Originally posted by B^C
).To simulate different TX coil diameter, the parameter TgtCoupling=0.01 must be changed. For a given target (smaller than the coil radius), bigger coils have less coupling to the target. Smaller coils have more coupling. But the distance, shape, size and orientation of the target has also an influence to the coupling factor. So it is difficult to calibrate a system. Therefore only relation of the response is important. Not the absolute values. If you know all of these parameters, than a more realistic simulation could be done for a specific configuration.
Supply voltage Ubat and ton (transmit pulse width) defines the exposed magnetic field energy and is not convenient to simulate different TX coil sizes.
An 8" and 16" coil with same inductivity L would give for the same target different response. The coupling of TX coil and target differs in this case. Small targets on bigger coils would therefore have less response due to less coupling. Coupling means: How many and how strength magnetic fields are going through the target?
The basic spice simulation indeed allows deep analysis of very interesting questions. I have taken an ideal switch for the model, to make a comparison between fast and slow damping as the flyback voltage shouldn't clipped due to mosfets avalanche breakdown voltage.
I have found, that the conductivity of the target matters much in respect to the target response! If you take a comparison for a fixed time constant target TC and different conductivity of the target (target inductivity differs then), then the target response differs quite much. Particularly long TC targets with low conductivity have less response.
We should all play a bit more with spice simulations.
