Source of propagation delay?
  • VinceC
    Here is a spec for one that works... use that as your starting point.
    Would the BYV27-xx (http://www.vishay.com/docs/86042/byv27.pdf) make more sense? It has an even faster recovery time.
    Vince
  • green
    A chart and some scope shots of my bench circuit I posted on another thread awhile back. The (MUR460, no diode) is a time constant plot of two targets with the diode and with the diode shorted. The diode would allow sampling at 4usec instead of 9.5 usec. The amplitude is higher with no diode do to more voltage charging the coil causing a higher peak current. The on time could be increased to increase the peak current for the diode circuit. Don't see any advantage or disadvantage with the diode circuit if sampling with longer sampling delays for higher time constant targets. The (diode no diode) scope traces are coil volts with R damping disconnected for some diodes I had. The lower scope traces of resonance are with the scope probe disconnected from the coil laying near the drive circuit.
  • VinceC
    Is there any particular advantage for the 50V version over the 200V version?
  • VinceC
    But wouldn't a preamp design that reduces the time to settle be preferable?
    Its tough in a single stage. The easy way is two amps in cascade, each amp saturates less and so recovers from large inputs faster.
    From what I have been reading, this is not and "either or" but rather you MUST have both to achieve the full advantages of either portion.
    Vince
  • golfnut
  • KingJL
    Originally posted by VinceC View Post
    For the non-EE, what is "fast" in your mind?
  • VinceC
    I am not sure of all the needed characteristics, but speed is extremely important... a fast diode is not fast enough. I haven't tried many diodes in an actual circuit. I tried a 1N1004 and a BYV28-200 in my HAMMERHEAD 2. The 1N1004 did not produce the desired results... the BYV28-200 did... my damper resistance went from around 470 ohm to 820 ohm and I can sample down to 6.5 usec. I plan on using the BYV28-200 (I have 9 of them) in my current Minipulse Plus build.
  • green
    Maybe I'm wrong, but it sounds your referencing the diode. We were referencing the 10meg resistor from the diode to ground. A fast diode is needed to speed things up. I have tried the 1N4004 with the same result as you got(didn't work).
  • KingJL
    Is the leakage current missing from the Spice model for this component? Is that why the resistor is required? If so, should the resistor be connected to ground for this circuit?
    Vince
    It depends on the model used... I tend not to use the LT Spice built-in mosfet models. I usually get the Mosfet spice models and the Mosfets from Fairchild.
  • KingJL
    If your concept is correct, what diode characteristics are really required to maximize this effect?
    Vince
  • VinceC
    I tried 100k, 10meg, and 100meg in the spice model. Couldn't see a difference with 10 or 100meg. With 100k the coil decay didn't go to zero and stay there. If it's constant probably wouldn't matter in the real circuit. It looks better with high resistance in spice.
    I actually found that infinite resistance gave the best results! But if what Davor is saying is correct, the Spice Model may be a bit too ideal!
    Vince
  • VinceC
    Actually 6Meg simulates MOSFET leakage better. In case you wish to see a drain voltage simulated properly with a MUR460, you should keep the resistor. You should be able to observe it as SPA11N60C3 is modelled with all the necessary capacitances.
    Vince
  • VinceC
    Don't need it... that is why it worked better with 10meg. Lower resistance bleeds off the reverse bias charge buildup at the cathode of the diode. If the proper ultrafast diode is used ( I use BYV28-200 in the actual circuit... can be simulated with a model for a BYG20J ) this reverse bias charge buildup reduces the capacitance of the diode from the time that the coil discharge pulse returns to 150V-100V until the diode id forward biased by the TX cghrge current from the mosfet. The result is that you can reduce the TX curcuit capacutance to that of the diode (or thereabout). This behavior is disputed by some... but it works in the real world for me... I think the results depend on the characteristics of the diode.
    Vince
  • VinceC
    I don't think R1 would contribute to noise. The voltage on R1 is over 200 volts when the coil volts is at zero Isolated from the amplifier. I'm not a EE so could be wrong. The cap could be either place for the model. Putting it external allows someone to see the value looking at the schematic.
    This is obviously where my ignorance will shine! I have no idea if the leakage current of the diode allows "reverse" noise propagation through the diode. Perhaps one of our more knowledgeable members can dispel my crazy concept.
    Vince
  • green
