of your browser. Then you can surf anonymously and also view any blocked sites. Another way is to use a Web Proxy like "hidemyass" ->
hi Hugo, if the components are glued they easy get out desoldering. hot does its deal. I do not see difficulty. there is only maybe ceramic capacitors, you have to measure everyone, because they are often not marked.
take all files you see in the forum - fixed diagrams, LAY of SMD, LAY of through hole board etc.
be with this folk http://www.md4u.ru/viewtopic.php?f=2...9a17d&start=25
do not wait the wind from west. west is catched in a web of patents and copyright. one russian guy wrote that ebay has been closed for RU zine if anyone want to buy anything of hi-tech. he did want to buy ERBIUM LASER HEAD with MIRRORS FLASH LAMP CAVITY OPTICS ssy-1 yag neodymium but the items are closed in search for him.
Hello kt315,
The wind is blowing from Russia.
It's not so easy with a SMD board. Even harder if the components are glued to the board.really I fully desoldered King Cobra
But if we can, it's the best way to do.
Be sure, It's not a waste of time to try to understand how it works.
Do you think I'll find the DeLeon schematic on my road ?Christopher Kolumbus did try to discovery India, but open America. because he had not good detailed maps. that is the good example.
Wait and see.
Best regards,
Hugo
- Likes 1
hugo, wait the wind of change from east. I see these people they open Tejon and Cibola. really I fully desoldered King Cobra, all components were measured by my hands. this is why there is not mistake in my schematic althought Lahr's schematic has its a bunch. Ivconic is right - do not waste your time on very crude project. Christopher Kolumbus did try to discovery India, but open America. because he had not good detailed maps. that is the good example.
