I know metal detectors and radios are not the same thing but the idea is the same.
The Rx is a zero or low IF type, our target signals after the mixer/sychronous detector - reside at anywhere from 0 to 15Hz and is dependant on shaft length and the demeanor of the operator!
Ive done some club digs in the UK with 80 people in a line up with a shotgun start - the front runners will cut you in half with their mad hacking slash and fully extended units.
It would be real neat to get a sig gen on these units to get a real number for performance - rather than where we are now.
It may be possible to take a sniff of the Tx coil signal, buffer it to provide isolation, add some FM somehow, attenuate to uV range and wire to Rx input.
If your Tx was derived from a xtal you could use a quality synthesised signal 9Hz above or below to give an IF signal in the Filter bandwidth.
Or maybe a VCO phase locked to your Tx with Audio tone as a modulation input to FM it and feed that to RX.
If the Rx sig was simply phase shifted from the Tx (which it isnt its frequency shifted also i.e. more than a cycle of shift) you could have put the Tx signal down a roll of coax to get a phase shifted signal for the Rx, or another RC delay.
S
I just didn't leave enough margin to account for highly mineralised soil: red soil soaked in sea salt. I couldn't get anything from the sea though - my GEB pot with poor margins didn't reach it. Waving a coil over the sea without a real ground balance produced a very funny series of tones.
