PI Power Output
  • Tinkerer
    Forgot to attach the PDF
    It just does not want to upload. will try once more.
    Tinkerer
  • Tinkerer
    Originally posted by B^C View Post
    Tinkerer,
    I unzipped the file you posted but it seems it's in a different format than what i can open, is there a program i can open it with?
    Hi B^C,
    the EAGLE is V5.4. It seems that the different versions are not compatible with each other.
    I have changed the schematic into a PDF so that should work.
    I like to use just a front end for the testing. Then I know what I see. Once the signal has been processed, one does not know anymore how it looked like at the beginning.
    I feel the most important part is the front end. If the input is bad, even the best processing will not make it good.
    Tinkerer
  • B^C
    Tinkerer,
  • B^C
    Thanks for the explanation Aziz, It is hard to model all the parameters & mostly due to them being unknown at this stage.
    I have a lot of data that doesn't seem to be able to be reproduced when not in the field for some reason?
    Like mentioned it would be good to have everybody test with the same things.
    Target response signal reading, what is the best way to do this, i have tried numerous ways & also including just having an O-scope probe across the test piece--target but the results vary.
    I have gold nuggets to get some readings from but as yet i do not like the way i have been testing these or the results.
    I want to test this individually away from the MD circuit, basically i want to use just an adjustable one shot circuit with inductor charge time & voltage variable, trigger this to pulse the target & read the target response with no other circuit connections, whats the best way to get good results.
    TX on time, if it is the transient spike that is going to give us the largest target inducing pulse then the TX on time is really only the inductor charge time--correct?
    If i am correct then all the test results will vary from individual to individual because all the inductors will vary so the intensity of the inducing pulse will also vary & so the results.
    We will need to find the inductor saturation time as it would seem going beyond this point may be a waste of time & power?
    As a test std why don't we just use say some 18AWG winding wire as it's readily available & we can just wind a suitable diameter inductor for testing, at least this way we can share comparitive results.
    I was reading an article where a university tested a lot of detectors including a ML prototype, with air testing of the targets all other detectors where better by far than the ML. The second test was done with the target in the ground & the ML won hands down & all the others where not comparable--food for thought!
    Tinkerer, it's hard to see the schematic, can you post it again?
  • Tinkerer
    Originally posted by nick_f View Post
    Hi Tinkerer,
    I can hardly see the circuit, it is too small.
    Did you try adding an electrolytical cap in parallel on the V+ to AGND?
    Can't you use an external power supply (linear and regulated with a LM317) to provide 15V? If it is only for testing, that would be ok,
    Nicolae
    Here is the Zipped EAGLE file.
    Tinkerer
  • nick_f
    Hi Tinkerer,
    Nicolae
  • Tinkerer
    So I found the source of the noise. With the higher voltage, the power supply
    makes more noise.
    Here is the power supply.
    How can I reduce the noise?
    Tinkerer
  • Tinkerer
    LONG OR SHORT TX PULSE
    Long or short TX pulse.
    Does it make a difference?
    Do the eddy currents caused by the ON transient diminish the response of the OFF transient?
    I set up the following experiment:
    TX coil = 325uH, 280mm diameter, 2.8 Ohm DC resistance for a TC of 116uS
    RX coil = 300uH, 140mm diameter
    Test # 1, coil current of 1.65A, using 8V for 100uS TX
    Test # 2, coil current of 1.65A, using 15V for 43uS TX
    The samples were taken at 2.5uS after switch OFF
    The total gain is 69 by the preamp (OP37) single stage.
    The output of the preamp was held in a Sample & Hold (NE5537) to facilitate the reading.
    The targets were placed on top of a plastic box at a distance of 150mm from the center of the coil.
    The targets were chosen to provide a wide variety of TC, from 5uS to about 200uS
    # 1 -- ½” square alu foil with a TC of 5us Results: Test # 1 = 1mV Test # 2 = 1mV
    # 2 – 1” square alu foil with a TC of 10uS = 3mV = 3mV
    # 3 – US$ 5c coin, with a TC of 20uS = 7mV = 7mV
    # 4 – US$ 1c coin, with a TC of 70uS = 6mV = 6mV
    # 5 – US$ 10c coin, with an estimated TC of 100uS = 5mV = 5mV
    # 6 _ US$ 25c coin with an estimated TC of 200uS = 14mV = 14mV
    If the Eddy currents generated by the ON transient have any influence on the signal amplitude of the Eddy currents generated by the OFF transient, the difference would be most visible on the targets with long TC’s.
    If the amplitude of the OFF transient Eddy currents is influenced by the TX pulse time relative to the TC of the target, this should be most visible for the US$ 1c, with a TC of around 70uS and being pulsed with 43uS or about 60% and 100uS or about 143% TC
    Results:
    There is no difference between the results. The only difference was in the noise level. With 15V – 42uS TX, the noise level is considerably higher. I don’t know the reason yet. Possibly it could be that I did not sync the timing with the 60Hz power line.
    Tinkerer
  • nick_f
    Hi Tinkerer,
    The CRT monitors have a circuit with MOS-FET and a 1mH ferrite coil that generates about 90V if I remember right, at a decent power (like 50W I think).
    If you say your intention is to sample during the on time and looking to use a high voltage, you should charge a larger capacitor to whatever voltage you want (even 100V or more) and connect it to the coil for a limited period of time, until the maximum current through the coil is reached.
