Variable pulse TX
My intention is not to dissolve this thread by posting pointless stuff, this well may go to off-topic or somewhere else, not directly related to ground balance, but indirectly can be.
Sorry for hand writing, this is from old scrapbook, i'm not too good for making documentation, but can be interesting. Built long time ago just for waveform observation, now something similar rebuilt to take some measurements, very interesting for experimentation.
Circuit TX part is based on constant peak current control of fixed inductance coil, turning it off when preset value is reached. Now just varying drive voltage, pulse width can be varied over very wide range, 50:1 or 100:1 is easily achievable, keeping energy stored in the coil and magnetic field during this time constant. Energy is 1\2 L x I sq. considering I is fixed, resultant pulse width needed to ramp up to predetermined value is I\ (1\L) x Vcoil. Circuit is built using UC3844 SMPS chip, driving power mosfet or IGBT. R\C constant at pin 4 sets operating freq. around 4.2kHz with given component values, but adjustable over wide range. Pin 3 is current sense input, with precision 1V comparator, sensing voltage across resistor from mosfet source to gnd to monitor peak current. Without coil or coil voltage applied, will produce 50% square wave drive, but when coil current ramp up and pin 3 voltage reaches 1V cycle is terminated. In this case, 0,5R resistance gives 2A peak.
This on picture is “high voltage” version built time ago, present setup is bit different, intended for lower voltage operation for convenience. Coil is 8in speaker wire flat spiral, about 160uH, 25 turns, connected using ordinary wire (same as coil is made of) not coax, but it consists of two identical halves, strongly coupled. Very convenient, RX side and dumping resistor can be galvanically insulated otherwise everything have to be floated on high voltage side. Value of dumping resistor must be adjusted for each pulse width, so this is still point by point method (some sort of dumping network will be needed, not resistor). With this values, 1uS is reached at somewhat above 110V, 3uS around 36V, 50uS at only few volts (i'm running out of PSUs). UC3843 is needed for 12V operation, original HV circuit was built using rectified tube filament voltage, and variac\HV rectifier to supply coil voltage (not good, ripple voltage can interfere with integrated measurements). Separating TX from rest of the circuit, just to contain damage in case of “big bang”.
I assembled another similar device, but for differential measurement, based on SG3525 chip and two coils from flat spiral, to generate one fixed long, and another variable pulse, to measure just difference between them. Can be connected for unipolar or bipolar pulsing, can be used for actual detector TX. Not finished timing and integrating part yet. Want to try another modification, “transformer coil” multifilar, say 5:1 turns ratio, most probably UTP, giving large inductance ratio to achieve two different pulse widths using single battery voltage. Naturally, field straight is lower for less turns, but fixed and can be compensated later. I wish if I have more time for this...
Ground Balance Theory
Bugger me!
Hi guys,
you are getting huge complexity with the log-amp re the GB issue.
Try to solve the integral of the log(signal responses):
Integral log (Exponential induction decay + Magnetic induction decay + Const signal) dt =
Integral ( log( A*e^(-t/"TC") + B/t + C) ) dt =
(If you are doing the integration windows as usual in a PI configuration of course.)
And you get incredible noise issue and temperature dependency too. The temp. compensated log-amps do cost a fortune.
I'm not kidding. It makes the task very complex.
But keep on doing this as we can see some nice log scope shots.
Agreed. Reliable disc in PI that works in any soil would revolutionise the detecting world. However, even in medium mineralised soil many PI mine detectors struggle to perform adequately, so you have to factor in GB as well. What happens in a country that is remote for many of us may seem not to be relevant. But if a detector design works well there, it stands a better chance of doing a good job in any other country. Luckily, the 1/t decay for magnetic non-conductive ground applies everywhere and the Oz material gives much more signal to work with when doing development and testing. I can set up a GB circuit accurately with a 0.5kg lump of ironstone, whereas I would need a bucketful of a weaker soil.Originally posted by Altra View PostThanks for the lead.
