My Pulse Oscillation detector project.
  • MikesMetal
    I unwound the coil former and pile wound a 22 cm diameter coil with 30 turns of the same speaker wire. Air tests showed it to be much better, detecting a gold ring at 20cms, a stainless steel watch with stainless strap at about 30cms and a pair of pliers at about 40cms. These tests were done in the 3rd position which seems to be the most sensitive. In the 1st position the ring is clearly detected at about 15cm. I will knock up some sort of support for it and check it on the ground.
    Cheers
    Mike
  • MikesMetal
    I built this from a kit I got from Teemo just over a year ago. I made a 25 turn Spidercoil O/D 22cm and 6cm I/D. I used 1mm speaker wire with a total O/D of 3cm. resistance was about 1 Ohm no idea about the inductance but it worked. Detection depth was very poor, about 5cms for a small gold ring and about 7cms for a 1 Euro coin. All this in free air. Yesterday I unwound the spidercoil and recovered the wire about 14 mtrs. Does anyone else agree with this poor performance? See attached plastic former that I used. Click image for larger version
ID:	429238 Click image for larger version
  • waltr
    Originally posted by h9361 View Post
    Hello
    Dear Walter.
    Is it possible to share me your hex file, PCB and part list?
    I did point to point wiring on a perf board, not PCB.
    The hex file is on Teemo's web site and in post #10.
    See post #26 for PIC data sheet.
    Source code in post #32.
    Firmware v1.26 in post #64
    I see I use v1.80 code and this doesn't seem to be posted.
    Teemos_metaldetector_hex.zip
    Teemos_firmware180.zip
  • h9361
    What does the signal from coil to PIC look like on an O'scope?
    It should match the scope pictures Teemo published on his web site.
    Hello
    Dear Walter.
  • gando
    i haven’t oscilloscope for misure or test.
    my coils work very well on Russian PI, Surf pi, clone pi avr, but on digiwood kit i have a very poor performance
  • waltr
    Originally posted by gando View Post
    i buied this kit. i try a different coil of 18cm (7 inches) whit different uH (250-285-360 and 433) but it find a coin near 5cm (2 inches)...why?? i readed on digiwood internet site that this kit work correctly whit coil from 150 to 400uH...
  • gando
  • nikko10
    The microcircuit can be programmed through an adapter, it is not necessary that the pin pins on the board, only take up space. I don?t know how to insert the archive in the RAR message, here is the link of the Russian-language site where I posted this archive.
    https://radioskot.ru/forum/14-15721-12
  • waltr
    Originally posted by nikko10 View Post
    [ATTACH]47030[/ATTACH]now the LED is triggered along with the booster
    This PCB layout is MISSING the PIC's ICSP header!
    This leaves no way to connect a PICKit programmer to Flash the code.
  • bernte_one
    hi nikko
    can you put lay file into zip or rar container as attachement? thx
  • nikko10
Name:	PIN DIP 1840.GIF
ID:	354598now the LED is triggered along with the booster
  • waltr
    I do use this circuit with a ferrite rod as a Pin Pointer. Works very well.
    It does how ever goes back into Calibration during which time it give an audio output. Simply hold it still and Cal finishes and it is ready.
    This can happen when MOVED rapidly (guessing a wire or slight shift of the coil/rod happens) which causes a Falsing. And can happen if Cal'ed in air then moved to only slightly minerialized soil.
    All this is due to this circuits extreme sensitivity to the slightest 'phase' shift of the coil/cap resonance.
  • nikko10
    Good evening! I assembled a ferrite head-470mkGn, length 100mm, made a chic case and what to say, I hastened to leave feedback, yes, I saw gold, yes, good range, but when I picked it up and waved it in the air, that's all the problems, constant workings. On the author’s board from the kit that he sells, you can see the third conclusion “-”, tried to shield the sensor, there is a constant, uninterrupted sound. Maybe he threw off such firmware ..., after all, for him it’s a commerce, but for himself he came to the conclusion that he is not suitable as an IDU with such work. Unfortunately, another disappointment uring ...Click image for larger version
  • Altair
    Has anybody tried this detector under the sea?
    I am wonder if is it is stable to work in that environment...
  • David_1
    Originally posted by David_1 View Post
    http://digiwood.ee/8-electronic-proj...tector-circuit
    I did not have a problem and received an email from him as well
    no connection to him just thought I liked this thread so would order one.
    well there you go ordered on the 27 arrived 7 days later from Estonia how cool is that
