SD2000 Front end
  • external9
    sd2000
    hello Would explore how useful this is the metal detector?
  • eclipse
    At least we know the schematic is correct, which is good ...
  • 1843
    1843 did you use the same components as those on the schematic
    some of them like LT1057 have very good parameters and if you use
    alternative the circuit could suffer from noises from such components
    I also want to build the it, but I am novice, don't know if i could do it.
    I am making board for it, 3 days just the power supply part ready
    No! As I said the mine had many difference.... I used an LT1054 for power supply,
    LF356 instead of LT1057... etc.
    Best regards,
    1843
  • eclipse
  • gef12
    Ye roger that .. I would have more benefit with motion mode as it gives me a good idea of where small targets lie .. especially nuggets... just cant visuallize how a non-motion would work or in what scenario ... have only used motion md's
    thanks anyways
  • 1843
    Originally posted by gef12 View Post
    hi
    I dont suppose there is a sd2000 pcb in the making ...
    Good try at the sd2000 on breadboard ..now i know I shouldnt try it as yet..
    Have you try shielding the front end stage ?? or anything else ??
    Anyways thanks
    No, I didn't shield anything. In fact when I saw it works in motion mode, didn't try anymore on it... I like non-motion MDs...
    Best regards,
    1843
  • putrechigi
    hi
    hi at all
    see this video peraps is intresting for you
    best reguards
  • Aziz
    Originally posted by JC1 View Post
    this one looks like 3 in parallel,
    in one package, very low noise,
    very high capacitance, very large die.
    http://www.interfet.com/pdf/P_NJ3600L.pdf
    Thanks JC1,
    so we can reduce the input resistors + pre-amp resistors to lower the resistor noises.
    I will start soon making some noise analysis on:
    - different power supplies
    - pre-amps
    - coils and coil shieldings
    I will also take milliWatt®™ PI coil pulses into account to reduce inherent noise and mineral soil magnetization.
  • JC1
    Guest replied
    3
  • JC1
    Guest replied
    links
    Here are some links on IntraFet low noise devices.
    notice the different noise, capacitance and die sizes.
    now to get lower noise than the lowest one here you
    would need to start paralleling them.
  • JC1
    Guest replied
    yes
    I have one more goody for you and others:
    A Low Noise Amplifier for Phase Noise Measurements
    http://www.wenzel.com/pdffiles1/pdfs/lowamp.pdf
    Almost same principle. But here using two fets parallel to reduce noise. This could be even better.
    Hi Aziz,
    Yes two or more of the same type in parallel will reduce noise.
    Over one of the same type.
    If you check the data sheets on FETs you will find that the
    lower noise devices generally have higher gate capacitance Cgs.
    why? because they are physically larger dies in the package,
    i.e. in effect multiple FETs in parallel just made as one large one.
    now the silicon can also be thicker and thinner also causing a change
    in capacitance but in general you will find what I said to be the case.
    The drain current required is also usually higher as well just as you would
    need to double the current through a single drain resistor to use two FETs.
  • ZED
    Caps
    At a risk of saying the obvious.
    Dont forget to put bypass caps on all the chips,especially the preamps.
    Zed
  • Aziz
    Hi Aziz,
    Yet another good find Aziz,
    good work, and your coil stuff
    is good too.
  • gef12
    Originally posted by 1843 View Post
    Hi gef,
    I completed the my SD2000.... It works very unstable because of the breadboard and internal noises... it detects a gold ring at 12cm...
    This machine must be made on pcb to get the best performance.
    hi
    Anyways thanks
  • JC1
    Guest replied
    good find
    Hi Aziz,
    is good too.