I just ordered a few of the VCA810s. They look very useful. I'm looking into ferrous/nonferrous
disc, which nobody seems to care about anymore. A lot of energy has gone into GB methods for a
couple of remote hot spots in the world. The Holy Grail for PI in the other 95% of the world is reliable disc.
Keep us informed of how you get on with the log amp. I must find my VCA610s that are hiding somewhere. These are 8pin DIL and easy to experiment with. I see no reason not to tailor the gain of the main amp to prevent the huge amount of amplified noise that you get with no target signal. Or, run the amp linearly until a certain threshold has been reached and then switch in the log circuit.
The other benefit of a log amplifier is that it compresses the target signal right at the front end and reduces the large range of signal that has to be processed by the following circuitry.
Eric.
Thanks for the lead.Originally posted by Ferric Toes View PostWhat I hope to try is a VCA810 in the feedback of a normal front end (LME49990, or even a NE5534). Scroll down on the 810 datasheet and you will see a wide band log amp in the applications. I have a few VCA610, which is the earlier version, that I bought on ebay a while back. Just waiting to find them as they are hidden away somewhere in one of my many parts boxes.
Eric.
quote Wiki - Lurkers make up a large proportion of all users in online communities. Lurking allows users to learn the conventions of an online community before they actively participate. Lurkers are referred to using many different names, including browsers, read-only participants, non-public participants, legitimate peripheral participants, or vicarious learners. No problem with that surely?Originally posted by Aziz View PostHi Eric,
but you like to lurk regularly there. Don't you?
Each to his own.Regarding the log-amp:
I stand by my opinion.
Cheers,
Eric.
Hi Eric,Originally posted by Ferric Toes View PostAziz,
I must say that I dislike this cross forum posting! If Doug breaches the guidelines here and gets himself banned, then that is his problem. I will not post on his forum because of all the verbal battles and anti Minelab propaganda that is generated there. If you choose to post on both forums then that is your prerogative. However, you are wrong in your assessment that a log amp has no benefit. All the clues are there in what I have posted, but so far you appear to have missed them. That is the value of doing practical experiments and looking at real signals on a scope. Maths and calculations can only take you so far, then you have to get a chunk of ironstone, pulse it, look at the result and see what the maths has missed. I am certainly going to delve further into log amps and encourage others to do the same, if they are so inclined.
Eric.
BTW, Doug didn't deserve to be banned. UFox ok, he really did deserve it as he is regularly discrediting us in other forums too. I would like the admin to unban Doug.
Cheers,
Aziz,Originally posted by Aziz View PostA banned person wants to know something from Eric. I have tried to post the answer below in that forum but there are problems right now. The answer might interest some people here too so I post it here.
Well,
I don't see a benefit of using a log-amp. That's the opposite.
It only will show you, whether a target has a single time constant (a straight line in the log/lin graph). The derivation of it ( d(log(f))/dt) will reveal the time constant.
Well, we would need two sampling windows to make the GB. If we want to cancel the static magnetic field/EMI cancelling too, we would need additional a late sampling window. Total 3 sampling windows can make a good GB.
There is no need for a log-amp.
Eric.
[quote author=Doug link=topic=6529.msg28087#msg28087 date=1366109592]
Can anyone suggest a reason as to why Eric (on geotech) wants to try a logarithmic op amp("VCA810 in the feedback of a normal front end (LME49990, or even a NE5534)” in an experimental? Pi. Pi.Would this make it easier to implement new GB methods or algorithms?
Today, 05:52 AM #228
doug ::419::
[/quote]
Well,
Proof:
Target response = f(t) = A*e^(-t/TC)
d log(f(t))/dt = d log(A*e^(-t/"TC")) / dt = -1/TC
(see http://www.wolframalpha.com/input/?i...%22%29%29%2Fdt)
And if you make the "-1/x" - operator to the result you get the TC.
