TGSL Experiments
  • salih
    help
    hello to all
    my MD tgsl in Air test I Get 30 cm for coin 2.2cm in all Metals or in VLF its same.
    I went to the test Tgsl on Field ( coin 2.2cm)
    In the position VLF, on max sensitivity I Get 15cm Deep in the ground
    In the position all Metals I Get 20cm Deep in the ground
    Is this really Results tgsl in Field
    I need ideas Please
    Greetings
  • simonbaker
    Exactly!
    I haven't seen feedback coil too!
    Yet i presume it was already included (and conjoined) with RX coil...
    Shield is obviously black layer inside both covers. Most probably graphite powder, sprayed earlier.
    I laughed when saw hand holding twisted can and pouring epoxy - same as i do!
    Each time i make coil - i bust some can and few "drops" of epoxy.
    I laughed at that pouring too because it was very skillful, I guess they couldn't make a machine to do it as well. I could never pour so perfectly though.
    The coil winder seemed funny also -- was it my imagination, or was there a kind of unsteady wobble going on?
    -SB
  • ivconic
    Whet's your appetite for more details. I don't think they mentioned the bucking coil at all, but there must have been one.
    -SB
    Exactly!
  • ivconic
    Originally posted by Jerry View Post
    Just watched the video three times and have a few thoughts:
    The glue on the wire activated by the alcohol is a neat twist on the method the dfbowers posted on here. There must be source for that type of wire.
    Oven is fairly low temp since the coils are on a piece of cardboard probably 150 - 200 degrees F.
    The coil testing with the scope was the most interesting of all. The machine must have been true non-motion mode. Makes me think about building a non-motion detector just for coil testing.
    Very Interesting! Thanks for sharing
    Jerry
    Yes, that's was what also attracted most of my attention too!
    Very nice to join windings like that and fix it in nice shape.
    I wandered about wire, but Altra already founded answer! (Thanks Altra!)
    Machine is not necessary to be non motion, because the very same behavior is with motions too, when observed on scope.
    Scope is 2 channel. If you have it - just hook up any available detector and you will see.
  • simonbaker
    Found this on Youtube. I think all their R&D is done on this forum
    http://www.youtube.com/watch?v=EA3aXkc6t64
    -SB
  • Qiaozhi
    Qiaozhi,
    Notice when the lady places the TX coil in the white housing the inside is black! They cut out the first epoxy pour, nulling and 2nd shielding. They show the second epoxy pour on top of the second layer shield. Think of a sandwich.
    Well spotted.
    I hadn't noticed that.
  • Jerry
    Hi Jerry,
    The wire is known as "bondable" magnet wire. Its hard to find in small quanities or on ebay. Minimum order from factory is 6in spool or about 10lb.
    See this link. "PN Bond #1"
    Insulation Enameled Wire Insulation Characteristics
    As for the testing he has one scope channel on TX output to the coil and the other channels hooked up to the output on the preamp. No need to build a non motion circuit.
    Hi Altra:
    Will check that out.
    On the scope test I was over analyzing it a bit. Makes perfect sense.
    Jerry
  • Altra
    Qiaozhi,
  • Altra
    Hi Jerry,
    See this link. "PNB Bond #1"
    As for the testing he has one scope channel on the TX output to the coil and the other channels hooked up to the output on the preamp. No need to build a non motion circuit.
  • Jerry
    Jerry
  • Qiaozhi
    The tests with the oscilloscope are confirmation of what we already know.
    The timebase appears to be set to 10us/div, giving a TX frequency of approximately 10kHz. This is probably a Bandido they're using for the testing. You can also see the initial phase offset of about 22us; which equates to an offset of 202us for a DD coil. Notice they didn't mention anything about the Faraday shield, as I guess they didn't want to give away all their trade secrets.
  • ivconic
    Ivconic,
    They are waiting for your final version of the IGSL
    You are holding up production for Christmas sales. Hurry please!
    IGSL's power drain is HUGE comparing to new Tesoro standards, because their newer models are really nice machines and drains much much less at the same time with better performances.
    So i think IGSL will not be so interesting for such manufacturers as Tesoro.
    But i will like to see "double" Tejon with same philosophy as is presented at IGSL.
    Would be mighty machine indeed.
  • Altra
    Ivconic,
  • ivconic
    I watched it with huge interest and satisfaction!
    Thanks for posting it!
  • Altra
