Cache Test
  • Carl-NC
    Here is a photo I took of the Central America gold exhibit. It shows a variety of finds, from the bonded clump of coins in the rear, to the bright-as-new coins in the center. Nothing had been cleaned, this was how they were found. Note that some of the coins are partially bright, and partially stained. As I recall, all of this was from contact with iron, and could have been easily removed.
  • Carl-NC
    Most patina on old and natural gold can be explained by a natural "electroplating" process. Look up the Galvanic table of metals where you see gold on top and iron much further down. If you submerse both metals in an electrolite, like sea water or you can even use Coca Cola, then the less noble metal will dissolve and the ions migrate through the electrolite to the noble metal and coat it. It is a natural electrical process no need to add any external power.
    You can stick one gold plate and one aluminium plate into sea water and you will get a potential over 2 Volt if I remember right.
    Tinkerer
    I saw this years ago, when the treasure from the Central America was on display in San Fran. Gold coins and bars that were in contact with iron had been "stained" black by the iron migrating to the gold, but only where there was contact. Elsewhere, the gold was perfect, like the day it was made. None of it had been cleaned in any way.
    - Carl
  • Tinkerer
    Originally posted by michael View Post
    Jeepers keepers....But I have seen some very old gold objects for over 2000 years (alloy over 22) had a distinctive black layer on the surface!!!! could you please explain it for me???!!
    You are right, my purpose was that gold is not immortal or unchangeable.
    meanwhile for these action and interactions not necassary pass milion years. 10-20 years will do its' job.of course should be added it definitely depends on soil condition and components + weather
    conditions had been there for years.(dry, rainy,...)
    Tinkerer
  • Tinkerer
    Scientific evidence
    I should clarify my statements... we are talking about gold treasure, i.e., coins, jewelry, etc., that has been recently lost. Recently meaning 100's of days to 100's of years. We are talking about average natural conditions. We are not talking about millions of years, high pressures, or boiling hot temperatures.
    Yes, I know gold has an oxide. Yes, I know gold will dissolve in aqua regia. Yes, I know seawater has dissolved gold in it, on the order of 6 nanograms per liter. This did not come from sunken treasure. BTW, gold in seawater is not in ionic form.
    I will consider scientific evidence and experiments that show buried or sunken gold produces ionic fields. I would not accept Mineoro's word on this, as some of the answers they've given me on other questions were completely bogus.
    I will consider scientific evidence and experiments that show buried silver and copper produce ionic fields which enhance detection, resulting in the popular "halo" theory. Tinkerer gave a very interesting explanation, which deserves investigation. I have strong doubts that any such ions would have any measurable effect on a metal detector, but it's worth looking at.
    And so I started this very experiment about 2 weeks ago.
    - Carl
    I would like to clarify, that what I meant is that the detectable part is the enhanced conductivity created by the halo of metallic salts, not the ions themselves. This off course only works if the surrounding soil is different.
    About a similar effect as the "Hole" effect.
    An easy test of this theory, would be to search for a sweet spot of sandy, absorbing soil. Then poor a pint of salt solution into it. Will it respond to the metal detector?
    I fully agree about proving all and every statement scientifically. This seems to be the big problem of dowsing rods, whatever fancy name they give it.
    I think we would do humanity a great service if we could prove once and for all, with repeatable scientific testing, that dowsing rods do work.
    Why has nobody taken Carls offer? And then there is the 1,000,000 Randy offer too. No need to go digging in scorching sun in snake infested bushland. Just show you can do it, scientifically.
    The one that does it will be the hero of the century.
    Tinkerer
  • hung
    [quote=okantex;45836].all of us know the truth about gold.does not ionize.]/QUOTE]
    All matter loses atoms as time goes by. Ions are modified atoms which loses or gain electrons. Gold is matter. It has atoms. It ionizes as well.
    PS. Your drawing is pretty much correct regarding magnetic and electrical/electrostatic fields behavior.
  • okantex
    I think it is clear why zahori works north to south.
    and why it detects farther from the north.
  • okantex
    hi
    I hope you like my treasure chest
  • okantex
    hi
    why are you trying to find new phenomens.all of us know the truth about gold.does not ionize.
    but there is something about it.it is diamagnetic meterial.reflects the the energy what ever causes it.Even a detector or earth.
    have a look at this page .it is the phenomen used in magnometers also.
    and minoro and zahori uses the same.but zahori and mineoro only takes the +
    positive signal which comes out of earth.
    I remembers Esteban's experience for a empty hole which burned 3130.
    why here nobody else tells about this?
    do mineoro effected by cavities.?
    and magnetic flux of earth changes place to place according to resisitivity.is not it?
  • hung
    Also, add to this that even for a small gold object in this case, the deeper it's buried, the stronger the field it produces.
    Did I hear the position of earth and its axis play an important role on this?