My point is that you don't need as much bandwidth anyway, as it gets buried in noise - true log amp or not. As a benefit of this setup you gain access to sampling a few us sooner. Besides, opamp/diode setup is easy to model in spice, so knowing your target dynamic range you can adjust everything else accordingly.Originally posted by Tepco View PostMain issue with op-amp\diode based log-amp is not log-linearity, but open loop BW limitation of amplifier used, limiting it's dynamic range.
Eric.
The log-amp idea seems to have potential, maybe not practical. But worth investigating. I found LOG102s for sale on ebay US, for $4.00/ea. Not sure if they are suitable? There is a data sheet and spice model on the link below. They appear to output the log of the input current.
Main issue with op-amp\diode based log-amp is not log-linearity, but open loop BW limitation of amplifier used, limiting it's dynamic range. Tried using LM318 and diodes at 32kHz and get stucked. Multistage designs are complex and usually high precision components are needed (tried to rip-off design from old portable Tek spectrum analyzer time ago, still have hardware, worked). Nothing can be achieved without some silicone. Remembering AD606 obtained for 125E (around 160$, over ten years ago!), i just dismissed any idea to use something similar for hobby. Today, useful chip like AD8307 is 12.5E (reichelt.de), acceptable for design. Just to figure out how to use it optimally, rules are different, band limiting, no need for DC coupling, extreme dynamic range to deal with, chips are log-amp\detectors giving absolute values... If you think you have no problems at all in your design, just add one, situation will change dramatically
. I get used to spectrum analyzer log display, but observing time domain process on scope this way is something one have to get used to...
What i'm doing here is to just try to utilize log-amp to extract some parameters from test setup, but for actual use in MD one criterion must be met: it most solve more problems compared to what it can produce, so i'm far from strongly advocating log-amps in actual MD design. May be changed...
Interesting that you mention it, but log amplification was mentioned on a few occasions here. Heck, I made some simulations with a simple opamp/diode setup. AFAIK it could be used for this purposes, and yes, it loses some log features at low signals as diodes are not as perfect as chained log amps, and they are prone to temperature effects, but both effects are mostly irrelevant for normal range of dynamics in use. As this setup uses inverting configuration, it is additionally resilient to high input signal (feedback fights the flyback), and first samples can be taken very early, at 4us or so.
Noise floor
This is best I managed to get, using brick, this %^&*~! thing is impossible to get above noise floor. TX width around 70uS, but coil intentionally underdumped, so it goes down in 4-5 fast cycles, increasing speed and visibility at early time. Two things I concluded so far, this response is also TX dependent, falls down with pulse width (rendering my double pulse idea useless), getting just noise floor at 3uS, also, process is probably not 1\t. Hard to distinguish from images like this, but ordinary soft ferrite is almost ideal 1\t, trace is just parallel (at some angle) to reference, this one is not (traces averaged x256). With some modifications, fixed TX time, more power, filtering, shielding etc, this can be improved for another 15dB or so, just not sure it is worth doing. Direct measurement may not be the best idea.Attached Files
Ended up exactly that way. Particles are certainly not 30nm, more like 30um or larger, very uneven. This oxide part is usually waste product from some chemical factory process, can contain just about anything, not good for this purpose, also not good for reference, different mixtures may behave differently, actually some Thermite types contain no Fe at all. Trying to find some other suitable substitute in form of ferrite. Ordinary soft ferrite is useless, but other types, like low permeability RF materials, or very high permeability, usually highly conductive types, or noncrystalline cores may be.
Idea with log-amp and differentiated output is phenomenal. I never before considered using log-amps for any hobby project, chips were expensive and hard to find time ago, but funny things can be done this way. Tried this “discrimination” method as described, well, works perfectly for nails, tools , paperclips and similar stuff, but unfortunately not for bottle caps or any more complexly shaped object. Very strange effects can be observed at shorter pulse lengths. Most objects tend to anomalously fall below it's natural linear (1\t log) curve earlier, some have “early time” bump more visible, some (larger more complex) deviate from linear in both directions during decay... Too many variables here.