    Based on your observations (I have yet to check if they are working for me), I have some other interesting idea. There are some voltage converters for cold cathode neon tubes that are very small in size and they can generate up to 600 or 1000V. I have one at home, I had to put a few fast diodes (1N4937) in series to withstand the voltage. I think it sort of doesn't matter if you monitor the target response during the fall of the flyback pulse or the raise of the flyback pulse (as long as there is a fast change in the magnetic field). When the coil is not energised, you can apply a high voltage (let's say 400V...1000V), that will create a fast raising magnetic field. If we can maintain the magnetic field constant in the coil for 10us, I think we can sample at any period of time that doesn't exceed that interval. Which is the opposite of the standard PI circuit and in this case, it wouldn't matter about the falling part pulse. I have to do some simulations. And a coil with a low inductance will raise the current (and magnetic field) much faster than a large inductance. A balanced receiver coil with many turns could check for the target.
    Nicolae
  • Unregistered
    Guest replied
    Gday Aziz, the simulations are good, thank you!
    Couldn't help but ask & off the subject a little but maybe relevant.
    Different diameter inductors-coils have a distinct magnetic field strength surrounding them, how can we add or subtract this into the spice sim to compensate for this?
    Can we just drop the supply voltage to do this or change the coupling of the target?--calibrating is another thing i know.
    The point i am getting at is that the transient spike voltage & characteristic would seem to be dependant on the strength of the magnetic field surrounding the inductor at the time of collapse. The diameter of the coil has an influence on this as well it would seem.
    If i'm wrong just belt me over the head!
    Eg:
    If we have two coils with the same inductance etc & fed from the same power supply a 8" coil is going to have a more intense magnetic field surrounding it than say a 16" coil has so the transient spike must be affected?
    It would seem as though this may be the reason why large coils won't detect small nuggets, the spike ain't big enough to induce them hence the use of smaller coils?
    So one would think to look at things better we need a Test std especially if the transient spike voltage changes with different diameter coils. This way we can all look at & test the same things?
    Or i may need a kick in the butt!
    Or how much of a transient spike is measured from a 16" coil compared to an 8" with the same specs, inductance etc?
    A bigger coil has a bigger field which means the field lines extend further from the coil before the curl region compared to a smaller coil.This is why you need bigger coils to detect larger objects at depth.However the field strength of a bigger coil (all other things being equal) is smaller than for a small coil and hence has less sensitivity to small objects.The s/n of bigger coils is also often poorer because a bigger antenna is more effected with EMI noise than a smaller antenna (coil).The ground signal amplitude from a bigger coil may also be very much larger than with a small coil because the "ground volume" under a big coil is larger than with a small coil and bigger coils (particularly mono's) are more susceptible to induced geomagnetic field noise than smaller coils.
  • Tinkerer
    Hi B^C,
    I never did a real calibration yet (still haven't the instruments to measure the parameters). The target model parameters are just estimated. You can see below the very basic target model. It is really difficult to model a real target. But the basic model will give quite good results to the interesting questions anyway.
    A target consists of some inductivity (parameter LTgt), capacitance (parameter CTgt) and will dissipate the induced energy through its resistance path (RTgt). It is more or less coupled to the TX coil (parameter TgtCoupling).
    Fortunatelly I bought today an oscilloscope (Tektronix 455), which will help to measure or give a better estimation of the target parameters. Then a more realistic simulation could be done. The target model itself could be modelled with a lumped model. But this is quite more complex to do it.
    Conductivity of the target is indepent to the coupling factor. I will list the dependencies of the parameters now (might not be complete):
    TgtCoupling (target coupling) is dependent on:
    - Transmitter coil size, transmitter coil orientation (to the target)
    - Target size, targe distance, target orientation, target shape
    - other objects nearby the coil/target, that affects the magnetic fields
    Target LTgt (target inductivity) is dependent on:
    - Target size, target shape, target material (permeability)
    Target RTgt (target resistance) is dependent on:
    - Target size, target shape, target material (conductivity)
    Target CTgt (target capacitance) is dependent on:
    - Target size, target shape, target material, other materials nearby the target
    So it is quite difficult to model a target as the parameters interact with each other.
    Thanks AZIZ, you have characterized the target parameters very well.
    Please ignore my post about target surface area. It was posted before I saw this post.
    Tinkerer
  • Tinkerer
    Aziz, yes i thought simulating this wasn't an issue.
    One other thing, the conductivity of copper vs gold for the simulation, if we add some resistance to the target inductor this should do the job --yes!
    Obviously the copper inductor will show better results than we would expect?.
    My question is how much resistance to add as a constant?
    Or do we just adjust the coupling as talked about?
    http://environmentalchemistry.com/yo...lectrical.html
    The surface area of the target has a very big influence on the coupling factor.
    Tinkerer
  • Aziz
    Hi B^C,
  • B^C
  • Aziz
    Hi Zed,
    Originally posted by ZED View Post
    Aziz looking at your last graph i dont see anywhere where your faster flyback has any real advantage,sampling one to two u/s after switchoff is not realistic,five to six u/sec after switchoff is a more likely scenario in which case it would appear that the slower system has more to offer.
    Zed
    Thats true from the point of target response only. If you can not sample earlier, then you will loose signal (integration area of signal).
    Darn, but the clamping diodes 1N4148 are responding better with fast system and give some real advantage over slow damping. That is, which surprizes me.
