PI discrimination is possible
  • moodz
    Yes it does, but I'm not gonna tell you the "trick" (hint: it's not a trick, it's Physics).
    I agree with Teleno .. there may also be other ways to do it however "funny" damping and frontend ccts are a winner ... alot harder ( but not impossible ) with standard damping / frontends.
  • Teleno
    Originally posted by ODM View Post
    The "secret" to discriminating PI won't be in any funny damping circuit or such, since a single excitation pattern won't do it all just as a single frequency won't do it for CW
  • ODM
    Seeing actual PI discrimination in varied ground conditions and targets would give more faith besides the usual hidden software tricks or frontend overload.
    The issue with PI is general difficulty in processing multiple excitation responses that CW does more elegantly, in MF or sequential sweeping like GEM series does. A detector with a powerful find mode like minelab MPS together with an identify mode with multiple halfsine periods or pulse shapes would likely fare better than a constant excitation pattern with tweaky processing.
    The "secret" to discriminating PI won't be in any funny damping circuit or such, since a single excitation pattern won't do it all just as a single frequency won't do it for CW, for analysis purposes. We have seen this in the curious frontends and software tricks so far that have amounted to nothing for target ID outside of known obvious targets in known conditions.
  • Teleno
    and what? Mustafa does PI's with the disc like cooking hot dogs!
    and all are without the arduino )
    Actually, Mustafa's is a piece of **** and you know it.
  • kt315
  • Teleno
    started a topic PI discrimination is possible
    Coil: Ferrite core 150uH, 01. Ohms,
    Pulse duration: 60us
    Compensation resistor: 560Ohm.
    Vdd = 12V
    Oscilloscope:
    The pulse in yellow is the start signal of the Tx pulse.
    The pulse in blue is the discrimination signal, it shifts right for Fe and left for non-Fe.
    LCD screen:
    Count is the number of clock pulses (16MHz Arduino) between the yellow and blue signals.
