PICKINI V3 - an easy to build PI detector
  • Beenthereuk
    From what I remember, the circuit uses both the ISCP DAT and CLK pins so may or may not work depending on the load placed on those pins by circuit components. You can code it directly, outside of the circuit, by using this sort of clip attached to the IC and to the PICKIT programmer:
    http://www.ebay.co.uk/itm/6-x-Single-Hook-Clip-Grabbers-Test-Probe-cable-for-multimeter-wire-lead-/151684532231?pt=LH_DefaultDomain_3&hash=item23511a 4807
  • BC547
    The in-circuit programming method, as described in the book on page 165 (complete PI2 circuit) should work.
    I haven't tried it yet and the connector is also not foreseen on the PCB.
    I program my parts with the PicKit3 programmer.
    But I don't see why it shouldn't work when you attach the programmer directly to the pins on the PCB.
    - Bernard
  • Guzzi
    Hello All
    Can i use the same methode, with the 5 pins, to program the PIC as in the book ITMD on page 165?
    Leendert
  • Beenthereuk
    In fact, test away from any buildings - at least 2m away from a wall, etc. Best go into an open field.
  • BC547
    For the circuit on breadboard, the response is kinda unstable sometimes, is it probably because of the noise of surrounding?
    Test your circuit outside the house, away from large metal structures
    and EMI. On a breadboard, longer leads on components may act as antennas.
    The sensitivity can be cranked up full range -- on a deserted beach.
  • bernte_one
    hello tclow
    the circiut needs some minutes to stabilize
    at start you will see the sens it not so high like the detector is switched on for 2 minutes
    do not trun the sens pot to high
    i remind if you turn it half way you even got the max sens
  • tclow
    Finally the circuit works, thanks a lot for sharing =D
  • BC547
    Pin 7 at around 10V is OK. It is divided by 2 towards pin 3 of the microcontroller.
    I quote the adjustment procedure :
    Adjustment:
    Adjust the DC offset of the opamp output with multiturn R23:
    Measure the DC voltage at pin 3 of the PIC12F1840 and adjust from low voltage until 5.3V is reached.
    Stop adjusting when 5.3V is barely reached.
    The voltage won't go any highter since it is clipped internally in the microcontroller with a diode to 5V.
    *my PCB trial failed ><
    It is a simple single sided PCB and easy to stuff. You can make bad solder connections, stuff the wrong components at the wrong place, short a couple of traces, but what else could possibly go wrong ...
  • tclow
    Now i get 5.92 - 6.05 variation at pin6 of opamp
    Vbatt/2 at pin1
    but at pin7 still fixed at around 1-2V less than Vbatt..
    btw my Vin is 13.05
  • tclow
    I see, made a mistake there.. now i changed the connection, the value is now full VBatt...
    at pin7 value goest to 1.58V and pin6, also around VBatt..
    i'm now trying to work directly on PCB.. see if it works.. currently the circuit is built on breadboard with DC supply..
  • tclow
    Thanks bernte_one!
  • BC547
    for pin1, No, it fixed at 0.5V, btw, isn't it suppose to be 0 as it connected to ground?
    NO - it should be 6V:
    Pin 1 of the opamp is "virtual ground" = VBatt/2 - connected only to D3, R4 and R13 - marked on the schematic as "DGND". Do not connect pin 1 to GND = minus pole of the battery - marked as "GND" on the schematic !
    Hope this helps,
    - Bernard
  • bernte_one
  • tclow
    for pin6, No, it fixed at -0.45V
    for pin7, No, it fixed at 10.6V
    btw, I am not sure about connection at x4..
    i did the connection as:
    x4-1 - 12V
    x4-2 - R19
    x4-3 - R18 - P6 of PIC
    x4-4 - GND
    is it correct?
    The whole circuit is built on breadboard and using breadboard stick as supply (not battery)
  • BC547
    Does the voltage at pin 6 of the opamp change when you adjust R23 ?
    Do you have VCC/2 at pin 1 of the opamp ?
    Does the output of the opamp - pin 7 - change in DC when adjusting R23 ?
    Check these first.
    Success!
    - Bernard
