Hello,
with a three position switch, the all metal mode works now. Many thanks. The all metall mode is a little strange without a tone for iron. Next tests outddors.
Jürgen
King Cobra PCB
Hello all,
My wires on sitch Mode was in a good order. I unsoldered all wire of the Mode switch and after I put in contact 1ML and 1MM together ( like All Metal mode ). Nothing no sound?
SW
I've drawn the switch connections and added the colors of the wires in accordance with the scheme. I hope I can help with anything.Attached Files
Yes, both switches are 3 positions of. This is seems from the photos I did put.The switch must have 3 positions. Medium position is to METALL ALL.
NOTCH - ACCEPT/OFF/ REJECT
MODE - DISC/ALL METALL/SET ALL METALL.This right position is NOT fixed, not fixedable, is only clickable. Althought you can take and use ordinary 3-P switch, but you have to remember to set the switch in middle position anytime (or fixed left one). SET - I mean you set the S.A.T. circuit to some zero, althought there is nothing new - you have to see this part in TGSL too and may be reading about.
So? I see.Originally posted by eduardo1979 View PostThe Kobra do not have a tone for iron. It has two tones, one for the foil and the other for higher conductivity metals. If a coin is placed behind a mineral, the Kobra detects the currency with a low tone, (foil).
Than it is better than TGSL for sure.
BTW could anyone here tells us; does King Cobra suffers from masking problem?
Testing it should be simple;
take piece of mineral and cover some coin with it, than try to detect it in Disc mode.
I tested XP Gold Max Power and it is also liable to "partial" masking problem (watch video bellow).
If you watch my test carefully;
you will notice that audio at GMP changes from high tone to low tone when mineral is between gold coin and search coil.
That's example of masking i am talking about.
In case of TGSL under same conditions: TGSL is not producing tone at all ... or eventually can produce occasional "cracks".
In case of IGSL: IGSL is producing nice low tone mixed with broken high tone.
Deus is producing middle tone when tested like this.
So, is there anybody willing to perform similar test with King Cobra (preferably original one)?
Cheers!
You do not have well connected switch DISC / ALL METAL. The switch must have 3 positions. Medium position is to METALL ALL. Double check the schema and put here a photo of the switch connections. Mine worked the first time.Originally posted by Miata View PostAnatolij, thank you for the hint. I have replaced the resistors.
I have make first tests, the discrimination mode works with some inteferences, but the all metall mode works not. No metall is detected.
I checked values of all parts and solder pads. Perhaps an OPAmp is fault.
Jürgen[ATTACH]21475[/ATTACH]
Hello Anatolij,Originally posted by Miata View PostAnatolij, thank you for the hint. I have replaced the resistors.
Jürgen
I have exactly the same problem too; the Discrimination mode works with some inteferences, but the All Metal mode does not work. Do you have some idea.
When you build a project like the King Cobra, it is always advisable to build and test the design in sections. Not simply solder everything onto the board, switch on, and hope it works. Nine times out of ten (Murphy's Law) you will be unlucky.Originally posted by Miata View PostAnatolij, thank you for the hint. I have replaced the resistors.
Jürgen
You should start with the power supply, and work forward from there.
- Likes 1
Look good, nice work. Mine is in the way too, I have some problems with wrong values components coming from supplier.
Now I'm ready for first tests. Hope my original Tesoro coil works. Some first pictures.
JürgenAttached Files
