I can translate easy Ivconic.
Just ask!
No problems.I will be glad to help.
“S”- tone discriminate metal detector.
Guest repliedSasho how about your english?-Ivconic
Very bad.Sorry.
Sascho
"...Всички мои схеми са правени и работят много добре..."
This is true and i beleive. So far i made only Pulse IB and it is working just as Sasho claimed - very good keeping on mind that it is very simple device.
This 2 tone... is second from Sasho i decided to make and making is in progress. When finished i will post my report here.
It is shame that i dont read bulgarian very well so i can not understand all here. But i can understand very well when listening. Sasho how about your english? I have feeling that you could have much more to say here. Also i have feeling that we can learn much more from you here. Looking at your previoulsy posted works i see quite knowledge and pretty well understanding of metal detector principles. I admit that you know and understand much more this problematic than me so i would like to hear more from you. By this i dont mean to ask for more schematics, no not at all. I just want to see good written text (more texts) explaining in details some of your projects. For example this, last one 2 tone..
It would be great benefit for others you to explain schematic stage by stage in details. To explain every function of every part here. If compilated well, that text can present "Bible" for beginers and novices on this field and for sure great reminder for more experienced enthusiasts..
So why not doing that?
BTW do not pay attention on ocassional provocations. Empty minded and simple minded people usually do provoke from time to time... just dont pay any attention. The rest of us here do appreciate you and your work and we are ready to read and listen what you have to say.
Best regards!
Guest repliedдо Нико
Става въпрос за репликите за "the best vlf metaldetector schematic ".В един български форум бяха писали ,че това са схеми,които са съставени без да са правени и не стават за нищо.Това се пише явно от дилетанти.Всички мои схеми са правени и работят много добре.Все пак се занимавам професионално с електроника.Конструирането на детектори ми е хоби.Не произвеждам детектори.Винаги ги докарвам до ниво много добре работещ прототип.В тази схема генератора е от "Бичкомбер" и е преоразмерен за 8в. захранване и 9 кхц.честота.Генератора в допълнението за копланар е правен и работи с тази схема добре с 20в амплитуда.И в двата варианта при 8 в. захранване тока е около 10 ма. Няма нестабилност и изкривяване.В тази схема моя идея е усилвателя след фазовите детектори.Много е стабилен,защото по прав ток усилва 1.При промяна на входното напрежение усилването е 100 пъти.Едновременно с това е НЧ активен филтър и компресор на динамиката.Сигналът е с много добър център.Дискриминаторът е със запомяне на входния сигнал.На практика 4053 работят добре при сигнал с амплитуда до захранването-1В.Схемата се пуска лесно и работи много стабилно дори при мъгла и при бобини с голямо остатъчно напрежение .Трептящите кръгове са с лош качествен фактор.Това води до стабилност и много добро премахване на земния ефект.
Поздрави -Сашо
Guest repliedСАШО, КАКВО СТАВА?
КЪДЕ, КАКВО СЕ ПИШЕ? В ТОЗИ ФОРУМ НИЩО НЕ ВИЖДАМ. АЗ ПОЛЗВАМ СЪЩИЯ ГЕНЕРАТОР, НЕ ЗНАМ ОТ КЪДЕ СЪМ ГО ВЗЕЛ ПРЕДИ 10-12 ГОДИНИ, МОЖЕ И ПОВЕЧЕ ОТ ТОГАВА СЪМ СПРЕЛ С МД. ОБЩАТА СХЕМА НА МОЯ МД Е ПОЧТИ СЪЩАТА, ДЕТО ПОЛЗВАМ PLL 4528, НО ЗА ГЕНЕРАТОРА В ОСНОВНАТА ТИ СХЕМА Е КОРЕКТЕН, НО В ДОПЪЛНЕНИЕТО, НЯМА ДА РАБОТИ КОРЕКТНО, СИМУЛИРАМ СЪМ ГО В РЕАЛНА СХЕМА, ПОЛЗВАХ 14V И ИМА СЛЕДНИТЕ ПАРАМЕТРИ Ut=~45Vp-p;It=8-10 mA И РАБОТИ ДОБРЕ ПРИ С2=С6 И С8=С2*(2-4) /ОТ СХЕМАТА ЗА ОО, АЗ РАБОТЕХ НА ЧЕСТОТИ ОТ 14-17 kHz И С БАЗИСНИ РЕЗИСТОРИ ОКОЛО 1к, МОЙТЕ БЯХА САМО ОО ТИП ГЛАВИ, СИМУЛАЦИЯТА ТИ Е С ДРУГИ СТОЙНОСТИ ОТ ПОСОЧЕНИТЕ В СХЕМАТА, ТЯ ПОЧТИ ВИНАГИ ГЕНЕРИРА, НО С МНОГО ЛОШИ ПАРАМЕТРИ: НЕСТАБИЛНОСТ, ГОЛЯМА КОНСУМАЦИЯ И Т.Н.. ЗА ПОСЛЕДНО ЕДИН ВЪПРОС: КАКВО Е СПОРЕД Е ТЕБ ОПТИМАЛНОТО НАПРЕЖЕНИЕ U р-р ПРЕДИ КЛЮЧОВЕТЕ. ЖЕЛАЯ ТИ ВСИЧКО ДОБРО И УСПЕХ. НИКО
Guest repliedДо умните глави,които писаха глупости тук и в българските форуми-имате думата за джафкане и оплюване.Не ви се сърдя-толкова ви е мозъка в главите.Хората по света знаят ,че Джон Атанасов е изобретил компютъра.Но те не знаят,че много преди това българите са открили завистта и подлостта.
Сашо
Guest repliedTo Patrick
Minimal distance loudspeaker-coils is 60 cm. Coils are shielded.
Sascho
Thanks,Originally posted by tiktak View PostHi,
Patrick.
How are you?
Its nice that the schematic actualy works.But I see that your coils are not shielded.Later when you shield your coils and go field test you will notice big diferance.You will see.But its usefull.
Nice PCB I like it very much.Simple with all the switches wiring and labels.
the RX is shielded (aluminium tape) and now I will dress ...
Hi
Patrick.
How are you?
