Originally posted by waltr
VDI-RODERICO
yes he should see some activity although the display is not responding but he also needs to setup the oscilloscope properly and so on, but if the could flash the firmware without errors then the pic probably is fine, I was suggesting and easy test just to check the other firmware for these displays, if everything else is correct
did you try VDI_S6B0108_P18F25K22.hex firmware? these displays are clones the built in controller says KS0107B or equivalent, yo need to power the pcb for the pic to be detected by pickit3 as you probably you did the first time as in the images you attached the first post
Hello Roderico! Everything is fine with jumpers --- checked with a tester. The PCB is also normal (I checked everything several times). To exclude the display, connected the second. He has a 100% controller KS0108. However, nothing has changed, everything is the same. Maybe it was necessary to put a tick in front of the MCLR item in PICkit3?? I bought PIC18F25K22 in a trusted store. Just in case, I connected the first display to the DM-1 ... everything works. In general, I will continue to think ...
The second display bought in this store
Roderico,
Shouldn't he see some activity on the Display control pins when resetting the PIC?
That was the only way I could think of to determine if the PIC is actually running code.
I was thinking he didn't have a good display but want to check that the PIC was running first.
I would replace one of the jumpers that looks like they are touching with a wire as waltr suggested, but if everything is fine I think it might be the display, could you post a picture of the back of the display or do you know the model? It looks like a clone of KS0108 if so you would need to use VDI_S6B0108_P18F26K22.hex instead of VDI_KS0108_P18F25K22.hex or it won't work, could you give it a try?
Good day! I took measurements with an oscilloscope --- nothing ... There is no signal on any of the outputs ... none at all, only noise. There is only voltage. It seems that the PIC does not start at all. The reset circuit is working. The contrast is adjustable in a wide range, but the display is empty ... Anyway, to hell with it. I'll put it in the archive --- harvesting is starting now, I have to go to the dig. I apologize for wasting your time and thank you for your willingness to help.
With the Internal oscillator there is not a clock on the pins (9&10). See figure 2-1 in the PIC data sheet.
Only pins I would check are the PIC pins to the Display.
These should output commands and data to the display upon power up or RESET (SW1).
Check the Display pins, EN, RS, RW, CS1 & CS2 as well as data pins, DB0-DB7. Some/most of these pins should have activity.
Have you ADJUSTED the CONTRAST Pot??? These displays will show nothing unless the contrast adjustment is just right.
I checked the jumpers first of all --- there are no short circuits, all tracks were viewed under a magnifying glass and rang by a tester. Everything is great. The contacts in the PIC socket are also good. And, here's where to look with an oscilloscope (on which pins) and what should I see there? For example, on pins OSC1 and OSC2 should there be an internal oscillator frequency (4MHz, sort of) or not?
Did you check with an O'scope PIC output pins to display and see if they toggled when powering the PIC?
Did you adjust the display Contrast?
Looks like the jumper wires above the PIC may be SHORTED. Ensure they are NOT touching (should have had insulated wire for the long ones).
The code should be using the Internal PIC Oscillator. This is set in the 'CONFIG1H' bits.
The PICKit3 shows this to be 0x2800 which is correct to enable 'internal oscillator'.Code:// PIC18F25K22 Configuration Bit Settings // 'C' source line config statements // CONFIG1H #pragma config FOSC = INTIO67 // Oscillator Selection bits (Internal oscillator block) #pragma config PLLCFG = OFF // 4X PLL Enable (Oscillator used directly) #pragma config PRICLKEN = ON // Primary clock enable bit (Primary clock enabled) #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled) #pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
Code seems good so check first items I list.Attached Files
Hello! I finally got this set up. I flashed the controller, inserted it into the socket, applied power and ... and nothing. The display shows nothing. The contrast is adjustable, but there is no indication. The display is serviceable --- stood on the Turkish VDI DM-1. It seems that PIC18F25K22 does not start. All voltages are present, the parts are in good condition, the installation has been checked several times. Where else to look, I have no idea. The archive contains the firmware that was flashed, a diagram, a printed circuit board drawing and screenshots from PicKit3. Thanks!
You must have some idea about the vdi numbers accuracy. Holyuser made the first vdi display on this board whites VDI that really worked. It makes me realize how old the Geotech board is, pretty cool. from what Ive read he has health issues. Yeah I agree with you that the x-y graph is great and i am wondering if it will work on tejon.
I can comment on the Roderico VDI but never used the Holyuser and do not know what it is.Originally posted by Wiltran View PostAnybody care to comment on the discrimination accuracy of Roderico VDI vs. the display made by Holyuser?
I use the VDI on a TGSL and the X-Y display I find to be most useful. I do not use the VDI numbers but look at the angle and shape of the X-Y graph while doing short sweeps across the target in multiple directions. Correct ID of target is then about 80%. Many targets will fool you, had one that seemed to be can slaw but dug it and found a 14ct gold ring with three diamonds that had been plow bent.
Originally posted by zmaj od nocaja View PostFinally I found a problem and my VDI working great with zolen display. Problem was bad reset button, remaining on all time. Thank you a lot :-)
Ahhh...something simple and stupid...
Great nothing was wrong with display connections or code.
