"OLD FORGOTTEN METAL DETECTOR'S"
  • chopz54
    Hi Chopz54,
    Will you fill in the values of the components.
    And will you have a special look in the yellow marks,confuse me.
    Grt Nakky
    I dont have time to do that many I meant just a few key parts.
  • nakky
    Hi Chopz54,
    Grt Nakky
  • chopz54
    Originally posted by amtech2005 View Post
    Hello Everyone . I can not figure out which model this is cloned from ? I thought this Red-Heat ran @ 17 khz and was made around 1994 ? Maybe why the Red-Heat is painted with permanent ink marker , try to use Cutex "Acetone" to clean components then we will know secrets .
    Trace on PCB could be cut for isolated ground for shield on a center tapped search-coil ?
    Regards................Eugene
    Machine is dated inside 10 june 1993.
    Let me know which components ID's you would like-showing them in one of my original photos.
  • ivconic
    Hi Ivconic,
    I think,I have tree little points, marked in blue.
    Grt Nakky
    Yes, that's true!
    Good job Nakky!
    Cheers!
  • ivconic
    Originally posted by ApBerg View Post
    Hello Ivica,
    Great.... now you are the fastest man on earth
    More serious.. have you seen the ground track break on top 2n2907.... Tesoro had always a closed ground track around the pcb's... Vic had also had made a cut in the ground track...?? is there some need for ??
    Agree it is Tesoro family !
    Best regards.
    Ap
    I think it is done to void eventual ground loop.
    Although, on most of my pcb's i put continued ground "frame" and usually i don't have loop issues.
    Might be Vic experienced some problems with "frame" and later decided to cut small piece and brake it.
  • amtech2005
  • nakky
    Hi Ivconic,
    Grt Nakky
  • ApBerg
    This should be preliminary sketch.
    Now it is needed to check it.
    There are several spots on pcb about which i am not sure, due unclear photo.
    Most probably i made some mistakes.
    Actually this is manually draw pcb! Ahahahah! I used to work like that in the past too.
    Also, most probably author made some smaller mods on it.
    I see some "tuning" added extra.
    I put some components values about which there should be no doubts.
    Rest i can do later when checking is done. Maybe bit better photo will help too.
    There is to strong light pointed to pcb, making some shades and shines which disturbing me to see clearly.
    It is obvious that this is Tesoro design, no doubts in that.
    Could be earlier version of Bandido or similar.
    Hello Ivica,
    Best regards.
    Ap
  • WM6
    Amazing work!
    He has special NASA reversing software.
  • simonbaker
    Amazing work!
  • ivconic
  • chopz54
    Thats VERY good Qiaozhi
    If you need any printed info (which is visible) off any components, I will have a look for you,which should save you some time.
  • chopz54
    Instead of making photos, try to put PCB on scanner, you will get much better hi-res picture without problems whit alignment, light etc.
    That would have been ok if the board was OUT of the box, but as you can see from my
    photos about 20% of it is still tight in the control box + add the plastic edgeing on most
    scanners and all you would have seen was about 1/2 of the board........
  • Qiaozhi
    OK - try this ->
  • Qiaozhi
    That's the problem. He cannot remove the PCB from the enclosure without unsoldering all the wires.
