Bipolar PI design
  • pechkata
    Hello Carl-NC
    How can we program a time slot?
    How can we build this type - time slot?
    I tried but I can't do it.
    Click image for larger version  Name:	viber_изображение_2025-04-11_12-45-47-335.jpg Views:	0 Size:	292.0 KB ID:	436758
    Click image for larger version  Name:	viber_изображение_2025-04-11_13-58-12-133.jpg Views:	0 Size:	292.7 KB ID:	436759
    Click image for larger version  Name:	viber_изображение_2025-04-11_12-45-22-964.jpg Views:	0 Size:	374.7 KB ID:	436760
  • Detectorist#1
    Hi pechkata,
    Any news for very interesting investigations - why 3 pieces of this project work differently?
  • ivconic
    I can't tell from the voltmeter, too hard to see. An oscope trace will tell you quickly.
    I'll do that next time I sit to deal with it.
  • ivconic
    Originally posted by pechkata View Post
    I glued 3 pieces of circuit board.
    All three work differently.
    One of them works like yours.
    https://www.youtube.com/shorts/Z1NFVttxZ0E
    That's interesting to investigate!
  • Carl-NC
    You didn't tell me your opinion about the voltage?
    Is that how it should act?
  • pechkata
    It makes sense.
    In the previous videos you saw the behavior on coins.
    It always behaves the same.
    I still have doubts about the quality and originality of these TL072s.
  • pechkata
    Greetings to all...
  • ivconic
    If you are expecting a roll of solder to be a low conductor, it's not; it's a high conductor, just like the nail. Get some household aluminium foil and cut a 25cm square piece, use that for a low conductor.
    It makes sense.
  • Detectorist#1
    Bravo pechkata! Very good result with home-made bifilar TX OO coil! I also work on bipolar MD with GB now.
  • Carl-NC
  • ivconic
    First, check that both demods are working correctly: IC5a should have a positive-negative target signal and IC5b should have a negative-positive target signal. If these look OK, then check the soldering of you GB pot, especially the pin to the ground channel.
    Carl , I am lost, here is the video, go figure:
  • eduardo1979
    Very good videos!!!
  • pechkata
    Continuation:
  • pechkata
    I knew something good would eventually come out of this!
  • ivconic
