Originally posted by simonbaker
Here are a few details on my grounding experiment. Attached are the two grounding schemes that I have tried. Coil details are as follows:
* 5 complete coils.
* 4 of them have been wired per the "TGSL coil making" pdf.
* One of them that I made has not been tested in wet grass (the one I
sent you) but is wired per the TGSL coil making pdf.
* One has been wired without any active parts of the coil attached to the
shields in any way (see attached). This one is quiet in wet grass..
* That leaves me with 3 coils that behave badly in wet grass.
* All 4 of my 27cm coils airtest at over 30cm for 1e. (one is a smaller DD
test coil).
* For all practical purposes, there is no real difference is detection depth between grounding schemes.. just ungrounded is quieter.. I have about 10 hours of
actual use on the ungrounded one at the beach.. I found 115 coins total in a week.
* All are shielded the same, have the same type of shell, epoxy and cable.
See attached links to videos for wet grass demonstration..
Sensitivity was at minimum in both videos.
GB on ferrite.
Disc set to MIN.
Don
Links to videos.
http://www.youtube.com/watch?v=XhRboS639no (Grounded)
http://www.youtube.com/watch?v=7UBOca3btMw (Ungrounded)
. Isn't digging sand nice! Just tricky to avoid the public sometimes...
