Originally posted by alcartraz
There should be a square wave at the output of U4D that is used to switch U7D (4066) on and off. This means that Q6 base is either at 0V (4066 turned on) or is biased to a higher voltage by U3A (LM356) when a metal target is near the coil (4066 turned off).
I know someone asked this earlier, but are you sure the link above R16 is inserted?
Looking at the original White's circuit diagram for the Surf PI, I notice that it has an audio transformer in the collector of Q6. This implies that the speaker needs to a high-impedance type, if you're not using a transformer.
