PI limit to early sampling
  • Qiaozhi
    Originally posted by Phiphi View Post
    OK. I hadn't seen it, there is so many topics on this forum !
    I think this paper is very interesting because it gives formula useful to calculate the parameters of a PI system. This paper is just 60 years old !
    Now, with modern electronics, we are more in the us range than in the ms range as in 1956 ...
    Yes - the paper is still very relevant.
    Perhaps you can answer the homework question in post #1, and derive equation 2?
    As you can see from later posts, equation 3 appears to be correct; but I failed to figure out how F.B. Johnson arrived at equation 2.
  • Phiphi
  • Qiaozhi
    [4] A pulsed bomb locator by F.B.Johson, M.A.
    25th January 1956
    The Pulsed Bomb Locator paper has been discussed on the forum here ->
  • Phiphi
    After a short but successful search on the Web, I have found these links on a french site : http://www.mantametaldetectors.com
    [2] Lettre de F.B.Johnson en réponse à Éric Foster
    http://www.mantametaldetectors.com/wpcontent/
    uploads/2016/01/Johnson-letter001.jpg
    [3] A method of detecting a mass of non-ferrous metal located
    at depth in the earth. J.H.Westcoot Ph.D. Imperial College.
    22rh febrary 1955
    uploads/2016/01/Westcott002.pdf
    25th January 1956
    uploads/2016/01/Johnson-FB005.pdf
    [5] Von Claus COLANI « Ein neuartiges metallsuchgerat nach
    dem pulsverfahren fur grofbe gelandeflachen mit
    elektronisher objektanalyse und –auswahl »
    08th june 1968
    uploads/2016/01/Colani-1968_German.pdf
    [6] E. J Foster « Futher developments of the pulsed induction
    metal detector » 1968
    uploads/2016/01/FOSTER.pdf
    [7] George Payne patent US4507612 A / 1979
    uploads/2016/01/US4507612.pdf
    The site is in french but the papers linked are all in english but one from Colani in german.
    I'm sure many of us will be interested ...
  • Phiphi
    Don't search, I have found it in the referenced thread in post #687.
  • Phiphi
    Which can be seen very clearly in this simulation:
    Here is an LTSpice simulation of equation 11 in John Alldred's paper:
    .......... (Eq.11)
    Thank you, interesting. Where can I find this John Alldred's paper ?
  • Qiaozhi
    The eddy response to a magnetic field step function is of the form t*e^(-t/tau), which has a peak at a time dependent on the target tau.
  • Carl-NC
    Thank you all for your answers. It's clearer for me now.
    What I understand is more or less what I was saying in my first post : between Tx off and, let's say 10 us after, it is impossible to distinguish no-target response to target response because the part due to coil is very strong. And the fastest is the coil, the sooner it will be possible to sample. Is this analysis seems correct for you ?
    Yes.
    If yes, one of the difficulty is to find the right sample time to maximize the difference between no-target response and target response. Am I right ?
    Yes, and it varies for different targets. The eddy response to a magnetic field step function is of the form t*e^(-t/tau), which has a peak at a time dependent on the target tau.
  • Phiphi
  • Carl-NC
    The first one is the following : Why, on every schematics I have seen so far, the first sampling after Tx off is so late, more than 10 us ? The designers wait for the signal to be very low then amplify it very hard and try to extract useful information buried in noise. Why don't sample sooner and amplify less to improve S/N ?
    A couple of reasons. As you try to push much below 8-10us, ground starts to become detectable. Also, as you push further up the decay curve, you have to run less gain to avoid saturation, and lose SNR in the process. Finally, the earlier you try to sample up the decay curve, the more sensitive everything gets to component variation (including the coil) and temperature shifts. In short, everything gets exponentially harder.
    If you want to sample early (even down to 0us), the easiest thing to do is build an IB coil.
    I have seen also that to be able to sample early, it is necessary to have a "fast coil" (low parasitics capacitance). May I have some explanations about that because I don't understand why ?
    The turn-off flyback & decay are due to the coil inductance and parasitics. The speed of the coil determines how fast its flyback is removed, leaving only the target signal.
  • Qiaozhi
    I know this book but I haven't already bought it ...
    Do you mean that the answers to my questions are inside ?
    I think it would answer a lot of your questions.
    You can use the "Look Inside" feature on Amazon to view some of the contents.
  • Teleno
    Your question is "why not sample during the turn-off transient". It's because the transient is orders of magnitude stronger than the target's response and you'd get a horrible signal/noise ratio.
  • Phiphi
  • Qiaozhi
    I have read some technical papers on this forum and on the net on this topic and I think I begin to understand how a PI detector works but I have many questions to go deeper ( in my understanding and maybe later deeper to find items buried ! )
    I assume you are aware of ITMD?
    https://www.amazon.fr/s/ref=nb_sb_no...metal+detector
  • Teleno
    The Tx coil runs a 1-3 amperes pulse and this current does not disappear instantly.
