Volksturm SM + GEB
  • mehdi
    I have not tried it. Might want to ask KT315 or try something like this:
    http://www.geotech1.com/forums/showthread.php?t=11150
    ok, thanks a lot my friend
  • dfbowers
    Originally posted by mehdi View Post
    Hi Don
    i would like to know if i can use my volksturm sm+GEB as a two-box?
    thanks in advance
    mehdi
  • mehdi
    Hi Don
    thanks in advance
    mehdi
  • taliesin
    Originally posted by taliesin View Post
    hi and,
    i just checked your pcb .the original schematic shows the tx q's driven from pin 12 of the 4013.on your pcb it's driven from pin 1 of the 4013.is this a mod or mistake ?
    my mistake i've just seen another schematic
  • taliesin
    Originally posted by and View Post
    ok
    here is the volkstrum + geb in proteus schematic and pcb, the part list, top (pdf), bot(pdf), included, can anyone to revise it is correct or not?, i replaced the kt8xx for the tip3x, and the kt315 for 2n2222 the pins are not the same, and i have a question... can i include a class a amplifier 10w in the tx coil to do more power more depth? and a mic booster in the rx? for 4ohm coil? anyone tried this? im crazy!
    ps. my english is weaker
    [edit]i forget to put the battery holes , you need to drill the holes for the battery [/edit]
    hi and,
  • dfbowers
    Hi
    one time with 75nf the sensitivity for 8cm ferrite rod reduced to about 5cm but sense reduced for coin to about 15cm.
    nulling is simple, because i can measure volt of pin1 lf353 but tuning is very hard, is there any test point to measure that tuning is in right way or not? or may be i must change the cap's often to get best sens to coin and less sens to ferrite?
    any idea is great help
    mehdi
    If no scope, it may be a little bit of trial and error. But, if tuned too far one way, you will get a negative response from ferrite, too far the other it will be positive, just right will be almost nothing. Now what you could really use is a "decade" box with a rotary switch and a bank of caps that can quickly switch them into place, say from 15 - 100 nF.
    You may be able to narrow it down quickly that way. Just and idea.
  • mehdi
    I suspect that you are not tuned to resonance. You must be able to reject ferrite or you will not be able to reject ground. Also, when you find resonance your depth will be even better!
    Hi
    mehdi
  • dfbowers
  • mehdi
    Hi dear Don
    thanks for your helps
    it work perfect now and can detect 1inch coin at 29-30cm and about 60-65cm for 12.5*16cm one side copper board, but it can not reject ferrite at all, and the sensitivity for ferrite is better than other metals! Is it good?
    my problem was poor coil; i make new one a few little than first.
    my null is good now( pin 1 of LF353 is about .4v) and for tuning cap i use 100nf for first time and i dont want to change it because the performance is good now.
    what cable i must use for coil connection?
    btw, volksturm sm+geb is excellent MD.
    thanks a lot dear Don to your help.
    all the best
    mehdi
  • stergeol
    ok
    hello in this pcb what is R2 R22 and C7???????
  • mehdi
    I do not think that exact coil parameters are important, as long as you are close. It sounds like you are just not tuned to resonance, or close to it. That would explain why you cannot reject ferrite.
    What you could try to do is add or remove tuning caps to your Rx coil for a maximum signal on pin 1 U1a while seeking a minimum while nulling. I usually get the null close and then start adjusting the tuning caps, then go back and null again.
    The tricky thing with trying to tune a squarewave it that you can hit a harmonic that gives you a peak in signal amplitude, but adjusting to the fundemental will give you the highest peak.
    Also, for initial tuning, I would suggest bypassing your op-amp that you are using for phase adjustment just to make sure that is not causing a problem as well.
    Anyway, everything would become obvious if you had a scope. If you are going to do many more projects it would be well worth the investment, even a cheap one
    Hope this helps!!
    Don
    Hi Don
    thanks for reply
    i think that my problem of can not reject ferrite is in critical adjustment of phase variable resistor, now i am going to use 10 off 1Kohm pot in series may be solve the problem.
    ok, i will do what you say and i will post the results after that.
    again, thanks a lot for your considerable helps.
    mehdi
  • dfbowers
    Hi Don
    after many trying, finaly i can not reject ferrite and my detection depth is poor yet.
    please let me know, what is your coil detail; TX and RX diameter details and etc.
    i think my problem is the poor coil!!
    all the best
    Hope this helps!!
    Don
  • mehdi
    Hi Don
    all the best
  • mehdi
    Yes, that is a little short. Detection distance should be at least twice that for a 1" coin.
    How "big" for a large item? For example, I just checked mine for a 10cm x 10cm copper PCB and detection range is about 60cm.
    Questions:
    Can you find the "threshold" (slight audio hum)?
    Where do you have your "sens" set to? I have mine fixed at 460K ohms.
    Can you reject ferrite??
    Don
    Hi Don
    yes i can find "threshold" but hardly, ((if you remember my video))
    my "sens" is fixed at about 480K ohms.
    no, i can not reject ferrite , but as i told, phase(geb) variable resistor adjustment is very hard and critical so i cant find true point but to night i will use two 5K variable resistor in series to easy adjustment. i will post here the result after change.
    again thanks a lot for your helps
    mehdi
  • dfbowers
    Hi and thanks Don
    my coils null is ok now , so please help me to fine tuning the coil, since it seem 14 cm for 1 inch coin is a little short distance! or not?!
    and any other info will be very great help.
    Don, what is maximum detection depth of your volksturm sm for 10'' coil? ( for big object)
    other thing; i am testing indoor (at home) so is it possible that my test was not correct?!
    with many thaks for your help
    mehdi
    Questions:
    Don