    Hint, hint...
  • hung
    Exactly Michael. Good observation.
    By the way, nice chemistry explanation posts above. It made me recall my chemistry classes.
  • hung
    Ha,ha,ha,ha,..
    Now Carl says 'not exactly that what I meant'...
    Yes this is exactly what you meant. No excuse.
    Tinkerer posted the exact information about the phenomena described.
    Carl even might not agree with Mineoro, he's free to believe what he wants. Even when evidences are overwhelming and thae answer is clear as Tinkerer's recipient of fresh water!
  • michael
    Black golds!!
    Originally posted by Jim
    Jeepers…all of the gold coins and jewelry I have dug has always come out of the ground/water in pristine condition. I am probably one of the lucky ones, digging/diving in an acid-free area.
    Originally posted by Carl-Nc
    I should clarify my statements... we are talking about gold treasure, i.e., coins, jewelry, etc., that has been recently lost. Recently meaning 100's of days to 100's of years. We are talking about average natural conditions. We are not talking about millions of years, high pressures, or boiling hot temperatures.Yes, I know gold has an oxide. Yes, I know gold will dissolve in aqua regia. Yes, I know seawater has dissolved gold in it, on the order of 6 nanograms per liter....
  • Esteban
    From http://www.treasurelore.com/florida/detector_info.htm
    WHAT IS HALO EFFECT?
    Halo effect makes targets that have been in the ground a long time appear much larger than they actually are. Imagine an iron nail that has been in the ground for a number of years. As moisture in the ground slowly rusts the nail, forming iron oxides and iron salts, these oxides and salts migrate from the surface and tend to form a “halo“ around the nail. This, of course, makes it a lot “easier“ for a metal detector to detect. This effect is basically the same for most metals. When the target is dug, this halo effect (which takes years to form) is destroyed. So if you find a target due to the halo effect, and, for instance, it was a very weak signal, you will find that if you rebury it at the same depth, you will probably not now detect it (unless you leave it for five years!). For you beach-hunters, halo effect rarely has time to build up and will be destroyed if the ground moves. Relics are often found at greater depths due to these effects.
    Gold can be very hard to find due to the odd shapes that are often formed. Halo effect really helps us liberate a lot of gold, as most gold hasn’t moved in a long time! But gold doesn’t rust or corrode I hear you say. Correct. Often where you find gold there are also salts and chemicals (like cyanide) and these will leach out the gold into the surrounding minerals, causing a halo effect.
  • Carl-NC
    won't be dissolved? why not?
    I have wrote this before and here repeat it:
    gold easily is dissolved in Hydrochloric acid (HCl) especially in mix of HCl + HNo3(3/1).
    there is a simple chemical theorem; when you dissolve a salt(e.g. NaCl) in water it produces an acid + base. when is NaCl this happens: NaCl + H2o gives HCl + NaoH. especially when be under pressure, slight heat and long time it will interact on gold and gives compounds such as; AuCl3[ gold(III)-chloride] or HAuCl4.3H2o (gold trichloride acid trihydrate) or for platinum; PtCl2 & PtCl4.
    In nature may be happens such an action and interaction or little different that induces a kind of halo.
    Can you definitely decline these with 100% certainty?
    Just to be correct: gold can oxidize too. Chemical formula is Au2O3 and is water-insoluble, heat-decomposable (at 350C), brownish-black powder; soluble in hydrochloric acid; used to gild, in medicine and porcelain, and for daguerreotypes. Also known as auric oxide; gold trioxide. It is usually done by reactive sputtering of pure gold in an oxygen plasma.
    In nature gold does not oxidize very fast: native gold usually has a thin coat of iron oxide or silica that prevents it from amalgamating readily.
    - Carl
  • Leto
    Copper Vs Iron
    Attached are two photos.
    Left is a fragment of a damaged bronze needle 2500 years old. You can clearly see what happened: Bronze patina (copper oxide+) completly transformed shiny bronze. Dark green patina is original surface of needle and the golden core is what remains of bronze. Such objects are very hard to detect even with lowest dead times - copper oxide is just too bad conductor.
    Bronze can leave green stains if an object is lying on very poreous material as bone, leather... and usually can not be seen in surrounding earth (except as a thin layer around object), but as said - copper oxide is poor conductor and can not help with detection.
    Right is the iron nail (medieval). The story here is different - the edge of dark core is original surface of the nail and the brown-yellow mantle around it is of course iron oxide. Iron oxide in high concentrations can be detected with metal detector - and here can be the cause of Fe objects having halo effect.
    As other people experimenting with MD I noticed too how some items can be detected deeper in undisturbed ground than air but probably this is not because of leeching ions etc., but we should investigate how magnetic fields propagate throu undisturbed soil Vs air.... I bet there lies an answer to infamous halo effect.
