Hypodermic needles
  • green
    I'm wondering if a safety razor can be detected with a PI or VLF detector, since it appears to have a similar signal to the needle and ground with a lot higher strength. And if it is detected what target indication do you get? Thanks
  • green
    Got a needle. Target signal during coil on time, not off time. Lower response than ferrite at end of coil on time. On the bench with a small DD coil, Don't know if I could get a detector to detect it on the ground.
    I think the statement about the ferrite is wrong. I had just recorded the ferrite on a different coil for another thread and the signal didn't decay to zero. Tried some things this morning. If I unbalance the coil so that the trace looks like the needle trace I can make the trace look like the no target trace with the needle, 2 blade safety razor, ferrite core and some clay from the yard. No visual indication at turn off with either target. The ferrite and razor don't need to be as close to the coil to balance it. All the other targets I tried wouldn't balance the coil.
  • green
  • green
    Was comparing some other targets with the hypodermic needle I have. PI amplifier out during coil on time with an IB coil. Some clay from the back yard and a couple different ferrite beads look close if not the same. When Nupi's needles arrive I will do a better comparison. Does anyone have an idea why the hypodermic needle would cause a signal similar to ferrite? Maybe Nupi's needles will be different.
  • green
    Originally posted by Nupi View Post
    Strange that you have not yet received. I've posted the June 22
    it takes an average of six days, they said at the post office.
    Thanks for sending them. I checked the address I gave you to see If it was correct. It was, maybe slow mail.
  • Nupi
    I haven't received them yet. It's the same needle I was using.
  • green
    [QUOTE=WM6;195186]
    Interesting and promising observation green. Was needle during test in your hand or sticked at something like plastic ruler?
    The needle was laying on the coil. Same signal with less amplitude when farther away
  • green
    Hi green,
    I assume you have received the hypodermic needles?
    Which of the three needles that I sent you, did you use?
  • WM6
    [QUOTE=green;195182]
    Made a DD coil, each half 3/8 x 9/8 rectangle. Couldn't see a change on the coil off decay like I did with the mono coil for the hypodermic needle. Saw something I didn't expect during the coil on time. Including scope traces of amplifier out with no target, 5 x 5 mm aluminum foil and a hypodermic needle.[/QUOT
    It's been awhile and I forgot the aluminum was cut from a can and not foil.
  • Nupi
    Hi green,
  • green
    [QUOTE=green;195181]Made a DD coil, each half 3/8 x 9/8 rectangle. Couldn't see a change on the coil off decay like I did with the mono coil for the hypodermic needle. Saw something I didn't expect during the coil on time. Including scope traces of amplifier out with no target, 5 x 5 mm aluminum foil and a hypodermic needle.[/QUOT
  • green
  • Nupi
    Hi Nupi I was asking Qiaozhi
    about his prototype PI bipolar transmitter .
    I see it now, Sorry.
  • 6666
  • Nupi
    Thanks.
    Hi 6666,
    what do you mean by private project?
