Originally posted by conan
AH SUPER PRO V
Super Pro V Schematic
Hello do you still have the schematic for the Super Pro VOriginally posted by Qiaozhi View PostSuccess! Allen has sent me the schematic.
Now I need to find some time to repair this detector.
I have recently been given one to look at.But the coil is in pieces
and no way of knowing what to replace with.Powers up and sensitivity is adjustable and meter works,but with out a coil is not much good.
The coil seems to have a 10n capacitor but coil winding is only a guess
since the previous hands butchered the tiny wiring.Any suggestions on how to make up something or replacement from another maker like old whites,Garrett,Bounty Hunter to use their coils
Cheers to all
After some searching I've discovered his email address: [email protected]Originally posted by JimNM View PostNo, I didn't try to get one. You might try contacting Alan Hammetta the builder.
The thing that threw me off course was the misspelling of his first name.
Anyway, I'll let you know whether I'm successful or not. Thanks for your help.
thanks for the reply
Hi Joe!
thanks for the reply! If you know any one who wants this one (Super Pro-V), I'd be interesting in trading for something. thanks!
Jim
SUPERPRO VS. PRO-2
I also have a Pro-2. It has a tonal control like the SuperPro V. I prefer it over all the other AH Pro detectors. It is a lot more sensitive to nickels than the SuperPro. It is also well balanced and is lighter in weight than the SuperPro. My SuperPro only gets 3 or 4 inches max on a nickel, the Pro-2 gets 6 or 7 inches on the same nickel. These detectors ground tune or can ground-hug the ground very well! No motion here so pinpointing is not a problem. Very loud signals are shallow in depth while the deeper targets are faint. Battery drain seems to be very nominal, I'm still using the same batteries purchased months ago! Objects can also be sized up, that is one can figure out the size of a target without a meter or graph telling one what size it could be! Joe
A.H. SUPERPRO V
Hi! SEE MY POSTS IN THE VINTAGE-COLLECTABLE FORUM. This a great detector not as deep as the current ones. It seems to be a cross between the BFO and the TR. It can squeal like a BFO but also gives a strong audio signal like the TR. As far as I know the SuperPro V has a tonal control while the SuperPro doesn't! This detector can see thru a lot of the trash and sees the good targets. It is light weight and well balanced and its tonal variances makes it a joy to use. I have found silver in worked out parks maybe because of the small-6 inch loop. It can see around a lot of the trash plus it makes one to slow down to cover each pass thoroughly. Hope this helps. Feel free to ask me any other questions concerning the SuperPro I'd be glad to answer! Joe
It got here!
I received the AH SUPER PRO-V this afternoon. It's a hipmount/chestmount version with a neck/shoulder strap on the control box. The armrest is on the rod that goes to the coil. It actually works in a strange sort of way. The tuning is weird, but it works in all functions. I'm using a new computer and have a digital camera, but not too good at posting pictures just yet. I'll try to post pics tomorrow.
Jim
Neat! Thanks for the photos. I should have one in a few days.
Let you know how it works. Thanks!
Jim
Sorry - my mistake. Of course, the other one is an AH Super Pro (without the V). Do you know what the difference is between these two?Originally posted by Carl-NC View PostWell, actually, the only one I have, happens to be the one Qiaozhi has. So let me know what you want for it.
- Carl
Here's a couple of pics of the AH Super Pro V:
- Carl
