Magnetometer MWB2.
Has anyone if anything looked at the pcb and schematic? One fet is not marked as well as the inductance of 100uh is nowhere on the pcb and the 4 resistors are marked as R? Here are the added components, I have not reviewed the schematic in detail!
Hello. Do you have the schematic and firmware for Fisher 34? Could you share them, please? Thank you.
Could you share the source code?Originally posted by Fisher View PostSorry for the long break. War. These are fuse bits in the Avreal programmer. https://real.kyiv.ua/avreal/
According to the description of this Avreal programmer, you can configure the fuse bits in another programmer.
c:\avreal\avreal32-1.29r1 -p1 +mega1284P -%% -o16000 -ab -5 -fJTAGEN=1,EESAVE=0,SUT=2,CKSEL=7,BLEV=1,BOOTRST=0, BLB1=1,BLB0=1,OCDEN=0,BOOTSZ=2,CKDIV8=1 -v -w
pause
pause How to display them in a modern program
If you open a lay6 file in the Sprint Layout program, then when you hover over an element, the name of that element will appear.Originally posted by j570 View PostGerber files does not contain element descriptions or outlines. The lay6 file contains element outlines, but it's unclear which element it is, for example, R5 or R8. There are no letter symbols. Do you have a drawing or file that would solve this problem?
pausesuitable for this
pause
