How to improve my Surf PI 1.2 for a mission like this: Underwater search for iron/steel solely
  • ZOUjiarui
    The two resistors are connected in series. I don't have 180k and 22k
  • ZOUjiarui
    U1 (555) is the TX oscillator. You could change R1 (100k) to 180k, and R2 (3k3) to 22k. This will give you a TX pulse width of 332us and a transmit rate of 329pps. Alternatively, replace R1 and R2 with trimmers, and adjust the values to get exactly what you want. However, the Surf-PI also uses the TX oscillator to generate the audio tone, which is 623Hz, so the audio tone will be much lower if you change these components.
    I don't know the maximum sample delay setting on the Surf-PI, but this is adjusted by P2 (100k). You may have to change the values of P2 and/or C9 to achieve 100us.
    Otherwise, have a look at Minipulse Plus Rev-E, which already has on-board trimmers to allow independent adjustment of the PX pulse width and transmit rate. There is a separate VCO audio oscillator, which means that the audio tone will be unaffected.
    Hello, I directly added 68k and 20k resistors, and the irf9640 and damping resistors heated up seriously. Is there any solution?
    Thank you so much
  • Loola
    Many years ago my father drove a 6000 Kilos heavy tractor trough the ice. When the ice got thicker, he and couple off men went back out on the ice with a big quadpod with a manual operated winch. They manage to lift the tractor back up on the ice again. So, the ice does not always have to be an obstacle, it could even be beneficial to when it comes to recovering goods from the bottom.
    /Loola
  • Ferric Toes
    It's a fake.
    Just one of KT315's little jokes.
    That's OK then. I got a bit concerned when Loola said "Thank you for the book tip! I will look it up."
    Eric.
  • kt315
    seen this pic you may present the depth. this probe is main instrument for lift up. it can be with hook and pin on its end changing.
  • kt315
    from bottom
  • kt315
    Air bags have been used to lift large cannons. Lift them off the bottom then tow to shallow water or a ramp. Same for any heavy object. Obviously you need to dive to attach straps or cables to the object, plus an air compressor. Do the survey on the ice; take GPS co-ordinates; then go back with the airbags when the ice has melted. Best to see what you have found before lifting though.
    Eric.
    thank you Eric. nice way.
  • qute1
  • kt315
    maybe. it's Third Edition. yet did not released. in stage of run-up.
  • qute1
    It is also a good advert for you as both KT315 myself and many others feel that the answers to near everything MD related reside in this very tome.
  • Qiaozhi
    Is this real, or a fake? I see my name is on the cover, but it is NOT with my courtesy at all. I fully recommend the real book which is solely the work of George Overton and Carl Moreland. Explanation Please!
    Eric.
    It's a fake.
  • Ferric Toes
    Eric.
  • Ferric Toes
    you do not see main problem. no difficulty to seek a something on 3-4 meter of depth, but how you will lift it up?
    all heavy metal were left on a bottom because no instrument to hook up it and lift.
    Eric.
  • kt315
  • Loola
    I have the search coil in another town so at this moment I cannot test this settings that you guys so nicely have shared, but soon I will be able to do some testing.
    Another question that rises: Is it possible to do searches at the bottom of lakes in the winter, and do so by walking on the ice. With let us say a deep seeking PI. Or would it just penetrate the ice and one or two meters more (depending on how good your detector is). I.E how would it function with a deep seeker on a frozen lake? What depth could one expect to reach?
