The ground X signal is only present during transmission so it obviously can't be present during a period of non-transmission regardless of what unregistered Doug says in post #131.
We could though use an example from his forum where they claim to sample earlier than Minelab by using a balanced coil even though they don't do anything to make this possible.
They claim to be able to sample at 11usecs when using a mono and have all GB samples out of the way 15usecs after switch off when using a balanced coil.
At the time they made this claim their sampling routine occupied 12usecs (2usec on, 2 off, 2 on, ~4 off, 2 on), so it would appear their first sample commenced at around 3usecs.
This means they would be sampling the spike in their first and second samples and sampling the true off period in their last sample.
Zed,
There is huge potential for information during the on time as has been disclosed in some patents.
I was only pointing out that the reactive signal is a problem for the novice who is still trying to get up to speed. This doesn't mean that others haven't a solution though. Remember ML brought out the Sovereign well before the SD2000 and obviously know the on time advantages and problems intimately and if you know the problems then you can work out the best way to address them.
I think you will find they have most bases covered if you spend time ploughing thru their patents.
I don't get what you mean here "Now PI detectors have the natural ability to discriminate between ferrous and non ferrous targets but it all comes undone because of the second sample as in a conventional PI".
Any objects such as ground material or metal objects give a signal of one polarity after pulse switch off in conventional single sample pi so I'm not sure what you mean when you say PI is a natural discriminator?
Have you tested your idea and do you have any pictures of the waveforms?
Tinkerer,
Enough of the vast knowledge bit. I wish!
I'm only interested in clearing up the simple basics. If we don’t then it just ends up a confusing mess.
I mentioned Dave Emery's patent because he uses a pi type pulse to generate a large back emf at switch off then causes this to ring with a cappy, something we avoid in pi. He then samples the resulting oscillations similar to vlf (IB) so this is actually a high powered vlf and not pi.
You do much the same but sample the spike itself so it is high powered IB or TR.
B^C,
I for one agree that your chart accurately depicts pi when looking at an ideal target provided the tx coil's spike has settled for a suitable period before sampling begins when using a mono or balanced coil.
I don't work for ML!
Take no notice of the troll. He is only interested in destroying Minelab, me, JP and anyone who thinks ML makes good detectors, He gets everything wrong as he clearly demonstrates here...
